On 8-May-2005, "BTIZ" wrote: BTW, how many out there are aware that 80 octane unleaded avgas used to be available, back in the 40s and 50s? Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... 80/87 avgas was (is) NOT unleaded. It just has less lead content than even "low lead" 100 (100LL) and WAY less than "conventional" 100 octane (which you never see anymore). -- -Elliott Drucker |
wrote in message news:_CBfe.4084$nX1.2291@trnddc09... On 8-May-2005, "BTIZ" wrote: BTW, how many out there are aware that 80 octane unleaded avgas used to be available, back in the 40s and 50s? Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... 80/87 avgas was (is) NOT unleaded. It just has less lead content than even "low lead" 100 (100LL) and WAY less than "conventional" 100 octane (which you never see anymore). The specification for red 80 octane did include the option for no lead to be added. We had it at the airport until about a year ago. |
BTIZ wrote: Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... Red gas was available in some places until fairly recently (historically speaking). My airport was selling it right up until 2002. Oddly enough, I saw some red gas the other day. My tiedown neighbor owns a 150 that never flies. Every few years, he spends several thousand on an annual and maintenance, then ends up not flying. The cycle repeats every other year. Just the other day he had a team of A&Ps and IA surrounding the plane on the ramp, getting it ready to fly again. He's finally selling it. When he sampled the fuel and it came out red colored, everyone on the ramp just busted out laughing. We figured he had the last surviving example of 80/87 aviation gas in the country. Too bad such rarity doesn't make his ramp queen worth any more :-( John Galban=====N4BQ (PA28-180) John Galban=====N4BQ (PA28-180) |
I got my last tankful of 80/87 at RBL about November of last year,
awhile after the last refiner stopped producing it. It had become a rarity over the last ten years or so - you had to know where to go to get it. David Johnson |
: Detonation is NEVER a problem when the octane is correct. If the engine
: is designed for 80 octane, it will happily drink 80 octane mogas or : anything else that meets the minimum spec. The absence of lead in the : fuel simply means that there is less junk to scavenge out of the : combustion products. That's not completely true. Some engines are marginal on their rated fuel (in particular, fire-breathing TGSIO-ABC-XYZ-540's putting out 350 hp or whatever). Even some planes could be marginal on their rated fuel in the worse possible condition. For example, long climb, just under redline CHT, fuel at the bottom of the permissible octane rating, carb float/jets at the leanest possible configuration, etc, etc. The bigger variable is that autofuel does not use quite the same rating as avgas. Autofuel (in the U.S. anyway) uses an (R+M)/2 rating, or anti-knock-index (A.K.I). The point spread between the two is not published, but is generally about \pm 5 points, with the lower (motor) most closely similar to the aviation method. Basically, that means that 87 AKI autogas is probably about 82 motor, 92 research. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Jim Carriere wrote: Awww, anecdotal evidence. Statistically speaking, you need a larger sample size ![]() Actually would be more like a longitudinal case study... same subject evaluated over a long period of time. Applicable only to the individual, or perhaps a population of similar subjects... but still a valid data point. I like the bit about the hours/years on the spark plug... Dave |
"Jay Honeck" wrote in message news:y6zfe.67777$WI3.10767@attbi_s71... Yesterday I noticed that we had pumped more than 5000 gallons of mogas through the Mighty Grape. This represents something like 60 complete fills (our plane has four gas tanks, totaling 84 gallons), and around 350 hours of flight time over the last 2.5 years. (See: http://alexisparkinn.com/fuel_truck.htm for details on our Jim Weir-inspired fuel truck, the "Mighty Grape"...) At an average saving of over $1 per gallon (at the moment, it's more like $1.25), we have paid for the truck (which we use extensively at the hotel), the tank & pump installation (which has worked flawlessly from "Day One") -- and put aside over $2500 toward our next overhaul. Best of all, Atlas (our Lycoming O-540-powered Cherokee Pathfinder) simply runs best on regular, 87-octane unleaded car gasoline. In fact, the ONLY time we've had trouble with our new engine has been when we were forced to buy 100LL avgas, which causes lead-fouling of our spark plugs at the drop of a hat. All the worries that people stated, both personally and here in this forum, have turned out to be entirely baseless. After flying with mogas for the last 2.5 years, I can unequivocally state the following: 1. Mogas works better in my plane than avgas. Our engine runs noticeably better on mogas. 2. I have had no problems with contamination of any kind (my pump/tank installation has a very good filtration system) 3. If we've run across any ethanol, the engine has never burped because of it. 4. We've run mogas from sea level to 13,500 feet, in temperatures from -15 to +97 degrees Fahrenheit, without problem. Because of this, I state further that: 1. I would burn mogas in my plane even if it cost MORE than avgas -- it runs that much better. 2. I will never buy a plane that doesn't have the auto gas STC. The autogas STC is undoubtedly the best thing that has ever happened to aircraft owners. If you've got the STC, but aren't using it, you are literally flushing thousands of dollars down the toilet. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" The only down side to mogas I have noticed is the smell. |
Dave Stadt wrote:
The only down side to mogas I have noticed is the smell. I had a friend who liked to sniff gasoline, once. God rest his soul. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
On 2005-05-09, Jay Honeck wrote:
Best of all, Atlas (our Lycoming O-540-powered Cherokee Pathfinder) simply runs best on regular, 87-octane unleaded car gasoline. Unfortunately the engine isn't the only consideration. For some reason the Comanche is subject to vapor lock with mogas so there is no STC available. What's really sad is that last year this time I was paying less for avgas than I am *now* for mogas. -- Ben Jackson http://www.ben.com/ |
| Thread Tools | |
| Display Modes | |
| MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Home Built | 82 | May 19th 05 03:49 PM |
