"Denny" wrote in message Now they are willing to kill people who get lost and cross invisible lines in the sky so that the powerful and the politically connected can feel safe... So...refresh my memory. How many people were killed in this incident? -c |
"Mortimer Schnerd, RN" wrote in message
om... What goes up must come down. Somewhere. The technical term for that is, "GRAVITY SUCKS"... |
The plane was already 15 miles in a 30 mile zone when the F 16 took off
and was only 3 miles out when intercepted. If this was a terrorist piloted airliner from Reagan National, takeing a northbound left turn instead of right. The WH or capitol would be toast. |
"Sport Pilot" wrote in message oups.com... The plane was already 15 miles in a 30 mile zone when the F 16 took off and was only 3 miles out when intercepted. If this was a terrorist piloted airliner from Reagan National, takeing a northbound left turn instead of right. The WH or capitol would be toast. The F-16s weren't the only line of defense, just the first. There are also patriot missile batteries and other SAM installations. It turns out the first line of defense got the job done, and didn't even kill anybody. I'm not exactly clear what failed except for the Cessna pilot's navigational skill and the politicians' nerve. On the other hand, we have the benefit of hindsite. All the people in the capitol knew is that there was a red alert and that a plane appeared to be coming directly at them despite rather obvious airspace closures. They wouldn't have necessarily known whether it was a Cessna or a 747. Personally, if I thought a 747 might be aimed at my building and mere miles out, I'd run like hell too. I wouldn't run downstairs...that's where the fuel leaks and the oxygen burns. -c |
Sport Pilot wrote:
The plane was already 15 miles in a 30 mile zone when the F 16 took off and was only 3 miles out when intercepted. If this was a terrorist piloted airliner from Reagan National, takeing a northbound left turn instead of right. The WH or capitol would be toast. Yes, but the TSA/HSA/SS believe that they have put adequate security precautions in for htat. National departing passengers are subject to additional screening, and the pilots are specially trained to get the hell away from DC if anything (passengers standing up, etc...) occurs. We've had a bunch of diversions to IAD of DCA flights since 9-11. The GA flights in the FRZ reqiure that the pilots get special security checks and there are special procedures. When security level goes to orange, this also incoming flights first to an outlying airport to check the passengers and "cargo". Similar restrictions on depatures are in effect. |
Jay Honeck wrote in message ...
Officials Weighed Shooting at Errant Plane By LARA JAKES JORDAN, Associated Press Writer 37 minutes ago Pentagon officials sought to play down the incident, saying the small plane was not seen as a serious threat and did not come close to being shot down. "The quantity of explosives that you can pack in a little Cessna is not the quantity of explosives you see placed in these big truck bombs," Jenkins said. "In terms of explosives, it probably could not do that much damage." They could probably see the two adults sitting in that Cessna 150 as if flew merrily along into the restricted zone. I haven't done a weight and balance calculation on a Cessna 150 in a couple of decades. How much cargo weight remains after putting two adults in the front seats? is it 6 or 8 pounds?? That wouldn't allow for a very large bomb. I can see why they decided that the plane wasn't much of a threat. |
"Ted" wrote
I haven't done a weight and balance calculation on a Cessna 150 in a couple of decades. How much cargo weight remains after putting two adults in the front seats? is it 6 or 8 pounds?? That wouldn't allow for a very large bomb. I can see why they decided that the plane wasn't much of a threat. The maximum Takeoff Gross Weight limit for a C-150 is a legal limit, not a physical limit. It is estabilished by the FAA as the maximum weight that will permit a go-around at the maximum flap setting and has nothing to do with the maximum weight that the airplane will carry for takeoff and cruise. In fact, for the C-172, by restricting the maximum flap setting to 30 degrees instead of 40 degrees, the maximum Takeoff Gross Weight was raised by 100#. Bob Moore ATP CFI |
The maximum Takeoff Gross Weight limit for a C-150 is a legal limit, not a physical limit. The physical limit isn't much higher. And you run out of payload SPACE probably before you hit that... You'll run out of ability to maintain level flight long before you get to the structural limits. |
Ron Natalie wrote: The maximum Takeoff Gross Weight limit for a C-150 is a legal limit, not a physical limit. The physical limit isn't much higher. And you run out of payload SPACE probably before you hit that... You'll run out of ability to maintain level flight long before you get to the structural limits. On a cool day a long runway and some patience the physical limit is much higher. Don't know how much but I wouldn't be suprised if it could be double on a winter day. Add a 150 or even a 180HP engine and the physical limit is huge. |
| Thread Tools | |
| Display Modes | |
| Close call with engine failure in IMC | G. Sylvester | Instrument Flight Rules | 12 | March 16th 05 06:57 AM |
| Comming close | Tony | Owning | 17 | May 18th 04 07:22 AM |
| RAF Boulmer (England) to close | Peter Ure | Naval Aviation | 0 | April 29th 04 06:02 AM |
| D.A.: Pilot flew close to airliner | John R | Piloting | 8 | February 3rd 04 12:03 PM |
| Veteran fighter pilots try to help close training gap | Otis Willie | Military Aviation | 0 | December 2nd 03 11:09 PM |
