"JJ Sinclair" wrote in
oups.com: I could play a tune with my Nimbus when just moving the flaps up and down----Weeeee-----wooooo----wrrrrr-----weeeee. Hey JJ, my PIK-20d played the same tune. Were they in the same band? -Bob Korves |
Dick,
I looked at my Ventus tonight and I see that the flap drive is about two inches inboard from the end of the flap, but about four inches will need to be cut off. How did you deal with the flap connection hardware when you trimmed the flaps? At the upper (connection) end of the flap is there enough room that you do have to change anything? Thanks, Tim |
Hi Tim,
No hardware needs to be changed to install the wing root fairings, and shortening the flap roots is easy. Dick Johnson |
| Thread Tools | |
| Display Modes | |
| Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 06:07 PM |
| Wing root fairings | D.A.L | Soaring | 10 | October 29th 03 12:36 PM |
| wing root strakes (not canard A/C) | Wallace Berry | Home Built | 0 | October 2nd 03 09:47 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 04:52 AM |
