Earlier, John Sp wrote:
...Play seems to be about 10 thou (+-.25mm) which translates to about .75 inch of "Waggle" At the wing tip... I'm not an engineer, but somehow that doesn't add up. Simple geometry suggests that in order for 0.010" of play at the root to yield 0.75" at the tip, the ratio of the depth to the semispan would have to be around 75:1. Operating from basic specs and a grainy 3-view, it looks to me like the semispan is around 17 feet and the depth (height from the wing mount to the strut mount) is around 4 feet. That yields an actual semispan/depth of only around 4:1. With that arrangement, +/- 0.010" of play at the bolt yields a vertical play at the wingtip of around +/- 0.040". Some semi-random comments on this situation, in no particular order: * There's a thread on a similar topic on the discussion boards at http://www.supercub.org but it seems to concern J-3 rather than PA-18. However, I'll bet that you would more quickly get a good response on that board than here. * Was there perhaps a typo in this post? If the .75 is mm instead of inches, then it all makes sense. On the other hand, I can't imagine worrying about .75mm of wingtip vertical play... * I know from measuring wing mounting play on various gliders that it is very hard to measure wingtip vertical play separate from wing flexibility. It's hard to tell where mechanical slop ends and limberness begins. * It's possible that you are actually seeing +/- 0.010" of play at the strut bolt and 0.75" of vertical play at the tip. But only if there are also other sources of play such as the fuselage-to-wing mounting, or the strut mount provisions inside the wing. * A certain amount of play is inevitable. There is simply no way of making the wing mounting provisions completely tight without using interference fit fasteners. Good luck, and best regards Bob K. http://www.hpaircraft.com |
| Thread Tools | |
| Display Modes | |
| Heater problem fixed! | Jim Burns | Owning | 14 | December 17th 04 11:38 PM |
| SSA Website problem | Raphael Warshaw | Soaring | 2 | February 12th 04 03:56 PM |
| RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 10:10 PM |
| Help with serious Glider Registration Problem | Soaring | 5 | November 12th 03 05:01 PM | |
| Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 04:06 PM |
