Negative flaps for better low speed aileron control?
Old August 18th 05, 08:54 AM
dav
Hi all,
1.I have a guess at the question of airbrakes improving low speed
response-they simply deflect extra air around their sides, increasing
the airflow over ailerons and wing root.
2.One point I must take issue with was in regards to Reynolds numbers.
Qoute:"I doubt that. Turbulence is associated with high Reynolds
number, and
that depends directly on speed. Low speed - low Re - less
turbulence."
At low RE the boundary layer is much more easily transitioned to
turbulent flow(In fact at RE=60,000 flow is considered critical and
boundary layer attachmnent will fail), therefore turbulence is much
more likely at low RE NOT high RE.
Interesting that no one else noticed that eh?
But as a modeller as well as fullsize pilot I have studied the effects
of low RE a lot more I guess.....
3.I fly a Hornet often, an aircraft with I believe the same fuselage as
the Mosquito, and it also shows the wing drop on ground run tendency,
due to high AOA in the two point position.
4. Small chord tips at low speed may well be sub RE60,000, not creating
ANY lift until RE60K is reached!(RE is proportional to speed, chord and
air density).
Regards & Safe flying to all
Dave Lawley
dav
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old August 19th 05, 09:49 PM
Eric Greenwell
Looking at top views of gliders, it appears the spoiler is always well
inboard of the aileron, so I don't see how significant air can be
deflected to them. With my ASW 20, the improvement occurred whether the
airbrakes were open 10 mm or 50 mm, so I think the improvement is caused
by spoiling lift rather than any deflected flow.
Tufting the wing between the spoilers and ailerons would allow a direct
check of the change in airflow. This could be done in a 20 mph wind, so
the glider would not even have to be moving.
Eric Greenwell
Washington State
USA
Old August 19th 05, 11:33 PM
5Z
Once it starts moving, even slowly, the wing is producing lift. The
more lift is produced, the more difficult it is to cause a wing to
drop, as this lift distributed over the whole wingspan damps a tendency
to roll.
Eliminate this damping by opening the spoilers and now the feeble
aileron is able to cause a roll.
Try this experiment: On a day with a light wind, sit in the glider
while it's pointed into the wind. Starting from a wings level
position, start rocking the wings. With the spoilers open, you will
find that you are able to go steeper and make quicker reversals. If
the wind is very light, it may all you can do just to keep the wings
level.
-Tom
Old August 20th 05, 04:04 AM
Bob Gibbons
to roll.
... text deleted ...
-Tom
This topic of why opened spoilers assists low speed roll control
really is one of those questions that comes up again and again. From a
post 5 years ago on r.a.s.
Bob
Subject: Dropping a wing on takeoff
Newsgroups: rec.aviation.soaring
View: Complete Thread (63 articles) | Original Format
Date: 2000-11-02 21:18:53 PST
This topic, that is, why deploying spoilers seems to help roll control
at low speeds, has come up often in RAS during the
years. Unfortunately, we seldom seem to get responses from
knowledgeable aeronautical engineers as to the real cause for what is
generally acknowledged as a real effect.
Earlier today I asked Dick Johnson the cause of this effect. I will
try to summarize his reply, but I may miss some of the finer details,
so any aerodynamicists, feel free to correct me. BTW, for those who
are not familiar with Dick credentials, in addition to his long
history of contest successes, Dick is a professional aerodyamicist
with 50+ years of experience.
Dick's response was that the effect of increased roll effectivness
with spoiler deployment is real, and is caused by a 3-dimensional flow
effect initiated by the spoiler deployment disturbing the normal low
pressure area over the top of the wing in the area of the
spoilers. The breakup of the normal low pressure in the spoiler area
results in a lateral spanwise flow in the airfoil forward of the
ailerons. This lateral flow modifies the normal pressure distribution
on the airfoil forward of the ailerons and allows the airfoil in the
aileron section to operate at a higher angle of attack (without flow
separation, i.e., stalling) than would otherwise be possible, thus
allowing greater aileron effectivness during the takeoff roll.
The effect is more pronounced in standard class gliders since without
the benefit of flaps to modify the airfoil camber, standard class
airfoils are often set on the fuselage at a higher angle of attack
than the corresponding airfoil on a 15m flapped ship. Furthermore, 15m
ships, with interconnected ailerons, can decamber their airfoil
(select negative flap) and generate increased resistance to flow
seperation at the ailerons during the early ground roll.
Hope this helps, and, as I said, this is an restatement by a
non-professional, corrections by practicing aerodynamicists welcome.
Bob
Old August 25th 05, 07:01 AM
Bruce Hoult
I've observed that the Club Libelle (similar to the Hornet) suffers from
wing drop, while the Std Libelle doesn't.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
ASW-20 flaps setting VS speed AttentionLEcureuil Soaring 4 March 10th 04 12:25 AM
Speed Astir Guy Acheson Soaring 0 December 11th 03 03:24 AM
Overweight takeoff / flight Koopas Ly Piloting 50 December 4th 03 12:53 AM
Flaps and V-Tails of Death Wallace Berry Soaring 59 November 26th 03 10:54 PM
