![]() Rich S. wrote: "abripl" wrote in message oups.com... With bullet/plane(s) relative horizontal speed of 820ft/s, the other plane reaches the bullet position in (50x3)/820 =3D 0.183 sec (pretty slow bullet). In that time the bullet falls a vertical distance of 0.5 x 32 x 0.183 x 0.183 ft =3D 0.536 ft. If the messer plane bottom was at least 0.537 ft (about 7 inches) below bullet firing vertical position its gona hit the other plane. Half a foot at 50 yards? I misrememeberd that a 45 drops half an inch at 50 yards. How embarassing. Nope. You are assuming "the other plane reaches the bullet position . . .= "=2E It never reaches the bullet's position because it is traveling at 90=B0 t= o the flight path of the B-17. If it was following the B-17, it could possibly = run into the bullet, but only at its foward velocity. The bullet has only a downward component relative to the Earth. (Ignoring minor variations, i. = e=2E coriolis force & wind velocity.) You're still assuming he's leading the ME-109 as if the gunner were in a fixed location. He's assuming the gunner is actually trying to hit the plane, and smart enough to figure out how so that he times his shot *correctly*. You're both assuming he fires straight back. He can hit the Me-109 by firing straight back, but ONLY if he fires exactly as B-17 crosses the flight path of the Me-109, and only if the Me-109 is fast enough or close enough to get there before the bullet drops out of the flight path of the Me-109. If the Me-109 is at a range of 50 yards, and no slower than the bullet the bullet will be no more than 7 inches lower than the muzzle of the gun and will still hit the Me-109 assuming the two planes are at the same altitude. Here is an example: Both planes are at the same altitude. The gunner fires straight back and level when the B-17 crosses the flight path ahead of the ME-109. At that moment, the Me-109 is at a range of 50 yards, e.g. it is 50 yards directly to the right of the gunner and flying from right to left, and also flying at 820 ft/s. If you think that bullet misses, calculate by how much. Now do that again, assuming the Me-109 is a bit faster, say, 900 ft/s. There is a range of realistic speeds and altitudes for the Me 109 for which it will be hit, and a larger range of speeds an altitudes for which it can be hit if the gunner is allowed to aim up or down, larger still if he can aim from left to right even though in all cases the ME-109 is flying at 90 degrees to the flight path of the B-17. --=20 FF |
ups.com... You're still assuming he's leading the ME-109 as if the gunner were in a fixed location. He's assuming the gunner is actually trying to hit the plane, and smart enough to figure out how so that he times his shot *correctly*. You're both assuming he fires straight back. He can hit the Me-109 by firing straight back, but ONLY if he fires exactly as B-17 crosses the flight path of the Me-109, and only if the Me-109 is fast enough or close enough to get there before the bullet drops out of the flight path of the Me-109. If the Me-109 is at a range of 50 yards, and no slower than the bullet the bullet will be no more than 7 inches lower than the muzzle of the gun and will still hit the Me-109 assuming the two planes are at the same altitude. Fred............... I'll say it again - you misunderstand the question. I have stated it as clearly as I am able and even drawn a diagram. I don't know how else to explain it. I'm a pilot. I talk with my hands (hopefully without resorting to certain gestures). The B-17 is flying West. The ME-109 is flying South. They are both at the same altitude. There is no wind. The ME-109 will cross the flight path of the B-17 and the B-17 will, at that moment, be fifty yards from the ME-109. The tail gunner fires his weapon straight behind the B-17. There is no way that he can hit the ME-109, given the stated speed of the B-17 and the muzzle velocity of the bullet. The ME-109 will *always* be fifty yards or more away from the bullet. Always. Rich S. |
![]() Rich S. wrote: wrote in message ups.com... You're still assuming he's leading the ME-109 as if the gunner were in a fixed location. He's assuming the gunner is actually trying to hit the plane, and smart enough to figure out how so that he times his shot *correctly*. You're both assuming he fires straight back. He can hit the Me-109 by firing straight back, but ONLY if he fires exactly as B-17 crosses the flight path of the Me-109, and only if the Me-109 is fast enough or close enough to get there before the bullet drops out of the flight path of the Me-109. If the Me-109 is at a range of 50 yards, and no slower than the bullet the bullet will be no more than 7 inches lower than the muzzle of the gun and will still hit the Me-109 assuming the two planes are at the same altitude. Fred............... I'll say it again - you misunderstand the question. I have stated it as clearly as I am able and even drawn a diagram. I don't know how else to explain it. I'm a pilot. I talk with my hands (hopefully without resorting to certain gestures). The B-17 is flying West. The ME-109 is flying South. They are both at the same altitude. There is no wind. The ME-109 will cross the flight path of the B-17 and the B-17 will, at that moment, be fifty yards from the ME-109. The tail gunner fires his weapon straight behind the B-17. There is no way that he can hit the ME-109, given the stated speed of the B-17 and the muzzle velocity of the bullet. The ME-109 will *always* be fifty yards or more away from the bullet. Always. Rich S. The way I see it, you are both in agreement. Fred says to hit the 109 he has to fire at the exact time the 17 croses the 109's path. That is correct. In effect he says that to fire as per your example he can't hit it. Harry K |
![]() Rich S. wrote: wrote in message ups.com... You're still assuming he's leading the ME-109 as if the gunner were in a fixed location. He's assuming the gunner is actually trying to hit the plane, and smart enough to figure out how so that he times his shot *correctly*. You're both assuming he fires straight back. He can hit the Me-109 by firing straight back, but ONLY if he fires exactly as B-17 crosses the flight path of the Me-109, and only if the Me-109 is fast enough or close enough to get there before the bullet drops out of the flight path of the Me-109. If the Me-109 is at a range of 50 yards, and no slower than the bullet the bullet will be no more than 7 inches lower than the muzzle of the gun and will still hit the Me-109 assuming the two planes are at the same altitude. Fred............... I'll say it again - you misunderstand the question. NO. I understood the question(s) and I answered them. The gunner cannot hit the ME 109 by aiming and firing the ways you described. There are an infinite number of ways the gunner can aim and fire and miss, you picked some of them. You also stated multiple versions with different circumstances, not just different wording. It is not clear that you realize that. After answering YOUR questions, we then addressed the question of how the gunner could hit the ME 109. That question was NOT your question. That is a different question and I don't see how I can make THAT any clearer to you. No rule of nettiquette requires that we limit our discussion to only the case you present. You are not the boss of us! Courtesy requires that we make it clear when and how we change the statement of the problem. We have made that clear. You just don't realize that. We changed the problem by relaxing the constraint on when the gunner leaving him free to fire whenever he wants to. Why? Because we're Americans goddamnit we want him to score a hit. What are you, German? clearly as I am able and even drawn a diagram. I don't know how else to explain it. I'm a pilot. I talk with my hands (hopefully without resorting to certain gestures). The B-17 is flying West. The ME-109 is flying South. They are both at the same altitude. There is no wind. The ME-109 will cross the flight path of the B-17 and the B-17 will, at that moment, be fifty yards from the ME-109. The tail gunner fires his weapon straight behind the B-17. In *this* statement of the question, unlike your first, you do not say WHEN he fires. Since I WANT him to hit, I'll tell YOU when he fires. Got it! He can hit the ME-109 by firing when the B17 crosses the flight path of the ME-109. Then the Me-108 is due North of the gunner. If he waits any longer, the Me-109 passes east of the bullet. If he fires sooner, the Me-109 passes West of the bullet. If he fires when the ME 109 is due North the Me-109 either hits the bullet or passes over it depending on the range and speed of the Me-109. You specified that the Me-109 passes fifty yards behind the B-17. A hit requires that the time between firing and the time the ME-109 arrives behind the B-17 is the time it takes the B-17 to travel 50 yards. OP already calculated that, and also calculated that the bullet drops 7 inches in that time. You did not specify the speed of the ME-109 or the range when the gunner fires, so we are free so vary those as needed. there are several combinations of speed and range that allow the ME-109 to be due North when he fires and cross 50 yards behind. For instance, if the Me-109 is flying at the same speed as the B-17 and it crosses 50 yards behind it, then the Me-109 will also be 50 yards when it is due North of the B-17 and the gunner can therefor fire when the B17 is at a range of 50 yards and hit. What a coincidence! This time around I did not have to change the problem because this time around you did not constrain the time at which the gunner fires. There is no way that he can hit the ME-109, given the stated speed of the B-17 and the muzzle velocity of the bullet. Wrong. The way is if he fires WHEN the B-17 crosses the flight path of the Me-109. That drops a bullet in the flight path of the Me-109 and if the Me-109 is 50 yards due North when the gunner fires and flying at 820 fps the Me-109 and the bullet are *both* 50 yards behind the B-17 when the Me-109 crosses the flight path of the B-17. The bullet has only dropped 7 inches, so it hits. The ME-109 will *always* be fifty yards or more away from the bullet. Always. Not if the gunner fires when the B17 crosses the flight path of the Me-109. That drops the bullet right in the flight path of the Me-109 and the Me-109 closes on it as it drops. Here is a hint. If you constrain all of the variables to specific values the question is 'does', not 'can'. 'Can' implies at least on variable is unconstrained as in your question above wherein you left the time at shich the gunner fires free to vary. -- FF |
Rich S. wrote:
There is a (magic) B-17 flying along at 560 mph. The tail gunner is out of .50 caliber ammo. He sees a Messerschmitt ME-109 crossing behind the B-17, 50 yards away. He pulls out his trusty .45 Colt auto (muzzle velocity 820 fps) and fires at the Hun when the ME-109 is directly behind the B-17. He leads the Messerschmitt by exactly enough to hit the pilot (if he were firing from a fixed position). Does the bullet exit the muzzle and fall directly to earth? Rich "Scratching my head" S. Forgetting turbulence following the B-17 the bullet would still have a muzzle velocity of 900 FPS, assuming a military load. 50 yards is 50 yards and the Me109 would still be hit assuming proper aim. Whether it does much more than penetrate the canopy I don't know. Put the trailing turbulence back into the scenario and all bets are off. Dan, U.S. Air Force, retired |
"Dan, U.S. Air Force, retired" wrote in message
news:cdOTe.9805$dm.6970@lakeread03... Forgetting turbulence following the B-17 the bullet would still have a muzzle velocity of 900 FPS, assuming a military load. 50 yards is 50 yards and the Me109 would still be hit assuming proper aim. Whether it does much more than penetrate the canopy I don't know. Put the trailing turbulence back into the scenario and all bets are off. Remember, the ME-109 is not following the B-17. It is crossing behind the B-17 at 90° and is fifty yards behind the bomber at the moment their flight paths cross. The bullet comes out of the muzzle with a velocity of 820 fps relative to the pistol. The pistol however, is traveling 820 fps in the opposite direction relative to the ME-109. Therefore the bullet has zero velocity toward the ME-109 and drops straight down due to gravity. Rich S. |
You've made an irrelevant assumption here.
The answer is "It's all a matter of relativity" With the correct lead, it does not matter what speed relative to the ground the bullet is travelling, relative to the two aircraft is what is important. remember the bullet is spinning so also maintains some gyroscopic stability. All bullets fall to earth at 9.8 m/s^2 regardless of their path over the surface of the earth. With the correct lead the bullet and the ME-109 colide, at which point the tragectory of the bullet is drasticaly altered such that it, and teh ME-109 all fall/fly to earth as one mass. If the case is simplified such that the bullet is simply fired backwards but at nothing, then it will accelarate to earth, only with a 0 lateral velocity relative to the ground. Rgds, "Rich S." wrote in message ... There is a (magic) B-17 flying along at 560 mph. The tail gunner is out of .50 caliber ammo. He sees a Messerschmitt ME-109 crossing behind the B-17, 50 yards away. He pulls out his trusty .45 Colt auto (muzzle velocity 820 fps) and fires at the Hun when the ME-109 is directly behind the B-17. He leads the Messerschmitt by exactly enough to hit the pilot (if he were firing from a fixed position). Does the bullet exit the muzzle and fall directly to earth? Rich "Scratching my head" S. |
Several people, most of whom have at least had physics, and at least one
with a degree in physics have stated that you are wrong and why. Suggest you read the thread before you post. Jim "BRO" wrote in message ... With the correct lead the bullet and the ME-109 colide, at which point the tragectory of the bullet is drasticaly altered such that it, and teh ME-109 all fall/fly to earth as one mass. |
![]() RST Engineering wrote: Several people, most of whom have at least had physics, and at least one with a degree in physics have stated that you are wrong and why. Suggest you read the thread before you post. ... "BRO" wrote in message ... With the correct lead the bullet and the ME-109 colide, at which point the tragectory of the bullet is drasticaly altered such that it, and teh ME-109 all fall/fly to earth as one mass. No. With the _correct_ lead he can hit. The _correct_ lead is different from how he would lead if he was firing from a fixed position. The _correct_ lead is incompatible with firing when the ME-109 is directly behind the B-17. He cannot correctly lead the Me-109 AND fire when the Me-109 is directly behind the B-17. But he CAN correctly lead AND fire straight back. In fact, he correct lead if the ME is at a range of 50 yards, when the B17 crosses the flight path of the ME-109, is to fire straight back. Then he will hit when the Me-109 is fifty yards behind the B-17. The problem is not with what he said, but with what he did not say. He didn't say what part of the original problem he was changing in order to introduce his new condiditon, _correctly_ leading he Me-109. Maybe he didn't realize there was an incompatibility, or mybe he thought it would be obvious which statement he was dropping. Which just serves to demonstrate the conventional wisdom about assumptions. -- FF |
![]() "Rich S." wrote in message ... There is a (magic) B-17 flying along at 560 mph. The tail gunner is out of .50 caliber ammo. He sees a Messerschmitt ME-109 crossing behind the B-17, 50 yards away. He pulls out his trusty .45 Colt auto (muzzle velocity 820 fps) and fires at the Hun when the ME-109 is directly behind the B-17. He leads the Messerschmitt by exactly enough to hit the pilot (if he were firing from a fixed position). Does the bullet exit the muzzle and fall directly to earth? Rich "Scratching my head" S. OK, more questions. What was the muzzle velocity of the .50 machine guns used as tail guns? What kind of gun was installed in the stinger on a B-58? |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Accurate plane performace? | R | Simulators | 27 | December 19th 03 04:54 AM |
