wrote in message ... On Wed, 07 Sep 2005 10:45:55 -0500, Charlie Wolf wrote: S-2's or S-3's?? S-2's are now approaching 60 years old. S-3's would be in the neighborhood of 35 yr old.... Stoofs. The last were retired in '75 time frame (from VS-73). They are still flying with Brazil and Thailand (at a minimum) making it one of the longest serving military aircraft of all time. :-) Bill Kambic Nice looking aircraft, I always thought - what were they like to fly?. Quick question that's always bugged me about carrier ops: On final approach, do you fly the same heading as the carrier but a bit to the right then change to the angle of the angled deck, or start your approach further to teh right and treat the ships movement liek a crosswind from the right? TIA |
On Wed, 07 Sep 2005 19:30:42 GMT, "Tom" wrote:
Nice looking aircraft, I always thought - what were they like to fly?. Well, those that were unkind described it as "two T-28s flying formation on dempster dumpster." :-) It was a reasonably agile airplane for having as much wing as it did. During low level ops (100' day, 300' night) it was stable and very honest. Single engine performace was quite good at lower operating weights. It did not get you anywhere fast. :-) Quick question that's always bugged me about carrier ops: On final approach, do you fly the same heading as the carrier but a bit to the right then change to the angle of the angled deck, or start your approach further to teh right and treat the ships movement liek a crosswind from the right? If the OOD is doing his job then the wind is down the angle. If not, you do a little slip, not a "crab." It's a visual approach so actual heading is not something in your scan; it's "meatball, line up, and airspeed." Non-precision approaches (ADF and TACAN) were flown on BRC (base recovery course) and you transitioned to visual and were back to "meat ball, line up, and airspeed"); or missed approach. Non-precision CCA or FCA (Fudd Controlled Approach) were like at the field (fly the heading given and altitude suggested) until visual then transion; or missed approach. Precision CCA was similar (and you awaited "3/4 mile; call the ball") on all of them. Night IMC approaches were always good for a thrill or two. Add in some high seas and weather minimums and you might get to "splice the mainbrace." :-) Bill Kambic |
wrote in message ... On Wed, 07 Sep 2005 19:30:42 GMT, "Tom" wrote: Nice looking aircraft, I always thought - what were they like to fly?. Well, those that were unkind described it as "two T-28s flying formation on dempster dumpster." :-) LOL.. I think it looks sort of.. functional and...cute, possibly. Organic. snip Non-precision approaches (ADF and TACAN) were flown on BRC (base recovery course) and you transitioned to visual and were back to "meat ball, line up, and airspeed"); or missed approach. Right.. was the BRC calculated so that you hopefully intercepted the glideslope in time to transition to visual and land? i.e. a sort of gentle lead pursuit? Non-precision CCA or FCA (Fudd Controlled Approach) were like at the field (fly the heading given and altitude suggested) until visual then transion; or missed approach. Precision CCA was similar (and you awaited "3/4 mile; call the ball") on all of them. What was your approach speed relative to the carrier? I'm guessing 60 kts or so.. so that's only 45 secs to sort it out.. not long if you're a bit off and the wind's blowing! Night IMC approaches were always good for a thrill or two. I bet they were... some high seas and weather minimums and you might get to "splice the mainbrace." :-) or the main spar! Bill Kambic |
On Wed, 07 Sep 2005 20:49:58 GMT, "Tom" wrote:
Non-precision approaches (ADF and TACAN) were flown on BRC (base recovery course) and you transitioned to visual and were back to "meat ball, line up, and airspeed"); or missed approach. Right.. was the BRC calculated so that you hopefully intercepted the glideslope in time to transition to visual and land? i.e. a sort of gentle lead pursuit? I have some of the old INTREPID approach plates around in my "old stuff box." I'll see if I can find them and answer your question more accurately. Non-precision CCA or FCA (Fudd Controlled Approach) were like at the field (fly the heading given and altitude suggested) until visual then transion; or missed approach. Precision CCA was similar (and you awaited "3/4 mile; call the ball") on all of them. What was your approach speed relative to the carrier? I'm guessing 60 kts or so.. so that's only 45 secs to sort it out.. not long if you're a bit off and the wind's blowing! Normal instrument approach was flown at 105kts and 2/3 flaps, if my aging memory is correct. Wind over the deck was usually in the 25-30 kt. range on most days and nights. I'd say the ship was doing 20 kts. plus or minus about 90% of the time. The landing was made in the 2/3 flap configuration (vice the full flaps used in VMC conditions). Bill Kambic |
On Thu, 08 Sep 2005 15:06:53 -0500, "B.C. Mallam"
wrote: How about the nights, in wx, that the only way to get aboard was to let down until you could see the glow of the ships wake and then follow it to the boat. Flying a slow a/c helped a lot on those nights. On nights like that the stiff wingers got "Signal Bingo*". The rotorheads had to descend until they could find the trail of sea water activated flares that were being dumped off the fantail every 30". Bill Kambic * Bingo: procedeed the designated or pre-briefed land base. |
Too many times "bingo" was the boat and the Stoof got us aboard with this
approach. This was early 60's VS-33 On 8/9/05 3:40 PM, in article , " wrote: On Thu, 08 Sep 2005 15:06:53 -0500, "B.C. Mallam" wrote: How about the nights, in wx, that the only way to get aboard was to let down until you could see the glow of the ships wake and then follow it to the boat. Flying a slow a/c helped a lot on those nights. On nights like that the stiff wingers got "Signal Bingo*". The rotorheads had to descend until they could find the trail of sea water activated flares that were being dumped off the fantail every 30". Bill Kambic * Bingo: procedeed the designated or pre-briefed land base. |
| Thread Tools | |
| Display Modes | |
| VP-II wings available in Oregon, USA (Or, "How I was coconuted...") | Roberto Waltman | Home Built | 2 | October 29th 04 05:21 PM |
| Charging for Wings safety seminar? | Marty Shapiro | Piloting | 19 | June 23rd 04 06:28 PM |
| Double covering fabric covered wings | [email protected] | Home Built | 9 | May 9th 04 09:39 PM |
| Stolen "Champ" wings located...from 23,000 feet!! | Tom Pappano | Piloting | 17 | December 15th 03 02:24 PM |
| Wings from "Champ" stolen in Oklahoma after emergency landing | Tom Pappano | Piloting | 1 | December 7th 03 06:02 AM |
