"cleared to ... when direct ..."
Old February 9th 04, 11:24 PM
John Harper
Default "cleared to ... when direct ..."
Got an odd clearance the other day, on climbout from Santa Monica
(IFR but in perfect VMC): "climb and maintain 6000 when direct
Ventura". I took this to mean that someone would later clear
me direct VTU, whereupon I would climb. However I never got
such a clearance, and later an evidently nervous controller called
me, cleared me to 6000', and asked me if I had the terrain in
sight (which I did, but it was getting close for IFR though not
worrying visually).
I wonder what this clearance really meant? Did it mean "when ABLE
direct", i.e. when I could receive the VOR (which I couldn't
initially although I was filed /G anyway)? Or did someone just
forget to give me the subsequent clearance?
John
Old February 10th 04, 12:07 AM
Roy Smith
In article 1076365605.761786@sj-nntpcache-3,
worrying visually).
I suspect you dropped a word (or he did). It sounds like it should have
been "climb and maintain 6000. When able, direct Ventura".
I would have started a climb to 6000, taken a WAG at the heading to
Ventura, turned to that heading, and begun to tune in the VOR (or hit
direct on the GPS). Once I had a good signal, I would have tracked it
direct.
Old February 10th 04, 12:32 AM
Bob Gardner
I'm going to quibble with Roy just a bit. "When able," in my mind, means
"when you can proceed direct without hitting anything." You can get a good
needle and still hit terrain. In this clearance, however, my guess is that
6000 feet was his minimum instrument altitude and you were good to go at
that altitude.
Bob Gardner
"Roy Smith" wrote in message
worrying visually).
direct.
Old February 10th 04, 12:46 AM
Roy Smith
In article ZLUVb.12036$032.41047@attbi_s53,
that altitude.
I certainly hope not! If 6000 was the MIA, what was the controller
doing issuing a route clearance? If John was on initial climbout, I
assume he was on a DP. How can the controller take him off the DP below
the MIA?
To get what Bob is talking about, I think the clearance needed to be
worded something like, "climb and maintain 6000, upon reaching 6000,
direct Ventura". On the other hand, if that's what the controller
wanted, it would have been simplier (and less confusing) to just issue
the altitude, and the direct Ventura once he reached it.
Bob Gardner
worrying visually).
direct.
Old February 10th 04, 01:25 AM
Teacherjh
Well, if I"m in the soup, the only way I know I won't hit anything is to trust
the controllers. They aren't supposed to vector me into terrain. Now granted
I need some situational awareness, but not to the extent that I don't need
controllers and the instrument flight rules themselves.
Jose
Old February 10th 04, 02:00 AM
Were you receiving departure radar vectors?
If so, a word was dropped or missed. The clearance you quote would make
no sense so it should have been promptly questioned. I suspect the
clearance was "cimb and maintain 6,000, when able direct Ventura."
worrying visually).
John
Old February 10th 04, 02:13 AM
John Clonts
"John Harper" wrote in message
news:1076365605.761786@sj-nntpcache-3...
worrying visually).
John
Which runway off of SMO?
Old February 10th 04, 03:51 AM
Jay Somerset
worrying visually).
Or it might have been, "climb and maintain 6000, THEN direct Ventura" which
would require him to get to 6000 before turning. No way to tell -- either
is plausible.
direct.
Old February 10th 04, 05:37 AM
John Harper
Thanks for all the answers. This was runway 21 at SMO, heading
out over to the ocean. No DP, but standard procedure is RH
to intercept LAX315 (the coastline), then 270, vecs to VTU.
I don't THINK I misheard (although memory is a fickle thing) because
I heard him say exactly the same thing to the following departure as well.
The idea that I should climb to 6000 THEN Direct VTU would make
sense except that turning Direct would actually vector me slightly
AWAY from the terrain.
I was at 3000 which is high enough to not bump into any terrain locally
but certainly not IFR en-route clearance (the highest peak in the
ridge is about 2700 from memory).
Guess next time I'll ask.
Thanks again,
John
worrying visually).
John
Can ATC assign an airway if filed direct? Andrew Sarangan Instrument Flight Rules 26 March 4th 04 01:23 AM
Funny Radio isums... [email protected] Instrument Flight Rules 30 December 15th 03 01:34 PM
Cleared for Hire for sale Kobra Instrument Flight Rules 0 November 25th 03 04:11 PM
"Direct when able" Mitchell Gossman Instrument Flight Rules 18 October 21st 03 02:19 AM
Filing direct John Harper Instrument Flight Rules 10 October 9th 03 11:23 AM
