#21
"Ernest Christley" wrote In the same DA$$ truck. Some engineer at Dodge aught be shot...with both a metric and standard size bullet!! They all seem to do it, at least on some models. My full sized Chevy van is somewhat consistent. If it is a hole in the engine block, it is SAE. If it is something not screwed into the engine, it is metric. -- Jim in NC |
Ernest Christley wrote: wrote: Stealth Pilot wrote: America uses a mix of traditional and SI units In the same DA$$ truck. Some engineer at Dodge aught be shot...with both a metric and standard size bullet!! Yes indeed! My 1994 Plymouth Voyager mini-van has both standard and metric fastners in the drivers seat. I found out last month when I had to replace the seat recline mechanism and the seat pan. The recline mechanism has the metric fastners, leading me to believe it is manufactured offshore. |
"W P Dixon" wrote: What are you building Smitty Two? If your close by I'll help you with some rivets. Patrick student SP aircraft structural mech Thanks, Patrick. I sent you an email; let me know if it gets lost in the ether. |
Eh? No Mac version? What is:
http://www.turbocad.com/prodinfo.asp?t=1&mcid=321 Well, it isn't DeltaCAD, which I thought was our topic. And I'm not sure that it qualifies as easy to use, but I'd welcome feedback on that score. It is harder to use than DeltaCad, but not by much, and it has more options. Rather than the 10 minutes it takes to figure out DeltaCad plan on taking an hour or 2 with TurboCad. I have AutoCad, Solid Works, BobCad, and a few others but I use the TurboCad for 90% of my drawings. I find it quicker than most to use. The only prolem I've come up with is that I can't find any drivers that will print correctly to my old HP plotter using WinXP. Win98 works just fine!?. Encad drivers also work OK for that plotter with either OS. ================ Leon McAtee |
wrote The only prolem I've come up with is that I can't find any drivers that will print correctly to my old HP plotter using WinXP. Win98 works just fine!?. XP can run a 98 emulator, I believe. -- Jim in NC |
For 2-D CAD on a MAC, I use CADINSTOSH.
lemkesoft.com/en/cadintosh.htm I actually like DeltaCAD better, and have gone so far as run it on my MAC using Virtual PC, but I don't recommend anyone else do that - getting Virtual PC to reliably print is something I haven't been able to master, and the documentation is no help. DeltaCAD will run on the cheapest, oldest, stupidest PC, and for less than 200 bucks you can get a used system to devote to just CAD if you really feel the need. As for Linux devotees, here's a list of Linux resources for y'all to explore (I've investigated/used none of these): http://www.tech-edv.co.at/lunix/CAD.html and http://www.tech-edv.co.at/lunix/CADlinks.html |
#28
Stealth Pilot wrote: ... hey bob. do you realise that america has been a metric country for over 103 years now. are you going to get the message soon? :-) What, you don't like binary fractions? Alexander Hamilton convinced the US to adopt metric currency. Shortly after, he was taken out and shot. -- FF |
#29
#30
Coming to R.S.'s defense. I've used AutoCad in various versions for
years and have had projects from RC aircraft, home construction, parts design, and full size aircraft components. After already investing a lot of learning time into AutoCad, I bought a copy of DeltaCad 3.0 at a discount store for $10 years ago. I was amazed at how simple it was to learn and how powerful it was for such a small program. I've kept that program through three computers and dozens of projects. For all projects I now use DeltaCad to work up my drawings. I no longer have AutoCad installed on my computer. The only drawback I've seen with DeltaCad is my old version doesn't properly save multi-point spline curves in .dxf files. I know this was corrected in later versions. Currently, I use DeltaCad to create templates for aluminum cutting for aircraft components, and reproduction of gauge faces and decals of cockpit labels and such. All of this is in conjunction with the restoration work we are doing on a WWII vintage North American Aviation P-51H Mustang at the Octave Chanute Aerospace Museum in Rantoul, Illinois. In my experience, there is not a better entry-level Cad program to be found. If you don't believe me, try the demo. http://www.dcad.com/demo.html I'm certainly not a salesman for DeltaCad, but I don't mind spreading the word when something works this well for so little cash. Norm Meyers Project Director Mustang Restoration Project http://home.insightbb.com/~p51h/index.htm Octave Chanute Aerospace Museum www.aeromuseum.org |
| Thread Tools | |
| Display Modes | |
| Big Bertha Thing blogs | Tony Lance | Owning | 0 | November 22nd 05 03:13 PM |
| A Sure Thing | [email protected] | Soaring | 5 | January 8th 05 01:16 AM |
| The Most Beautiful Thing Ever | Grantland | Military Aviation | 37 | October 28th 03 06:10 AM |
| Is a static port a precision thing? | Larry Smith | Home Built | 8 | August 12th 03 11:26 PM |
| SUV thing | Fastglasair | Home Built | 4 | July 12th 03 06:32 AM |
