G Farris wrote:
With all these questions about how to integrate GPS into our everyday operations, I'm tempted to believe we have allowed the advent of this wonderful new technology to send our thinking back to the dark ages! We want GPS to simply replace everything else - then all that "legacy" stuff just becomes a backup, in case the GPS signal or on-board equipment should become unreliable. This presents problems - as has been pointed out in the above threads - as we are not usually flying airways and overlays (at least that's the idea) so transitioning to the "legacy" stuff is not always that quick and easy, especially in high workload moments like approaches or missed approach procedures. I don't know why we don't simply weave GPS into the RNAV web that was already part of our mentality before GPS came along. With one integrator box, receiving signals from VOR/DME/ILS/eLORAN and GPS we could fly random routes, RNAV waypoints and approaches even with one primary system (GPS for example) inoperative or unreliable. An in-flight failure of one such system would still leave us with full RNAV capability, but might be our clue to fly an overlay, such that the (unlikely) failure of a second system would make transitioning easier. We consider the old KNS-80 style RNAV boxes to be obsolete today - but in a way they were more forward-looking than the way we're going about GPS today. G Faris The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. This will take a long time, but it will happen. And, it's all about Required Navigation Performance (RNP). RNP, by definition, is sensor independent, although that has some practical limitations today. The new RNAV (RNP) procedures are premised on the possibility the GPS will fail. Without this assumption, the target level of safety required for small RNP containment areas cannot be achieved. This is particularly true of the missed approach segment. Note that the first FAA RNP procedure at KDCA does not require RNP for the missed approach, just for the approach segments. OTOH, the newer RNP procedure at KSUN requires RNP for the missed approach because of terrain. The DCA procedure can be flown without a second system of RNAV. The SUN procedure cannot. Presently, the only approved second system is two (preferably three) IRUs feeding at least two flight management systems. Eventually, IRUs, or something quite similar, will become affordable for light aircraft. These concepts are where the forward thinkers are going, and not just in this country by any means. |
Bob Noel wrote:
In article xl0kf.62898$qw.59268@fed1read07, wrote: The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. DME, and probably MLS, will be around for a while longer. Alas, where are the MLSes? DME will remain only if the legacy carriers can keep flying, and keep their first-generation, non-GPS, LNAV aircraft flying to need the arcane DME/DME update protocol. |
In article z67kf.62948$qw.39145@fed1read07, wrote:
The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. DME, and probably MLS, will be around for a while longer. Alas, where are the MLSes? Outside of the US -- Bob Noel New NHL? what a joke |
Bob Noel wrote:
In article xl0kf.62898$qw.59268@fed1read07, wrote: The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. DME, and probably MLS, will be around for a while longer. Don't count on it...elimination of all ground-based navaids. Even the FAA has reconsidered this flawed from the beginning concept. Ron Lee |
Ron Lee wrote:
Bob Noel wrote: In article xl0kf.62898$qw.59268@fed1read07, wrote: The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. DME, and probably MLS, will be around for a while longer. Don't count on it...elimination of all ground-based navaids. Even the FAA has reconsidered this flawed from the beginning concept. Ron Lee Which FAA? ;-) As the budget crunch deepens, and it will, the pressure to do away with most ground facilities other than ILS will be irresistable. One variation is to shut down the VORs but leave "geometrically desirable" DME facilites going until the legacy air carrer LNAV platforms retire. That would be a whole lot less expensive than maintaining aging VOR facilities. The bean counters want to do away with primary radars, too. But, so far, the security-minded have stopped that planning. |
Bob Noel wrote On 12/02/05 15:50,:
In article xl0kf.62898$qw.59268@fed1read07, wrote: The FAA, and the rest of the world as well, want to eventually shut-down the VORs. The only remaining ground-based systems will be ILSes. DME, and probably MLS, will be around for a while longer. I suspect that having more than 3 levels of backup is counterproductive. I.e., GPS backed up by Loran backed up by VOR backed up by ADF, etc. That represents a lot of onboard equipment to go wrong, forget how to use, etc. The obvious candidates to go are ADF, marker beacons, and DME. DME isn't going away soon because the airlines use it. If the airlines wanted toliets on ballons in the sky, they'ed get them. |
the VORs. The only remaining ground-based systems will be ILSes. Uhm, not quite. The JAA is all hot about DME-DME area navigation. They thing GPS is not reliable enough. Go figure... -- Thomas Borchert (EDDH) |
