On Tue, 13 Dec 2005 22:37:26 GMT, Jon Kraus
wrote: How about one of these to use up that idle 220 volt connection. http://www.heatersunlimited.com/item29471.ctlg Let's see @ X 15KW at say 7 cents per KWH is $$2.10 an hour but they should run intermittently after they are up to temp. I've forgotten my physics...any one... what's 30KW in BTU? I remember 746 watts per HP. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Jon Kraus '79 Mooney 201 4443H @ TYQ Gig 601XL Builder wrote: What is the groups suggestion for heating a 40x50 insulated hanger. It doesn't have to be hot I just want to raise the temp about 15-20 degrees when it is 30-40 outside. Here's the rub. No natural gas available plenty of electric though including an unused 220 connection. To see the hanger visit www.peoamerica.net/N601WR look in the contact me area. Gig Roger |
Roger wrote:
I've forgotten my physics...any one... what's 30KW in BTU? According to a formula I found at "infoplease", that works out to 102,360 BTU. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
"George Patterson" wrote in message news:dYNnf.14092$Ea6.1451@trnddc08... Roger wrote: I've forgotten my physics...any one... what's 30KW in BTU? According to a formula I found at "infoplease", that works out to 102,360 BTU. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. My 75K natural gas unit heater costs $1.00 per hour as a comparison. |
Dave Stadt wrote:
My 75K natural gas unit heater costs $1.00 per hour as a comparison. If that was last year, it may be considerably more this year. Here in Jersey, it probably won't be too bad -- the providers are only asking for a 40% rate increase, but I've heard stories of rates doubling. Still cheaper than electric, of course. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
On Wed, 14 Dec 2005 05:25:33 GMT, "Dave Stadt"
wrote: "George Patterson" wrote in message news:dYNnf.14092$Ea6.1451@trnddc08... Roger wrote: I've forgotten my physics...any one... what's 30KW in BTU? According to a formula I found at "infoplease", that works out to 102,360 BTU. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. My 75K natural gas unit heater costs $1.00 per hour as a comparison. Depending on what I'm doing I keep the shop 28 X 40 at 70 to 72 degrees F for about 12 out of 24 hours with the other 12 at 62 to 64 for about $2.00 to $3.00 a day in this very cold weather and it's 75,000 BTU as well. Of course it's not running all the time. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger |
You may have a winner there.
"Jon Kraus" wrote in message ... How about one of these to use up that idle 220 volt connection. http://www.heatersunlimited.com/item29471.ctlg Jon Kraus '79 Mooney 201 4443H @ TYQ Gig 601XL Builder wrote: What is the groups suggestion for heating a 40x50 insulated hanger. It doesn't have to be hot I just want to raise the temp about 15-20 degrees when it is 30-40 outside. Here's the rub. No natural gas available plenty of electric though including an unused 220 connection. To see the hanger visit www.peoamerica.net/N601WR look in the contact me area. Gig |
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote: www.peoamerica.net/N601WR Too bad the floor is already poured. The best hangar heating is via a heated floor. You plumb it before you pour and connect it to a boiler. Makes it much more comfortable on your feet and legs while working on the plane during the cold months and keeps the heat out of the rafters. |
("john smith" wrote)
Makes it much more comfortable on your feet and legs while working on the plane during the cold months and keeps the heat out of the rafters. Floor heat is afraid of heights? :-) Montblack |
On Wed, 14 Dec 2005 03:17:34 GMT, john smith wrote:
In article , "Gig 601XL Builder" wrDOTgiaconaATcox.net wrote: www.peoamerica.net/N601WR Too bad the floor is already poured. The best hangar heating is via a heated floor. You plumb it before you pour and connect it to a boiler. Makes it much more comfortable on your feet and legs while working on the plane during the cold months and keeps the heat out of the rafters. The IR heater in my shop heats the floor to the same temp as the rest of the building. I do have two of the large ceiling fans to circulate the air to prevent much of a temperature variation between the floor and ceiling. If I have any complaint about the tube heater it would be the noise and the supplied thermostat. The noise is not bad, but it's not quiet. Mine, like most furnaces takes the inlet air from the room. If I did it again I'd use a firebox that takes in outside air. The standard thermostat is just a bimetallic strip. It has a very wide dead band between on and off. Enough of a dead band that you get chilly before it turns on and uncomfortably warm before it turns off. It was probably about 6 degrees or more. With the thermostat properly located and replaced with the programmable one the temperature never changes enough for you to see the digits change on the read out. Set it at 70 and the inside goes to 70. Both will always read 70 even though the furnace will occasionally turn on for a few minutes. Even with the much colder temperatures this year compared to last and the gas usage is about half of what it was. To heat a hangar efficiently it needs very good insulation in the walls, ceiling and doors. Those doors need to seal well too. It helps if the floor is insulated from he ground as well although that is not often done. However it works very well. As one of the major problems with heating a hangar is it's height, ceiling fans and a lot of insulation up there can really improve the efficiency. Without the fans you have to put a lot of BTUs into the room so the area up to head high is comfortable. When you do that, quite often you will find it is much warmer near the ceiling. That makes for a large temperature differential between inside and outside which required even more insulation and makes for high heat /energy loss Were I going to build a hangar I'd model it after my shop. The foundation would be insulated from the inside with a thermal break and the floor would be insulated from the ground as well as the foundation. The ceiling would be no higher than necessary to clear the tail on a light twin in the "kneeling" position (just in case). Painted (pre finished) "Barn Metal" makes a good inside surface for the walls and ceiling. It is far easier to install than dry wall. It costs a bit more but less labor makes it close to a wash in price. If the code allows and you can afford it, off set studs between the inside and outside also make a big difference, but add about an inch thickness to the wall. Electrical service is run in thin wall, surface mount conduit. I have a barn metal ceiling in the shop and that has 16" of blown in cellulose insulation. As I said in another post, even with the high winds and single digit temperatures we've been having the shop has been very economical to heat. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
The big downside to in-floor heating is that you have to heat the hanger all
the time. With radiant heating you heat it when you need to and keep it at 33F the rest of the time. Mike MU-2 "john smith" wrote in message ... In article , "Gig 601XL Builder" wrDOTgiaconaATcox.net wrote: www.peoamerica.net/N601WR Too bad the floor is already poured. The best hangar heating is via a heated floor. You plumb it before you pour and connect it to a boiler. Makes it much more comfortable on your feet and legs while working on the plane during the cold months and keeps the heat out of the rafters. |
| Days as a hanger rat | Jack Allison | Owning | 33 | May 12th 05 04:01 AM |
| Hanger and gliders hit by storm. | [email protected] | Soaring | 6 | February 1st 05 02:44 AM |
| Yankee Air Force hanger has burned. | GraveRobber | Restoration | 0 | October 10th 04 03:52 AM |
| Hanger space S. Florida | smf | Owning | 2 | September 13th 04 06:15 AM |
| objects near hanger doors at Groom Lake | miso | Military Aviation | 4 | May 23rd 04 09:59 PM |
