Dave Butler wrote:
Jay Somerset wrote: Taking a different track, so i changed the thread/subject line... If you are on a composite flight plan (VFR, then IFR) who is responsible for closing the VFR portion of the plan? If the VFR plan is not closed (with FSS if a true VFR plan) then SAR will be initiated if they cannot get hold of you within an hour or two. How does this work with a composite flight plan? The pilot is responsible for contacting FSS and closing the VFR portion of the flight plan. And along the same vein, I was reading the AIM the other night and it said that an FSS should also be contacted to get the IFR clearance at the appropriate point. I believe the OP said he requested his IFR clearance from approach control, which is contrary to the procedure documented in the AIM. It doesn't say that another facility CAN'T give you the IFR clearance for the IFR part of the composite flight plan, but it specifically says to contact FSS for this. I assume that is written there for a reason. Maybe if the OP has followed the recommended procedure he would have had better luck. Matt |
"Matthew S. Whiting" wrote in message ... And along the same vein, I was reading the AIM the other night and it said that an FSS should also be contacted to get the IFR clearance at the appropriate point. I believe the OP said he requested his IFR clearance from approach control, which is contrary to the procedure documented in the AIM. It doesn't say that another facility CAN'T give you the IFR clearance for the IFR part of the composite flight plan, but it specifically says to contact FSS for this. I assume that is written there for a reason. Maybe if the OP has followed the recommended procedure he would have had better luck. If you call FSS for the clearance, FSS then has to call ATC. If you call ATC directly you skip the middle man. |
Steven P. McNicoll ) wrote:
If you call FSS for the clearance, FSS then has to call ATC. If you call ATC directly you skip the middle man. If only all controllers provided this exemplary service. One time last summer, I overheard two different GA aircraft within a few minutes of each other attempt to pick up their IFR clearances while in the air inside Philadelphia Approach's airspace. The controller, after hearing the second request, asked what is going on here, then proceeded to lecture all listening that IFR aircraft should be contacting flight service for clearances when in the air. The controller then answered the second aircraft and told him to do just that, then returned to servicing all other aircraft under his control. -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
The answer to your question as well as to the general question of who is
responsible for closing any flight plan is: The pilot-in-command Though generally speaking when you land at a towered airport they usually close your IFR flight plan for you,,, but it is more a courtesy rather than something they are 'responsible' for,,, so-to-speak. In the end it is the responsibility of the PIC -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
"Cecil E. Chapman" wrote in message . com... Though generally speaking when you land at a towered airport they usually close your IFR flight plan for you,,, but it is more a courtesy rather than something they are 'responsible' for,,, so-to-speak. In the end it is the responsibility of the PIC When you land at a towered field in the US your IFR flight plan is closed automatically. ATC takes no action to close it, it's closed simply because you've arrived at your clearance limit. Action is taken only if you don't arrive - a search is started. |
??? So, the process is 'automated' in some way? What ATC and/or pilot
action toggles the action to closure? -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - "Steven P. McNicoll" wrote in message ink.net... "Cecil E. Chapman" wrote in message . com... Though generally speaking when you land at a towered airport they usually close your IFR flight plan for you,,, but it is more a courtesy rather than something they are 'responsible' for,,, so-to-speak. In the end it is the responsibility of the PIC When you land at a towered field in the US your IFR flight plan is closed automatically. ATC takes no action to close it, it's closed simply because you've arrived at your clearance limit. Action is taken only if you don't arrive - a search is started. |
Cecil E. Chapman wrote: ??? So, the process is 'automated' in some way? What ATC and/or pilot action toggles the action to closure? None. No action necessary. |
"Cecil E. Chapman" wrote in message . com... ??? So, the process is 'automated' in some way? It's not "automated", it's "automatic". What ATC and/or pilot action toggles the action to closure? Pilot: Lands. ATC: Observes pilot land. That's it. Flight plan is now closed. |
Steven P. McNicoll wrote:
"Cecil E. Chapman" wrote in message . com... Though generally speaking when you land at a towered airport they usually close your IFR flight plan for you,,, but it is more a courtesy rather than something they are 'responsible' for,,, so-to-speak. In the end it is the responsibility of the PIC When you land at a towered field in the US your IFR flight plan is closed automatically. ATC takes no action to close it, it's closed simply because you've arrived at your clearance limit. Action is taken only if you don't arrive - a search is started. Doesn't ATC have to take SOME action to confirm your arrival? If not, how is that different from a landing at a non-towered airport on an IFR flight plan? How does the computer know the difference? Matt |
"Matthew S. Whiting" wrote in message ... Doesn't ATC have to take SOME action to confirm your arrival? Only if you consider watching the aircraft land to be some action. If not, how is that different from a landing at a non-towered airport on an IFR flight plan? At a non-towered airport ATC is not able to observe the pilot land, so the pilot must tell ATC he's landed or cancel IFR. How does the computer know the difference? The computer doesn't need to know, there's no computer processing beyond the destination airport. If a pilot cancels IFR while enroute the controller receiving the cancellation will enter a "remove strips" message, every ATC position downline that has received a strip will receive that message. If you're the last controller, tower controller at a controlled field or the controller providing approach control services for an untowered field, there's nobody to pass that message to. |
| Thread Tools | |
| Display Modes | |
| "cleared to ... when direct ..." | John Harper | Instrument Flight Rules | 21 | February 11th 04 05:00 PM |
| Practical IFR Question (for centre controllers) | David Megginson | Instrument Flight Rules | 10 | December 5th 03 12:26 AM |
| AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 09:26 PM |
| Follow up Alright, All You Dashing, Swaggering Bush Pilots | wmbjk | Home Built | 135 | September 8th 03 07:09 AM |
| Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 05:02 AM |
