Why is wind directon expressed as "FROM"?
Old January 6th 06, 11:45 AM posted to rec.aviation.piloting
Default Why is wind directon expressed as "FROM"?
On Thu, 05 Jan 2006 17:49:51 GMT, Jose
One could easily design a vane that worked the other way.
But they didn't. All weather vanes point into the wind. So those New
Hampshire farmers must have been onto something, since their cast-iron
horses, carriages, sailboats, kiddies etc all point in the direction I
should land the Cub.
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old January 6th 06, 03:25 PM posted to rec.aviation.piloting
Then why don't airports use weathervanes instead of windsocks?
Old January 6th 06, 03:46 PM posted to rec.aviation.piloting
Wouldn't a wind tee be considered a weathervane?
Peter
Old January 6th 06, 03:53 PM posted to rec.aviation.piloting
"JohnH" wrote in message
Windsocks are a bit more useful to a pilot, they provide an indication of
wind direction and speed. Weathervanes provide only an indication of wind
direction.
Old January 7th 06, 02:11 AM posted to rec.aviation.piloting
Some do.
Geoff
the sea hawk at wow way d0t com
Spell checking is left as an excercise for the reader.
You disturbed a large number of electrons when you posted
"Then why don't airports use weathervanes instead of windsocks? "
but we think you know weathervanes are telling us where the last wind
came from, and windsocks give us some information as to how hard it's
blowing at the moment.
Flags work well at doing that, too but come to think of it, I'd rather
have a windsock on the flagstick of my golfcourse than a flag.
(and several more on high poles about a 100 yards out, although that
would remove still another excuse for for bad golf shots.)
Old January 5th 06, 07:25 PM posted to rec.aviation.piloting
Larry Dighera wrote:
On Thu, 5 Jan 2006 11:51:58 -0500, "JohnH"
wrote in ::
Why is that?
The convention is probably a result of the way a weather vane works;
the arrowhead points into the wind, so a compass rose placed under it
indicates the direction of the wind's origin.
I'm pretty sure that is confusing cause and effect. I suspect that the
explanation is the one others have given about the source of the wind
being relevant to weather. Weather vanes could easily have been built
with no "tailfeathers" and a big arrowhead if the convention had been
the other way.
Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently.
Old January 5th 06, 11:15 PM posted to rec.aviation.piloting
I suspect that it comes from the days of sailing ships. All of your course
decisions are based on the direction of the wind. Tacking, running,
reaching, etc. are all referred to the current wind direction. I'm not sure
I fully understand why FROM was chosen as the convention, but when you're
sailing, you tend to keep the wind in your face unless you're running.
Bob (Chief Pilot, White Knuckle Airways)
"Larry Dighera" wrote in message
wrote in ::
Why is that?
Old January 6th 06, 12:32 AM posted to rec.aviation.piloting
Even more so than today, the old fashioned sailing ships never had the wind
in their face. I sail a J/24, which is a fairly modern design racing boat.
With everything set up right, new sails, and flat water, I can get within
about 35 degrees of the wind. The old square riggers were doing well if
they could get any closer than 60.
This, BTW, is why a toilet on a boat is called the head. On a vessel that
spends most of its time with the wind behind it, you put the toilets up on
the very front (i.e. the head of the boat) for odor control. Even sailors
know not to **** into the wind. It also happens to be the part of the boat
that gets the most water sprayed on it, which is wet and cold for the
users, but does make the apparatus somewhat self-cleaning.
Old January 7th 06, 11:43 PM posted to rec.aviation.piloting
sure I fully understand why FROM was chosen as the convention, but when
you're sailing, you tend to keep the wind in your face unless you're
running.
I'd go back even further in time. Even before the age of ships, the
direction the wind comes FROM was the most interesting, as looking in that
direction could tell how the weather will change (well, fronts are
different, but they are a later invention). Later, when man learned to build
boats, looking INTO the wind was (and is) the best way to see how hard it
blows at sea, i.e. is it safe to leave the shore. It's easy to imagine that
the wind god is in that direction - better keep attention to him!
Just my $0.02 ;-)
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Headwinds, always Paul kgyy Piloting 36 June 9th 05 02:05 AM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 05:33 AM
