Thats a tough call.....
Our 172 was purchased from a training school that put 2500 hrs on it in 4 years. It started making metal at 2792 hrs. (aft cam lobe) Was using a liter of oil/12 hrs, comps 72 - 75, good oil pressure, pulled great.. Replaced engine, could not tell the difference in oprn or performance.. At the flight school, if they could see, they flew.. the aircraft was very agressively maintained. Cosmetically, it was rough, but mechanically, no concerns, Annuals.... cowl fasteners and a manifold flange leaking (exhaust) were the biggies. Squawked one time for a noisy wheel bearing. Dave On Fri, 13 Jan 2006 17:17:09 -0500, "pgbnh" wrote: Maybe a related question. How to make the decision to actually DO an overhaul/replacement? In some cases it is exceedingly clear - lots of metal in oil, oil usage, cylinders blown, etc. But what about the high time engine that is otherwise working just fine? Compression good. Oil clean. not burning excessive oil. Due to a prop strike, my lycoming IO360 was torn down at 1300 hours. Since it was in pieces, we did more than a 'normal' sudden stoppage inspection. Bearings, cam recondition, rings, etc etc. Engine is now at 2400 hours (2000 tbo). Runs fine. No change in oil consumption or fuel consumption. Good compression. Do we wait for bad stuff to happen, or be proactive. Frankly, I am concerned about taking an engine that 'ain't broke' and either overhauling it or replacing it and ending up with problems when today I don't have any. any advice on how to know when 'It's time'? "Andrew Gideon" wrote in message gonline.com... I'm the "plane lt." for a skyhawk, based in northern NJ (KCDW), that's getting ready for its engine overhaul. What should we do with it? I'm curious what others have done, and how its worked for them. I've been doing some of reading of articles, but it's raised more questions than answers. Questions I do need, but I'd also like some of those answers. Questions bouncing around head include: Should we get our engine overhauled, or swap it for a previously overhauled engine? If we do overhaul, is "to new specifications" the only reasonable choice? Is there a difference of significance between "factory rebuilt" (zero-timed) and "overhauled to 'new specifications'"? Any recommendations for shops for the overhaul (or shops to avoid)? Finally, I'm confused about the process. Does one shop remove/replace and another actually do the engine work? Or does the plane need to be flown to the shop that either does the overhaul or has the engine to swap? For others asking similar questions, here's some of what I've read: http://www.mattituck.com/new/articles/ohterms.htm http://www.avweb.com/news/maint/185049-1.html http://www.aviation-consumer.com/arc...rt/4718-1.html I've also looked through the forums on cessna.org, but I cannot relocate what I'd previously found there. Thanks... Andrew |
Compression good. Oil clean. not burning excessive oil. My opinion is that if you have a properly working engine, no need to overhaul it. There is some risk in flying it, but there is risk in overhauling. The breakin period is risky time to fly. Spending all that money is risky. There are risks everywhere. I have an engine that is 2200 hours since new, never overhauled or rebuilt. I am monitoring its oil filter and doing oil analysis at every oil change. I think the risk/reward tilts toward just keep flying it until I start using oil or metal wear shows up or the compressions go down. My engine just keeps on ticking.......why risk replacing it? |
| Lycoming 0-360 A4M Engine overhaul in Ohio | Roy Page | Owning | 9 | January 13th 05 10:31 PM |
| Lycoming 0-360 factory overhaul core charges - Does Air Powertell the truth ? | Mike Spera | Owning | 6 | December 13th 04 02:13 AM |
| Lycoming 0-360 factory overhaul core charges - Does Air Power tell the truth ? | nuke | Owning | 4 | December 11th 04 01:59 PM |
| Major Overhaul | Jim Weir | Owning | 10 | June 8th 04 06:12 PM |
| lycoming major overhaul | Marty from Sunny Florida | Owning | 14 | June 7th 04 06:57 PM |
