Rob Turk wrote:
"Harvey Spencer" wrote in message news:%0%xf.6967$CV.2345@dukeread03... I know that the XV-36 light offered by XeVision at http://www.aerovisions.com/pic/XV-36-SL-new.jpg will meet the FAA requirements for brightness and light pattern. It uses the D1S bulb xenon arc bulb which is better than the D2S commonly used in automobiles since it has the starting ballast integrated into the base of the bulb. [SNIP] These lights are not cheap, about $550 through places like Aircraft Spruce, but you get what you pay for. I think I saw a xenon arc light offered by Chief Aircraft for about $350 but found out that the lens and reflector is plastic. Thanks for all the details, Harvey. I had looked at XeVision but found the price kinda steep. The Hella ones sell for about $350 each and are a bit smaller. Unfortunately they are usually offered in pairs ($699) for car owners. Rob How about something like http://www.1000bulbs.com/category.php?category=391 There are landing light kits for homebuilts already available using this style bulb. Various angles of coverage available, if you do a little looking. It doesn't run cold like the xenon bulbs & it does have a filament, but the .01X cost factor would have a strong influence on my decision..... Charlie |
"Charlie" wrote How about something like http://www.1000bulbs.com/category.php?category=391 There are landing light kits for homebuilts already available using this style bulb. Various angles of coverage available, if you do a little looking. I wouldn't want to use something like that, for a landing light. Recognition light, perhaps the 75 watt would be OK. The bulbs you cite are used in low voltage landscaping applications. Real landing lights are 250 watts, up to 600 watts, and some, more. The beauty about the HID lights are multi-fold. No vibration breakage, so a very long life. Low heat output. Low current draw, for the amount of light produced. The output light frequency is such that objects appear much brighter, and whiter; more like real daylight. Unfortunately, they cost more. Your investment pays off in peace of mind, that the light will work when you turn it on, and that you can better see what you are trying to look at. :Less (or almost no) maintenance is always a "good thing" in my book. -- Jim in NC |
Morgans wrote:
"Charlie" wrote How about something like http://www.1000bulbs.com/category.php?category=391 There are landing light kits for homebuilts already available using this style bulb. Various angles of coverage available, if you do a little looking. I wouldn't want to use something like that, for a landing light. Recognition light, perhaps the 75 watt would be OK. The bulbs you cite are used in low voltage landscaping applications. Real landing lights are 250 watts, up to 600 watts, and some, more. The beauty about the HID lights are multi-fold. No vibration breakage, so a very long life. Low heat output. Low current draw, for the amount of light produced. The output light frequency is such that objects appear much brighter, and whiter; more like real daylight. Unfortunately, they cost more. Your investment pays off in peace of mind, that the light will work when you turn it on, and that you can better see what you are trying to look at. :Less (or almost no) maintenance is always a "good thing" in my book. I'm sure that airliners use 600W+ lamps, but we aren't building airliners. Real normal *traditional incandescant* landing lights are 250 watts. Sometimes. Halogens are typically twice as efficient as traditional incandescents. If the only criteria is wattage, why suggest using 35W HID lamps? The bulbs cited are used in uncountable applications, including landing lights. 'You pay your money, & you make your choice.' |
The wattage listed in only an indicator of the current used. HID doesn't
use much current but the light output is awesome. "Morgans" wrote in message news ![]() "Charlie" wrote How about something like http://www.1000bulbs.com/category.php?category=391 There are landing light kits for homebuilts already available using this style bulb. Various angles of coverage available, if you do a little looking. I wouldn't want to use something like that, for a landing light. Recognition light, perhaps the 75 watt would be OK. The bulbs you cite are used in low voltage landscaping applications. Real landing lights are 250 watts, up to 600 watts, and some, more. The beauty about the HID lights are multi-fold. No vibration breakage, so a very long life. Low heat output. Low current draw, for the amount of light produced. The output light frequency is such that objects appear much brighter, and whiter; more like real daylight. Unfortunately, they cost more. Your investment pays off in peace of mind, that the light will work when you turn it on, and that you can better see what you are trying to look at. :Less (or almost no) maintenance is always a "good thing" in my book. -- Jim in NC |
On Fri, 13 Jan 2006 17:15:29 +0100, "Rob Turk"
wrote: We're looking at installing landing lights on our Rans S6S. The ones offered by Aircraft Spruce are a bit big, about 5" diameter. I'm trying to find something a bit smaller but equally effective. Does anyone here know what (if any) requirements a landing light has, such as beam angle, width, brightness etc?? What are those White, or blue white lights that are showing up in cars now. Although they claim no glare, for older eyes the things are worse than meeting regular lights on bright. I'd think they'd make an excellent landing light in the proper housing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com The Hella Micro DE Xenon looks like a really interesting option. Less than 3" diameter, low power (35W) but very high light output and resilient to vibration. See: http://www.hella.com/produktion/Hell...o_DE_Xenon.jsp Anyone used this? Good or bad? Any alternatives that are equally small and effective? Thanks! Rob |
Rob Turk wrote:
We're looking at installing landing lights on our Rans S6S. The ones offered by Aircraft Spruce are a bit big, about 5" diameter. I'm trying to find something a bit smaller but equally effective. Does anyone here know what (if any) requirements a landing light has, such as beam angle, width, brightness etc?? The Hella Micro DE Xenon looks like a really interesting option. Less than 3" diameter, low power (35W) but very high light output and resilient to vibration. See: http://www.hella.com/produktion/Hell...o_DE_Xenon.jsp Anyone used this? Good or bad? Any alternatives that are equally small and effective? Thanks! Rob I got some Halogen driving lights from NAPA. They should work fine. I used a 50W Halogen light on my Piper and it was quite sufficient for landing. It provided about the same light as the 100w 4506 legal one. (notice I said sufficient .. not "legal". ;-) ) |
"Rob Turk" wrote in message news:AmQxf.3664$zc1.3603@amstwist00... We're looking at installing landing lights on our Rans S6S. The ones offered by Aircraft Spruce are a bit big, about 5" diameter. I'm trying to find something a bit smaller but equally effective. Does anyone here know what (if any) requirements a landing light has, such as beam angle, width, brightness etc?? Thanks everyone for the hints, tips and advice. We went ahead and ordered the Hella Micro DE Xenon, will let the group know how it works out. Rob |
| Landing Light SOP | kristoffer-m20j | Piloting | 94 | November 4th 05 04:36 AM |
| "bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 29th 04 12:04 AM |
| Slip to landing on PPG practical test | Roger Worden | Soaring | 56 | November 11th 04 10:38 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| Landing Gear Lights-Need Wiring Help | BG | Home Built | 2 | August 17th 03 12:21 AM |
