Headset: Unexpected safety bonus
Old January 16th 06, 07:44 PM posted to rec.aviation.owning
Default Headset: Unexpected safety bonus
On Mon, 16 Jan 2006 09:12:37 -0800, Bob Fry
Hey, could you tell our governor this trick? He needs to pass that
test too....
I'd need to tell it to his stunt double.
Anyway, I credit those wax earplugs, used with the plane speakers,
with extending my flying time-to-fatigue greatly. I mostly like
today's headsets even better because of the boom mike and yoke-mounted
PTT.
Don
Old January 16th 06, 10:13 PM posted to rec.aviation.owning
Jay Honeck wrote:
In addition to the ANR, I still use foam earplugs and then turn up the
radio. That makes it even clearer.
You put earplugs in your ears, and then turn up the volume?
Isn't that sorta like holding the brakes whilst flooring the accelerator?
What, exactly, are you trying to accomplish?
Ive done it too, Jay..
When I fly alone, and others arent there who dont have/wont use
earplugs.. I sometimes do that.
Most noise suppression occurs in lower frequencies, both with ANR and
the passive devices.
Most Radio audio is in the middle frequencies.. So in effect you
suppress LOTS of loud low freq engine noise and suppress minimal
voice-spectrum sound.
Dave
Old January 16th 06, 01:14 PM posted to rec.aviation.owning
Vaughn wrote:
If you find yourself saying "say again?" often, perhaps it is time to open
up the wallet and invest. There is no longer any valid reason to be flying
without ANR.
I have to agree. I've been using the Bose for almost a year now and not only are
they more comfortable to wear for longer periods of time (than brandX) but the
radio and interfcom communications is more readble at a lower volume level than
before.
You won't hear dead silence with ANR headsets, its just a different noise "pitch"
and at a slightly lower level than passive.... and the radio is clearer to understand.
Old January 16th 06, 04:39 PM posted to rec.aviation.owning
I sometimes fly an Aztec with a Bose headset. It makes a world of
difference with the ANR compared to a regular H10-13.4 David Clark.
The only fault I find with the Bose is the need to keep an extra 9 volt
battery handy. If you leave them on, the battery will run down. Not a
big deal to change out during flight. You can still hear ATC but you
will be getting the noise which would be normally filtered.
Old January 16th 06, 06:08 PM posted to rec.aviation.owning
The new Bose X uses two AAs and has an auto-shutoff feature. They went to that a
few years ago. If you have one of the earlier Bose X models that uses the 9v
battery, you can get a replacement battery box/control unit for an exorbitant fee.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 16th 06, 06:09 PM posted to rec.aviation.owning
I got a new Bose for Christmas. They now use two AA's and have an auto
shutoff feature. You can send your headset to Bose and have them put
that on yours if you want.
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 06:20 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
SSA to Safety Group at Convention: "Clear Off!" ? SoarPoint Soaring 11 February 13th 04 05:48 PM
