Military Airfield Procedures..
Old February 26th 06, 03:14 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Military Airfield Procedures..
David Cartwright wrote:
One has to wonder why they didn't put it down for you (the fact that they
said it was up suggests it was retractable). As for what would have
happened - well, it would almost certainly have damaged your landing gear.
The retraction mechanism could have been disabled or inoperative. When
Ellington (KEFD) was having their tower refurbished, the tower did not
have control over retractible mechanisms and relied on airport
operations personnel to manual actuate and retract the barrier as needed
(using a guy in a truck).
If a small or light plane was cleared to land just prior to or just
after military fighter type aircraft, the cable was likely to be up and
the tower would announce such to the inbound aircraft.
Dave
Old February 26th 06, 03:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
"David Cartwright" wrote in message
"Dan" wrote in message
Last night I took a quick trip to KYUM. On approach, the controller
mentioned that the "arresting gear was up" on the runway
Does anyone know what would have happened if I had landed on it? This
type of thing seems quite dangerous to GA aircraft.
I think this is holdover from previous arresting gear terminology. There
are still web type devices that are actually "up" and then retracted when
not needed. Most cables are "strung" across the runway. At most fields,
changing a cable configuration is a manual process that takes a couple of
guys about 20 minutes or so to accomplish. Not something they will do for a
GA arrival.
Old February 26th 06, 08:18 PM posted to rec.aviation.piloting,rec.aviation.ifr
The cable was probably manually operated only. Normal configuration for
manual cables is to have the approach end cable removed, and the
departure end cable strung across the runway. That way, military jets
that have brake failure or abort takeoff can snag it and come to a stop.
If the wind shifts and requires a runway change, then the tower has to
direct a crew out there to change the cable configuration. They may not
have had enough time to do that before you came in, or you may have been
operating "opposite direction" in able to get the ILS approach. There's
a good article about cables at the following link, it even mentions an
incident where an MD-88 snagged a cable during takeoff roll and came to
a stop.
http://www.boeing.com/assocproducts/...ingsystems.pdf
I'm not sure the E-28 cables at Yuma are remotely retractable.
Incidentally, even if the arresting gear was down, you should always try not
to land before it (assuming there's plenty of runway the other side - which
there should be). I did part of my PPL training at RAF Coltishall, which has
arrester gear that sits in a little channel across the runway when it's
down. If you roll over the channel, you get a hell of a bump.
David C
Ahh, RAF Coltishall. I spent 2 tours over in East Anglia. One at
Ben****ers/Woodbridge, the other at Mildenhall. It's amazing how many
airfields they squeezed into such a small area.
John
Old February 28th 06, 01:26 AM posted to rec.aviation.piloting,rec.aviation.ifr
"JPH" wrote in message
news9nMf.173258$WH.118923@dukeread01...
Well, there are fewer now. Benwaters/Woodbridge closed about 6-7 yrs ago.
Coltishall ceases to be operational on April 1st and will close towards the
end of the year when our last General Aviation ac will also depart. It's all
sad ;-(
When landing at RAF Stations the question asked is "Are you familiar with
the field", referring to the RHAG (rotary hydraulic arresting gear). I just
say "negative, but have the RHAG in site".
Gus Cabre
RAF Coltishall
Old February 28th 06, 05:39 AM posted to rec.aviation.piloting,rec.aviation.ifr
just
So, how about a quick description of RHAG?
Jim in NC
Old March 4th 06, 04:27 AM posted to rec.aviation.piloting
David and others
Before Air Force birds had tail hooks we had a system where a cable
was raised to two/three feet in air. When bird ran into it the cable
caught on nose gear and the chain lengths attached to ends of cable
drug you to a stop.
This arresting gear was normally down and could be raised and lowered
by the tower when required.
This may have been the system in this case. It's been so long since I
retired not sure if they still use it?
The tail hook system can be used at either end of runway so you can
get two chances to use it in an emergency. Approach end and far end.
Any current jocks care to comment on to days systems besides the tail
hook system?
Oh yes, in winter the chains would freeze to ground and had to be
broken loose every day or they would jerk the tail hook off the bird.
On GCA. I made 999 to one ILS. Also made a full zero zero landing on
GCA. Great system.
Big John
On Sun, 26 Feb 2006 11:08:20 +0000 (UTC), "David Cartwright"
roups.com...
David C
Old March 4th 06, 04:35 AM posted to rec.aviation.piloting
That was the system that was installed at SPI, when the
guard flew F84Fs. When the tower cleared them to land they
always said "The barrier INDICATES UP" which covered the
tower in case the barrier was down.
"Big John" wrote in message
| David and others
where a cable
the cable
of cable
| drug you to a stop.
and lowered
long since I
so you can
and far end.
besides the tail
| hook system?
had to be
off the bird.
landing on
| GCA. Great system.
| Big John
Cartwright"
roups.com...
the controller
runway
landed on it? This
(the fact that they
would have
your landing gear.
other side - which
runway when it's
bump.
| David C
Old February 26th 06, 03:50 PM posted to rec.aviation.piloting,rec.aviation.ifr
mentioned that the "arresting gear was up" on the runway I was to land
on. Being unfamiliar with arresting gear and flying an Archer, I asked
the controller specifically what that meant. He indicated that it
consisted of a cable stretched across the runway about 6 inches high.
Since it seemed that this could seriously damage an Archer, I made sure
to land beyond it. (although it's exact position was difficult to
determine at night.)
IT IS!
You could easily find yourself without your landing gear if you land before
the cable.
On another note, as I was inbound on the ILS, the tower handed me over
to someone else for a "monitored" approach. This controller called my
position on the ILS and advised of any deviations. There was no
parallel ILS in progress. Is this just the way things are done at a
military field?
Yes.
Old February 27th 06, 05:36 PM posted to rec.aviation.piloting,rec.aviation.ifr
"John Doe" wrote in message
news:2fjMf.42118$Dh.501@dukeread04...
I've done it in a C-150, at NAS Millington, TN, with a flying club
aircraft. I was unfamiliar, simulating a dead stick with an Instructor, when
we touched down before the last wire. We rolled right over it. No damage.
When I saw we were going to hit it, I held the nosegear well clear, and hit
it with the mains. We were probably still doing about 30kts, and had full
flaps, so there was some lift being generated. I am a little amazed the
cable didn't pop up and strike the tiedown ring on the tail cone which must
have been a foot off the ground or so. Of course the cable is pretty heavy,
and I doubt the 150 moved it much.
The system they used to have installed at Klamath Falls,(Kingsley
Field), had the same wire and donut scheme, but it was connected to what
looked like anchor chain on both sides of the runway. One link was
positioned right next to the prior link, so the chain was very "slack". When
you caught the wire, you pulled one link on each side for about a foot, then
picked up the next link for about a foot. Before long you were dragging many
tons of iron down the runway. I have no doubt that it would stop almost
anything.
Al
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
07 Feb 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 February 7th 06 02:28 AM
30 Jan 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 31st 06 04:21 AM
20 Nov 2005 - Today's Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 November 20th 05 10:43 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
