Boosting ICOM IC-A23 Handheld Aviation Radio
Old June 5th 04, 11:25 PM
CHANGE USERNAME TO westes
Default Boosting ICOM IC-A23 Handheld Aviation Radio
I recently purchased an ICOM IC-A23 radio, and I'm disappointed in its
pickup. It gets the weather channels fine, but the reception for both the
airport and airplane radios is poor. Aside from standing next to the
airport or being right under the airplane, do I have any options for
improving gain and the quality of reception? Is there some third party
antenna that I could attach to this radio? It looks like it takes a
standard BNC type connector for the antenna that comes with it.
Will
westes AT earthbroadcast.com
Old June 5th 04, 11:59 PM
zatatime
On Sat, 5 Jun 2004 14:25:57 -0700, "CHANGE USERNAME TO westes"
My radio guy swapped out a loran antenna for a VHF antenna when I had
some radio work done. He ran a wire up to the cockpit and put it in
the map pocket. If I ever need it he's told me it will work almost as
well as a regular radio with that set up. Haven't tried it out yet,
but I do trust his judgement.
HTH
z
Old June 6th 04, 01:00 AM
Bob Gardner
It's not just ICOM. The rubber ducky antennas that come with the handheld
units are almost, but not ntirely, useless. Getting a good signal in or out
of a metal enclosure is tough...you have to hold the unit near a window and
keep it vertical for best results.
If you are a renter and can't go for an installed antenna, talk to your
local avionics shop about getting a better antenna.
Bob Gardner
"CHANGE USERNAME TO westes" wrote in
message ...
Will
Old June 6th 04, 03:26 AM
Michelle P
An external antenna is essential. I had an occasion to use it airborne
after an electrical failure in IMC. It had a range of 20-30 miles at
5000 ft. I was able to talk to ATC al the way to the airport. My
external antenna is on the belly sine I figured I would be transmitting
down to the radio antennae's.
Michelle
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old June 6th 04, 03:29 AM
Rod Madsen
All very true, but I think the original poster was referring to reception on
the ground (next to the airport or under the plane), not inside a cockpit.
Rod
"Bob Gardner" wrote in message
out
and
Bob Gardner
message ...
party
Will
Old June 6th 04, 03:54 AM
EDR
In article , CHANGE USERNAME TO
If you are on the ground, outside the airplane, you can purchase a
metal, 5/8 wave, telescoping antenna to replace the standard rubber
duckie.
Old June 6th 04, 04:46 AM
Ray Andraka
Don't forget, VHF is line of sight. On the ground, you won't get much range to
another ground station regardless of how good your antenna is.
duckie.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old June 6th 04, 12:11 PM
Several years ago, I went to a ham radio shop and had them cut an roof mount
antenna for my ICOM 21. I believe I had them cut it for 128 MHz and 3/4 wave
length. I got awesome performance from my car. I could hear the ATIS and talk
with ground control five miles from the airport on the freeway. I could drive
along I-5 on the coast and talk with LA Center's RCO on Catalina Island.
Old June 6th 04, 12:12 PM
duckie.
Right, I think my antenna is 5/8 wave. Makes it awesome with a roof mount.
Old June 6th 04, 12:13 PM
five miles is pretty good. And, since ZLA Catalina's RCO is atop a mountain on the
island, 40 miles works with ease.
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Barnyard BOb - Home Built 5 September 8th 04 08:27 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 12:55 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 11:05 PM
