GPS altitude vs altimeter altitude
Old April 17th 06, 03:47 AM posted to rec.aviation.piloting
Default GPS altitude vs altimeter altitude
Sounds like a really cool plane. I've always thought doing something
like this would be neat. What speed will it cruise at?
Old April 17th 06, 04:21 AM posted to rec.aviation.piloting
I suggest that you contact the FAA before you launch a robot
airplane and kill somebody.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Chris W" wrote in message
news:TKB0g.933$9c6.344@dukeread11...
| It seems as though those who actually read what I was
really asking
| didn't think it was important to find or know the answer
so let me get a
| little more specific. I am going to launch a remote
control airplane
| that has an autopilot. The autopilot has an altitude hold
function that
| is based on barometric pressure sensor. I will also have
a GPS used for
| guidance. The data from that GPS will be transmitted
using APRS on
| 144.39 mhz to any amateur station listening. Once the
autopilot is
| turned on it will hold the pressure altitude it is at, so
as it flies
| along it's route (maybe as many as a few hundred miles)
and the
| barometric pressure changes the plane will climb and
descend to maintain
| the same pressure altitude. However the only data I will
be getting
| back is the GPS altitude. I need a way to do a reality
check so if I
| see the plane is descending or climbing I will know it is
because of
| changes in the barometric pressure and not the something
that has gone
| wrong. The plan is to get the latest METAR data from the
closest
| observation point to the current position of the plane and
then do the
| math compared to what it was where and when it launched so
I will know
| about what the GPS altitude should be reading as that is
all I will be
| able to see. For those who want to know why I don't just
have it
| transmit the pressure altitude back, I have four good
reasons; cost,
| weight, size, complexity. My first flights will be only
20 miles or
| so. For safety I will be sure it steers clear of any
class B, C, and D
| air space. I'm not sure what pressure altitude I will
have it fly at
| .... probably somewhere between 1500' and 6000' AGL
depending on the
| distance for it to cover.
| Chris W
| KE5GIX
| Gift Giving Made Easy
| Get the gifts you want &
| give the gifts they want
| One stop wish list for any gift,
| from anywhere, for any occasion!
| http://thewishzone.com
Old April 17th 06, 04:31 AM posted to rec.aviation.piloting
I do hope this UAV flight has been cleared with the local aviation
authorities, or is contained within a "restricted" airspace to keep other
VFR and IFR aircraft safe.
BT
My first flights will be only 20 miles or so. For safety I will be sure it
steers clear of any class B, C, and D air space. I'm not sure what
pressure altitude I will have it fly at .... probably somewhere between
1500' and 6000' AGL depending on the distance for it to cover.
Old April 17th 06, 05:19 AM posted to rec.aviation.piloting
I've got to agree with this one.
To the OP: When an RC airplane leaves your sight line, it is now a UAV, and
under another set of rules.
This is a rather hot topic, and in the news, as of late. Don't be the one
that gets used as an example. It could cost you a bunch of money, jail
time, or a lifetime of regret. (over the people that your plane killed)
Most likely, nothing bad would happen. Is that something you want to
gamble your like on? Is it worth it?
Jim in NC
Old April 17th 06, 07:09 AM posted to rec.aviation.piloting
I'm guessing that you either live east of the Mississippi or on/near the
west coast, and not in Oklahoma. RC airplanes can and have killed
people. However, generally this happens from a much larger plane than I
plan on using, and the chances of someone getting injured is reduced
significantly when the engine isn't running. With this in mind these
are the situations I foresee potential for serious injury. The only way
I see this coming in contact with someone on the ground is if the engine
is not running. Therefore, the biggest danger to someone or something
on the ground is gone. So for the plane to impact a person while the
engine was running it would have to be an impact with a real plane. If
the difference in heading of the real plane and the model were between
greater than 0 and less than 90, then the prop wold be history before it
penetrated the cabin and would the now dead engine would loose most of
it's energy before in impacted someone in the plane, most of the rest of
the plane would never enter the cabin. If the difference between the
heading of the real plane and the model were between 90 and 180, that's
big a problem. I'm not sure how feasible it would be to have some kind
of sensor to detect such an impending collision and do something about
it. Other than avoiding busy airspace, I'm not sure what to do about
it. Keep in mind that the class C around KOKC which is with in 3 miles
of my house and I plan on staying away from, really isn't very busy at
all. There is still the possibility that something goes wrong with the
autopilot and sends the plane down the wrong side of the highway at 3
feet off the ground. To virtually eliminate this type of situation, I
plan on having a completely independent system that will kill the engine
and put the plane in a slow flight configuration should the altitude
drop below a given amount. Granted that could also fail but the chances
of both the autopilot and that system failing is very remote, that "fail
safe" system would be pretty small and light and could be made redundant
and possibly include a the deployment of a parachute. All this said I
am open to other ideas to make it safer.
Chris W
KE5GIX
Old April 17th 06, 07:42 AM posted to rec.aviation.piloting
What is the purpose of the project? Why couldn't it be done in a way
where the model remains within sight at all times - say by flying a
pre-established figure-8 course or something similar, and having a
manual override capability if it's observed to stray from the planned
course? Your current plan certainly appears to violate the model
airplane safety guidelines which state that "10. The operator of a
radio-controlled model aircraft
shall control it during the entire flight, maintaining visual contact
without enhancement
other than by corrective lenses that are prescribed for the pilot. No
model aircraft shall be
equipped with devices which allow it to be flown to a selected location
which is beyond
the visual range of the pilot."
http://www.modelaircraft.org/PDF-files/105.PDF
Old April 17th 06, 08:45 AM posted to rec.aviation.piloting
I lived in Tulsa and OKC and have now been in Kansas over 25
years. Your proposed altitudes are above the MEA on
airways. Done properly, with reserved airspace [you can get
approval to use the MOAs] what you want to do is safe. But
if you just want to launch and depend on luck to avoid
killing somebody you're being reckless.
A quick Google returned this...
Drone aircraft may prowl US skies | CNET News.com Drone
aircraft may prowl US skies | Can unmanned aerial vehicles
doing ... the FAA says it's created a UAV "program office"
to come up with new rules of the ...
news.com.com/Drone+aircraft+may+prowl+U.
S.+skies/2100-11746_3-6055658.html - 54k - Cached - Similar
pages
Unmanned Aerial Vehicles (UAVs) and the National Airspace
System This process has aided the FAA, other government
agencies, and the UAV manufacturers ... except for those
flown under the AMA Experimental Aircraft Rules; ...
www.house.gov/transportation/
aviation/03-29-06/03-29-06memo.html - 16k - Cached - Similar
pages
AOPA Online - Regulatory Brief -- Unmanned Aircraft Systems
Unmanned aircraft (UA) operate without an on-board pilot or
crew. ... The FAA is in the process of drafting rules that
establish regulatory guidance for UAS ...
www.aopa.org/whatsnew/regulatory/unmanned.html - 29k -
Cached - Similar pages
Use of Pilotless Planes May Be on the Rise Last year, the
FAA allowed two unmanned aircraft to be tested for
commercial use. ... The Fine Print: WPNI Rules for Posting
Content | Privacy Policy ...
www.washingtonpost.com/wp-dyn/
content/article/2006/03/29/AR2006032901814.html - Similar
pages
Federal Aviation Administration - Unmanned Aerial Vehicles
(UAVs) Unmanned Aerial Vehicles (UAVs) – sometimes called
“unmanned aircraft systems,” ... The FAA’s main concern
about UAV operations in civil airspace is safety. ...
www.faa.gov/news/news_story.cfm?type=fact_
sheet&year=2005&date=092005 - 8k - Cached - Similar pages
Section 5. Potential Flight Hazards 7-5-1. Accident Cause
Factors ... However, some time may pass before the FAA is
notified of these outages, ... 7-5-5. Unmanned Aircraft. a.
Unmanned aircraft (UA), commonly referred to as ...
www.faa.gov/ATpubs/AIM/Chap7/aim0705.html - 57k -
[ More results from www.faa.gov ]
I see on your website that your name is Woodhouse and you
sell wishes. Does your planned UAV that will fly up to
6,000 feet for many miles [you said you early test would be
20 miles] make up a "wish" for a customer?
Since you're in OKC, why not visit the Feds and learn what
is legal and how to do it safely?
James H. Macklin
ATP,CFI,A&P
some support
news:TpF0g.942$9c6.755@dukeread11...
or on/near the
have killed
larger plane than I
is reduced
mind these
The only way
if the engine
or something
person while the
real plane. If
were between
history before it
loose most of
of the rest of
between the
and 180, that's
have some kind
something about
to do about
with in 3 miles
very busy at
wrong with the
highway at 3
situation, I
kill the engine
the altitude
but the chances
remote, that "fail
made redundant
this said I
| Chris W
| KE5GIX
Old April 17th 06, 02:35 PM posted to rec.aviation.piloting
On Sun, 16 Apr 2006 19:58:19 -0500, Chris W wrote:
It seems as though those who actually read what I was really asking
didn't think it was important to find or know the answer so let me get a
little more specific. I am going to launch a remote control airplane
that has an autopilot. The autopilot has an altitude hold function that
is based on barometric pressure sensor. I will also have a GPS used for
guidance. The data from that GPS will be transmitted using APRS on
144.39 mhz to any amateur station listening. Once the autopilot is
turned on it will hold the pressure altitude it is at, so as it flies
along it's route (maybe as many as a few hundred miles) and the
barometric pressure changes the plane will climb and descend to maintain
the same pressure altitude. However the only data I will be getting
back is the GPS altitude. I need a way to do a reality check so if I
see the plane is descending or climbing I will know it is because of
changes in the barometric pressure and not the something that has gone
wrong. The plan is to get the latest METAR data from the closest
observation point to the current position of the plane and then do the
math compared to what it was where and when it launched so I will know
about what the GPS altitude should be reading as that is all I will be
able to see. For those who want to know why I don't just have it
transmit the pressure altitude back, I have four good reasons; cost,
weight, size, complexity. My first flights will be only 20 miles or
so. For safety I will be sure it steers clear of any class B, C, and D
air space. I'm not sure what pressure altitude I will have it fly at
.... probably somewhere between 1500' and 6000' AGL depending on the
I do not believe there is any formulaic method to convert from GPS altitude
to pressure altitude.
GPS altitude may be more akin to true altitude, with variations based on
the precise geographic location that could be placed into a table.
But if altitude is varying with pressure altitude, bearing in mind that the
pressure altitude sensor is also sensitive to temperature, I think you have
your work cut out for yourself.
Perhaps you could graph the METAR derived data and compare it with the GPS
derived altitude, and if the trend (direction of change) is the same, be
satisfied that the aircraft is performing as designed.
If you had the lookup table to derive geographic position vs GPS altitude
error; and also something like a SKEW-T plot to look at temperatures aloft;
and also the METAR data, perhaps you could develop something to convert
true altitude (from your corrected GPS output) to assumed pressure altitude
reading on your altimeter) and draw some conclusions that way.
It sounds like an interesting problem.
Old April 17th 06, 11:55 AM posted to rec.aviation.piloting
On Sun, 16 Apr 2006 14:37:53 -0500, Chris W wrote:
It is my understanding that even if a GPS is reading perfectly and your
standard altimeter is reading perfectly even on a standard day that the
2 values will not be the same
Mine generally read within 50-100 feet of one another. However, I
rarely fly above 3,500 feet. (Altimeter is 60 years old, assuming same
age as airplane.)
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
In Search of Lost Time: www.readingproust.com
Old April 17th 06, 11:58 AM posted to rec.aviation.piloting
Does your old Cub have a sensitive altimeter or just a
standard?
James H. Macklin
ATP,CFI,A&P
some support
"Cub Driver" usenet AT danford DOT net wrote in message
perfectly and your
However, I
assuming same
| age as airplane.)
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 08:35 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 01:39 AM
