Why is a standard hold right turns?
Old August 25th 04, 06:38 PM
Newps
Kevin Chandler wrote:
In a twin the thrust line is slightly to the right when climbing, just like
a single, which makes the plane yaw left, just like in a single. The left
engine in a twin is the "important" engine.
In most twins. However there are some that have no critical engine and
some that have both engines as critical.
Old August 25th 04, 11:14 PM
Kevin Chandler
I know that some planes have counter-rotating engines for the right side;
however, I never knew that planes existed with both engines critical. Are
you saying the counter rotating goes on the left and a normal engine on the
right? Is so, why???? What benefit would there be in that?
Just curious and learning something new everyday.
Kevin
Old August 26th 04, 02:00 AM
Mike Rapoport
What he is implying is that in some twins you have a major problem if you
lose either engine.
Mike
MU-2
"Kevin Chandler" wrote in message
Kevin
Old August 26th 04, 05:28 AM
Newps
Any engine that turns its prop outboard is a critical engine. The P38
is an example of an airplane that has both engines turning outboard.
They did this for better manuverability.
IFR hold short line at uncontrolled airports? Peter R. Instrument Flight Rules 30 June 9th 04 05:47 AM
Hold at VOR for 2v2 Doug Instrument Flight Rules 21 May 28th 04 12:42 AM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 04:19 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 05:21 PM
Need Hold Harmless Waver for Ultralight or Experimental Sale Larry Smith Home Built 9 August 19th 03 03:47 AM
