Fuel Prices and their Effect on Your Flying
Old May 1st 06, 03:19 PM posted to rec.aviation.owning
Default Fuel Prices and their Effect on Your Flying
Montblack wrote:
("Newps" wrote)
Or just buy a more efficient plane. I sold my 182 and got a Bonanza.
I'm burning a lot less gas, approx 40%, than when I had my 182.
What are the two engines?
Your normal cruise speeds between the two?
Curious? I wouldn't have thought that the case.
Most of my flying is the local $100 hamburger run. In the 182 with the
standard O-470R I usually ran top of the green, 23"/2450. That gave me
about 135-140 mph indicated and burned about 12.5-13. In the Bo with
the standard IO-520 I run 45% in the local area at 19"/2100 at 50 lean
of peak. That will give me 150 mph indicated and burn 8 gph, so
nowadays I'm burning 4.5-5 gph less and when I need or want to I can
tear up the sky at 185-190 mph indicated at 15 gph.
Old May 3rd 06, 04:01 PM posted to rec.aviation.owning
On 2006-04-30, Montblack Y4-NOT wrote:
("Newps" wrote)
Or just buy a more efficient plane. I sold my 182 and got a Bonanza. I'm
The Bonanza is vastly more efficient than a C182. Our club had a 1960
C182 and a mid-60s S35 Bonanza. The C182 (IIRC) had an O-470. It would
burn about 13 gph in cruise at about 135 kts (again, IIRC). The Bonanza
with an IO-520 (285hp) would do 160 knots at the same fuel flow. It
would also climb a lot faster, take off in less distance, and IMHO was a
much nicer plane to fly.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old May 1st 06, 02:15 AM posted to rec.aviation.owning
That's one way to to do it. Bonanza are a lot more fuel efficient than
a 182.
I just had a trip last weekend in my 75 AA5. 420nm buring 27.58gal of
autogas, about 15.2 nmpg. That's very good for a production 4-seater.
Old May 1st 06, 03:44 PM posted to rec.aviation.owning
"M" wrote in message
a 182.
TN B36 (IO-550): 418nm (Montrose-Lincoln, NE), 185kts, 19kt tailwind, 12,500
feet, 32.5 gallons 100LL, 60 LOP; TT 2hrs 19min.
Old May 1st 06, 02:45 AM posted to rec.aviation.owning
"Newps" wrote
... I sold my 182 and got a Bonanza. I'm burning a lot less gas, approx
Wow! Is that at the same air speed?
Old May 1st 06, 03:20 PM posted to rec.aviation.owning
About 10 mph faster.
Old May 1st 06, 03:39 AM posted to rec.aviation.owning
Amen.
Would you mind talking some sense into my partner? We have a perfect
opportunity to buy a F33 from a friend in the next hangar over.
Pristine aircraft, casual sale (so no tax liability here in NJ), just
needs some avionics work. It does 178KTAS on ~15GPH, while we burn
11GPH in the 172/180HP doing 115KTAS on a good day. Ugh. My kingdom
for a little common sense.
-Doug
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old May 1st 06, 03:54 AM posted to rec.aviation.owning
However, what would the difference in maintenance costs be between the
172 and the F33, and insurance...?
Bob Noel
Looking for a sig the
lawyers will hate
Old May 1st 06, 06:55 PM posted to rec.aviation.owning
I have a 180hp (C/S prop) C-172F with the lyc O-360 and I burn and plan
on 9 gph. Why are you at 11? I run 2300 rpm and 22". I believe that give
me 9 gph.
Ross
Amen.
opportunity to buy a F33 from a friend in the next hangar over. Pristine
aircraft, casual sale (so no tax liability here in NJ), just needs some
avionics work. It does 178KTAS on ~15GPH, while we burn 11GPH in the
172/180HP doing 115KTAS on a good day. Ugh. My kingdom for a little
common sense.
-Doug
Old May 1st 06, 01:58 PM posted to rec.aviation.owning
M wrote:
The best "mod" you can get to make fuel cost more bearable is the
autogas STC, if you're lucky enough to own a model that can get the
STC, and you can get ethanol free autogas.
How great is that mod when you need to get 30-40 gallons into the plane?
Do you land at a gas station? G
Even 20 is a lot to carry around in portable containers.
