Andor Holtsmark wrote:
At 17:12 04 June 2006, Eric Greenwell wrote: I think this is a very narrow view of what a sustainer can do and how they are really used. Don't many European pilots often take a winch launch, then use the sustainer to get to lift 20 or 30 miles away? -And how often do they suffer from engine trouble? Why are these two stroke engines so notoriously unreliable? When I think about all of the two wheeled vehicles out there that operate reliably at terrestrial sorts of speeds for years, without the good flow of cooling air like on an aircraft, I wonder why sustainers are so problematic. I'm familiar with two strokes being harder to start, but from discussions here and elsewhere I get the impression they can be expected to poop out after an hour of use, or less, in the air. Doesn't seem right. Thoughts? Experience? Shawn |
Why are these two stroke engines so notoriously unreliable? In many cases, I'm sure, it's because they don't run often enough. Two stroke or four, it's not that they fail, it's that they fail to start. Tony V. |
Tony Verhulst wrote:
Why are these two stroke engines so notoriously unreliable? In many cases, I'm sure, it's because they don't run often enough. I think this is especially likely to be true for sustainer engines, which are only used for a (rare?) self-retrieve, unlike the self-launchers which are usually run each flight for the launch. That's why I think many pilots would be interested in the greater reliability an electric sustainer could provide, even with a reduced range compared to a gas engine. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
On Mon, 05 Jun 2006 09:12:12 -0600, Shawn
sdotherecurry@bresnannextdotnet wrote: Why are these two stroke engines so notoriously unreliable? Thoughts? Experience? My personal perception of 2strokes as installed on a DG400 and a DG600M, is of very good to excellent reliability. Never a problem with the single cylinder 600, a few problems with the 400 (carb needle valves, HT wires). aldo cernezzi |
2cernauta2 wrote:
On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Why are these two stroke engines so notoriously unreliable? Thoughts? Experience? My personal perception of 2strokes as installed on a DG400 and a DG600M, is of very good to excellent reliability. Never a problem with the single cylinder 600, a few problems with the 400 (carb needle valves, HT wires). aldo cernezzi I have no first hand experience, but I was under the impression that the simplicity of the sustainer engines (no starter, etc) means that they are quite reliable, if only because there is not much that can break. |
"Greg Arnold" wrote in message news:m76hg.11350$KB.6912@fed1read08... 2cernauta2 wrote: On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Why are these two stroke engines so notoriously unreliable? Thoughts? Experience? My personal perception of 2strokes as installed on a DG400 and a DG600M, is of very good to excellent reliability. Never a problem with the single cylinder 600, a few problems with the 400 (carb needle valves, HT wires). aldo cernezzi I have no first hand experience, but I was under the impression that the simplicity of the sustainer engines (no starter, etc) means that they are quite reliable, if only because there is not much that can break. Small 2-stroke engines which require oil mixed with the fuel will often have startng problems after long periods of inactivity. The fuel/oil mix forms gum in the small passages inside the carburator blocking them. I understand there are spicific 2-stroke oils that reduce but do not eliminate this problem. The cure is to dismantle the fuel system and clean it with solvent. I wouldn't expect a weed eater, snow blower, or lawn mower that has sat with fuel in it for 6 months or so to start easily. Sustainer engines are no different. Bill Daniels |
sdotherecurry@bresnannextdotnet wrote: Andor Holtsmark wrote: Why are these two stroke engines so notoriously unreliable? I have been flying with sustainer engines (Solo 2350) for more than 10 years in a Discus bT, Ventus2cT and DuoDiscusT and never had a problem with it. Most of the times engine problems are the cause of bad maintenance or incorrect use of the engine. |
AT Parowan last June, one supper conversation with three owners of
powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Ruud wrote: On Mon, 05 Jun 2006 09:12:12 -0600, Shawn sdotherecurry@bresnannextdotnet wrote: Andor Holtsmark wrote: Why are these two stroke engines so notoriously unreliable? I have been flying with sustainer engines (Solo 2350) for more than 10 years in a Discus bT, Ventus2cT and DuoDiscusT and never had a problem with it. Most of the times engine problems are the cause of bad maintenance or incorrect use of the engine. |
Charles Yeates wrote:
AT Parowan last June, one supper conversation with three owners of powered single seaters detailed two propeller problems (manufacturer took a season to sort out) and one battery failure (expensive) -- unusual, I suppose. But not engine problems, eh? Were these all two stroke engines? And I'm very curious how a battery failure could be expensive, given the low cost of batteries. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
-To me the disappointing thing is that so much of the discussion seems to be focused on the motorization of the self-sustainer version of the Antares 18. There is a lot more to that aircraft than a way to get home once you run out of thermals. This aspect seems to be completely ignored, which is rather strange, since the goal of gliding is to get somewhere WITHOUT using the engine. Well, it's a very pretty (and certainly not affordable by me) 18M glider, but how much is there to discuss given the lack of a measured polar, and any real performance comparisons with 18M gliders from more established manufacturers? What makes the 20E interesting to most of us is its electric motor. The only thing that makes the 18T interesting, at the moment, is the lack of an electric motor. If it runs away from the ASG-29s, LS-10, LAK-17As, and V2Cs at the WGC, I'm sure we'll all be more interested... |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
