The issue is recovery from a botched barrel roll, such as in
inverted stall followed by a high speed dive and too strong a pull on recovery. "Big John" wrote in message ... | Andrey | | As has been said in all the posts, the short answer is NO. 172 is not | certified to do barrel rolls. | | However I can barrel roll a 172 only pulling 1 G which puts no more | load on airframe than straight and level flight. I have thousands of | hours to back up my statement. | | A corollary. | | Is a 707 certified for barrel rolls? Short answer is NO. | | Did a Boeing Test Pilot barrel barrel roll a 707 over the boat races | on Lake Washington without any damage to aircraft. YES. | | I'm also sure Dudley can barrel roll the 172 without any problem or | exceeding any limits. | | Long Long answer is don't try to B-roll the 172. | | My 1971 172/Skyhawk Owneers manual shows: | | Normal Cateory Maneuvers | | Max pos G' = 3.8 | Stalls and turns not to exceed 60 degrees of bank. | | Utility Caategory Maneuvers | | Max pos G's = 4.4 | Chandelles | Lazy Eights | Steep Turns | Spins | Stalls (Except whip stalls) | | Acrobatics that may impose high loads should not be attempted. | | | Big John | `````````````````````````````````````````````````` `````` | | | On 20 Jul 2006 04:34:44 GMT, Andrey Serbinenko | wrote: | | | If kept within the normal category load limits, is 172 certified to do | barrel rolls? | | Andrey | |
Big John schrieb:
However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No, you can't do a barrel roll without pulling more than 1g. Did a Boeing Test Pilot barrel barrel roll a 707 over the boat races on Lake Washington without any damage to aircraft. YES. No, it wasn't a barrel roll, it was an aileron roll. (At least this is what I've been told, and it makes a lot of sense.) Stefan |
Did a Boeing Test Pilot barrel barrel roll a 707 over the boat races on Lake Washington without any damage to aircraft. YES. No, it wasn't a barrel roll, it was an aileron roll. (At least this is what I've been told, and it makes a lot of sense.) Someone correct me if I'm wrong, but isn't an aileron roll a negative 1 G maneuver? You spin on an axis, through the plane's center of gravity. For an instant, the pilot is upside down, hanging by the belt. Mr. Boeing would not be pleased if all of the gas and oil was on the top of the tank, away from the fuel and oil pickups. The 707 roll was indeed a barrel roll. Check it out on Jay's webpage. -- Jim in NC |
"Morgans" wrote: Someone correct me if I'm wrong, but isn't an aileron roll a negative 1 G maneuver? You spin on an axis, through the plane's center of gravity. For an instant, the pilot is upside down, hanging by the belt. Inertia, centrifugal force. Think three dimensional. You do not have to maintain level flight. Pick a down-line. Altitude and gravity are your friends, put the nose down. :-)) |
Morgans schrieb:
Someone correct me if I'm wrong, but isn't an aileron roll a negative 1 G maneuver? You spin on an axis, through the plane's center of gravity. For an instant, the pilot is upside down, hanging by the belt. No. This is called a slow roll or simply a roll. The 707 roll was indeed a barrel roll. Check it out on Jay's webpage. Hardly an authoritative source. Stefan |
Morgans wrote
The 707 roll was indeed a barrel roll. Check it out on Jay's webpage. Again....check the definition of a "barrel roll" at the web site posted by Peter and my previous post. Big John, dispite his thousands of hours, simply doesn't know what a "barrel roll" is. I'll put my Navy training and 22,000 hours and ATP/CFI ratings up against his anyday. :-) I've been waiting for two years for John to post an authoritative source for his concept of a "barrel roll". http://www.iac.org/begin/figures.html#Aileron%20Rolls |
Stefan
I'm glad your the expert. I used to do half of a barrel roll at one G and give to student under the hood upside down to recover. Bird of course was acro rated but student couldn't tell we had rolled inverted and we were pulling 1 G positive when handed over. Big John ````````````````````````````````` On Thu, 20 Jul 2006 21:35:26 +0200, Stefan wrote: Big John schrieb: However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No, you can't do a barrel roll without pulling more than 1g. Did a Boeing Test Pilot barrel barrel roll a 707 over the boat races on Lake Washington without any damage to aircraft. YES. No, it wasn't a barrel roll, it was an aileron roll. (At least this is what I've been told, and it makes a lot of sense.) Stefan |
Big John schrieb:
I'm glad your the expert. I'm far from being an expert, but I have an idea, yes. I used to do half of a barrel roll at one G and give to student under If you can actually do a barrel roll without exceeding 1g at any point, then you should immediately inform your local university. Or, better yet, directly the nobel commitee. Because you've just proved that some very basic physical laws are wrong. Stefan |
Stefan
Have done many in real life. Go to Google and research Barrel Rolls. You will find links that show you can do them between 0.5 G's and max G's bird is certified for. Beside these 'experts' who posted, all I can say is fly the airplane. If you want 1 G then fly it that way. If you can't fly it that way then don't get in bird as you are an accident waiting to happen. Big John `````````````````````````````````` On Fri, 21 Jul 2006 11:10:53 +0200, Stefan wrote: Big John schrieb: I'm glad your the expert. I'm far from being an expert, but I have an idea, yes. I used to do half of a barrel roll at one G and give to student under If you can actually do a barrel roll without exceeding 1g at any point, then you should immediately inform your local university. Or, better yet, directly the nobel commitee. Because you've just proved that some very basic physical laws are wrong. Stefan |
Big John wrote:
Andrey As has been said in all the posts, the short answer is NO. 172 is not certified to do barrel rolls. However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No you can not. It's not possible to even start the roll without going greater than 1G. |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
