From FAA's 2004 Instrument Procedures Handbook, chapter 5:
[...] The weather conditions encountered in CAT III opera- tions range from an area where visual references are adequate for manual rollout in CAT IIIa, to an area where visual references are inadequate even for taxi operations in CAT IIIc. To date, no U.S. operator has received approval for CAT IIIc in OpsSpecs. [...] But I heard that airlines are not only authorized, but required to do an auto-land every so often. Am I missing something here? Andrey Jim Carter wrote: -----Original Message----- From: Andrey Serbinenko ] Posted At: Sunday, August 06, 2006 2:42 PM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums A question: the landing minimums section for ILS CAT-III approaches may have separate lines for A, B, and C. In some cases the C line has an "NA" for visibility, and on some other plates the whole C line is missing. So, what's the difference? Does "NA" mean "not authorized", i.e. CAT-IIIC cannot be used? Thanks! Andrey Can you give us a particular plate or approach to reference please? |
You don't need CAT IIIc for autoland. Cat IIIa is sufficient. I'm
sure one of the airline drivers will chime in - ceiling/visibility ignored for a moment, can't you autoland off a normal CAT I ILS if you so desire? It's the same LOC/GS as the CAT III beam, right? They just flight and obstacle check to a greater tolerance for the CAT III authorization? On Mon, 07 Aug 2006 04:37:55 +0000, Andrey Serbinenko wrote: From FAA's 2004 Instrument Procedures Handbook, chapter 5: [...] The weather conditions encountered in CAT III opera- tions range from an area where visual references are adequate for manual rollout in CAT IIIa, to an area where visual references are inadequate even for taxi operations in CAT IIIc. To date, no U.S. operator has received approval for CAT IIIc in OpsSpecs. [...] But I heard that airlines are not only authorized, but required to do an auto-land every so often. Am I missing something here? Andrey Jim Carter wrote: -----Original Message----- From: Andrey Serbinenko ] Posted At: Sunday, August 06, 2006 2:42 PM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums A question: the landing minimums section for ILS CAT-III approaches may have separate lines for A, B, and C. In some cases the C line has an "NA" for visibility, and on some other plates the whole C line is missing. So, what's the difference? Does "NA" mean "not authorized", i.e. CAT-IIIC cannot be used? Thanks! Andrey Can you give us a particular plate or approach to reference please? |
Peter Clark wrote:
You don't need CAT IIIc for autoland. Cat IIIa is sufficient. I'm sure one of the airline drivers will chime in - ceiling/visibility ignored for a moment, can't you autoland off a normal CAT I ILS if you so desire? It's the same LOC/GS as the CAT III beam, right? They just flight and obstacle check to a greater tolerance for the CAT III authorization? It depends upon an airline's ops specs and flight ops policy. Autolanding on a non-CAT III ILS does not assure containment on the runway, thus the weather better be sufficient to see if things are not working out. |
so desire? It's the same LOC/GS as the CAT III beam, right? They If I remember correctly, the glide slope reception and usability for vertical guidance are only guaranteed above DA for the approach. So, I'd assume CAT I and CAT II beams don't officially reach the surface of the runway. Andrey just flight and obstacle check to a greater tolerance for the CAT III authorization? On Mon, 07 Aug 2006 04:37:55 +0000, Andrey Serbinenko wrote: From FAA's 2004 Instrument Procedures Handbook, chapter 5: [...] The weather conditions encountered in CAT III opera- tions range from an area where visual references are adequate for manual rollout in CAT IIIa, to an area where visual references are inadequate even for taxi operations in CAT IIIc. To date, no U.S. operator has received approval for CAT IIIc in OpsSpecs. [...] But I heard that airlines are not only authorized, but required to do an auto-land every so often. Am I missing something here? Andrey Jim Carter wrote: -----Original Message----- From: Andrey Serbinenko ] Posted At: Sunday, August 06, 2006 2:42 PM Posted To: rec.aviation.ifr Conversation: CAT IIIC minimums Subject: CAT IIIC minimums A question: the landing minimums section for ILS CAT-III approaches may have separate lines for A, B, and C. In some cases the C line has an "NA" for visibility, and on some other plates the whole C line is missing. So, what's the difference? Does "NA" mean "not authorized", i.e. CAT-IIIC cannot be used? Thanks! Andrey Can you give us a particular plate or approach to reference please? |
ignored for a moment, can't you autoland off a normal CAT I ILS if you so desire? It's the same LOC/GS as the CAT III beam, right? They If I remember correctly, the glide slope reception and usability for vertical guidance are only guaranteed above DA for the approach. So, I'd assume CAT I and CAT II beams don't officially reach the surface of the runway. Andrey The G/S is not used for Autoland below 100 feet, or so. It is all radar altimetry and computer logic starting at 150 feet, when the system goes from autoland tracking to autoland align. |
But I heard that airlines are not only authorized, but required to do an auto-land every so often. Am I missing something here? 'Autoland' and 'Approach CAT' are two separate subjects. It is true that 'autoland' is a requirement for the conduct of an approach and landing if the wx conditions are below CATII minimums, but autoland can also be used in VFR conditions. The reason for the requirement to conduct autolandings every so often (we had that requirement at the old PanAm) is to insure that the equipment remains in calibration. If the autolandings were not logged, the equipment had to be removed from the a/c and bench calibrated at scheduled intervals. Many of our PanAm B-727s had autoland capability with only a CATII approach capability. Bob Moore ATP B-707 B-727 PanAm (retired) |
that 'autoland' is a requirement for the conduct of an approach and landing if the wx conditions are below CATII minimums, but autoland can also be used in VFR conditions. OK, I see now. Thanks! Andrey The reason for the requirement to conduct autolandings every so often (we had that requirement at the old PanAm) is to insure that the equipment remains in calibration. If the autolandings were not logged, the equipment had to be removed from the a/c and bench calibrated at scheduled intervals. Many of our PanAm B-727s had autoland capability with only a CATII approach capability. Bob Moore ATP B-707 B-727 PanAm (retired) |
| Thread Tools | |
| Display Modes | |
| Alternate minimums same as forecast weather | [email protected] | Instrument Flight Rules | 17 | February 21st 06 11:45 PM |
| Middle Marker minimums | S Herman | Instrument Flight Rules | 5 | June 9th 05 06:28 PM |
| Canadian departure minimums? | Derrick Early | Instrument Flight Rules | 3 | August 9th 04 02:43 PM |
| Skymap IIIC Mounting Options | NW_PILOT | Owning | 15 | July 8th 04 02:41 PM |
| Personal Weather Minimums | FryGuy | Piloting | 26 | December 9th 03 07:09 AM |
