Crashing on takeoff... how odd
Old August 28th 06, 06:21 AM posted to rec.aviation.piloting
John Gaquin
Default Crashing on takeoff... how odd
Well, why then do you guys dread an engine failure more than anything
else?
Most transport pilots don't, I think. There are a number of things I would
rate higher on the crucial scale than an engine failure. .
Old August 28th 06, 07:26 AM posted to rec.aviation.piloting
Jim Macklin
Perhaps more than the short runway, rising terrain off the
end of runway 26 looks to be in the take-off path. It will
be weeks before the calculations are verified, the ATC and
CVR tapes checked and the FDR completely investigated.
James H. Macklin
ATP,CFI,A&P
| Matt Whiting wrote:
| You are assuming that all such crashes are due to
partial power loss. Isn't so. One
| airplane crash on takeoff a few years ago was due to a
problem with the elevator trim, if I
| recall correctly. Also, a weight and balance issue can
cause a crash right after takeoff as
| can myriad other problems not related to power.
than anything
| else? The reason is because other factors are pretty
much within
| your control - pitch trim, aircraft loading, choice of
runway,
| condition of the tires and whatever else. Engines too I'm
sure aren't
| altogether iffy but there's an element of risk of a
failure because of
| their enormous complexity - and nobody can deny that there
isn't
| anything simple about a turbine!
| Someone on this thread mentioned 'loss of control
surfaces' as one of
| the many possible reasons - what does that mean? A
hydraulic failure
| that altogether prevents aileron, elevator and rudder
control?
| Ramapriya
Old August 28th 06, 07:56 AM posted to rec.aviation.piloting
Jim Macklin
That may not be the case, downloaded the IAP charts and
looked at a topo map of the airport area, it appears that
the terrain slopes downward off the end of rwy 26, but that
does not include trees and buildings.
http://www.topozone.com/map.asp?lat=...ad27&layer=DRG
Reports are that they hit the airport fence, that would have
seriously impacted climb.
BTW, for those who suggested that the crew may have set the
HI to the wrong heading, transport jets have dual slaved
compass systems.
"Jim Macklin" wrote
in message news:O8vIg.6171$SZ3.5038@dukeread04...
will
| James H. Macklin
| ATP,CFI,A&P
| wrote in message
| than anything
| much within
| runway,
| sure aren't
| failure because of
there
| isn't
| surfaces' as one of
| hydraulic failure
| control?
|| Ramapriya
Old August 27th 06, 08:57 PM posted to rec.aviation.piloting
Bob Gardner
Airplanes are heavier on takeoff than at any other time, and the margin
between their climb speeds and the stall is at its smallest. Ask anyone who
has done a V1 cut in training or on a checkride (jets only). I'm willing to
venture that the pilots of the accident plane did all of the appropriate
calculations for the longer runway. Seems to me that if a plane is cleared
for takeoff on a long runway but lines up on a shorter runway, there is a
lot of blame to be shared between the cockpit and the tower.
Bob Gardner
I remember a recent discussion with a pilot mate where I was mentioning
how illogical a crash-shortly-after-takeoff is, given that beyond V1
takeoff can safely be continued even with just one good engine. I'd
even told him that if I saw an aircraft airborne following takeoff, I'd
presume it safe.
Days after that tete-a-tete, a Fokker went down in Pakistan shortly
after taking off. And today the Bombardier at Kentucky.
Doesn't add up, does it? After all, if the engines are good and there's
no bomb going off, it should be pretty hard to crash an aircraft!
Ramapriya
Old August 27th 06, 09:01 PM posted to rec.aviation.piloting
Matt Whiting
If the tower cleared the airplane to the correct runway and the pilots
taxied to a different one, how does the tower share in this blame?
Matt
Old August 27th 06, 09:35 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Matt Whiting" wrote in message
ATC will no doubt be assigned a share of the blame. But if the pilot
reports ready to go at the assigned runway when he's actually at a different
one, and there is a Comair at the assigned runway, it's easy for the local
controller to miss the error.
Old August 27th 06, 10:20 PM posted to rec.aviation.piloting
Matt Whiting
I certainly always appreciate when ATC catches a mistake that I make or
am about to make, but as PIC the bottom line is that it is still my
responsibility for any errors, not ATC's.
Matt
Old August 27th 06, 10:49 PM posted to rec.aviation.piloting
Newps
Jets take a long time to take off so if he used the wrong runway the
question will certainly arise as to what the tower controller was
looking at. My guess is the coffee pot. The controller would have had
about 1 minute after issuing the clearance to notice that he was using
the wrong runway. And looking at the airport diagram this would be an
area well known to controllers for aircraft using the wrong runway. We
have one here at BIL. Ask for a certain intersection and don't turn all
the way onto the runway and you are using the last 700 feet of another
runway. We've had one crash, one near crash and a bunch of aborts from
pilots who weren't paying attention.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Approaches and takeoff mins. jamin3508 Instrument Flight Rules 22 September 14th 05 03:51 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 4th 03 12:53 AM
