Glider Crash - Minden?
Old September 1st 06, 07:08 AM posted to rec.aviation.soaring
Bob C
Default Glider Crash - Minden?
Like Jack, I just read the whole thread. 4 comments:
1. Remember, the most important glass in a glass cockpit
is above the instrument panel. I used to quote this
to airline pilots, but these days I find it appropos
for many gadget-oriented glider drivers.
2. If you're not seeing much traffic, you're just not
looking hard enough.
3. I tried the 10 point font 'o' at ten feet. Even
in light blue it was clearly visible. At age 46, it's
actually harder to see it at 10 inches! I see another
aircraft at 10 miles, I wish I could read my altimeter
to tell ATC where I am ;o)
4. The rules are see and avoid, and give way to the
glider. The PIC is responsible for knowing all pertinent
information about the intended flight. Adjusting speed
or flight path to avoid heavy glider traffic is not
just a good idea, it's the law.
At 04:42 01 September 2006, Glen Kelley wrote:
Ramy, I would agree. Mode A isn't completely worthless,
since at least the
airliner knows you are around. Clearly Mode C provides
more 'protection'.
Glen
'Ramy' wrote in message
roups.com...
Thanks Glen. I am not aware of any transponder equiped
glider not using
mode C. Seems like once you go through the hassle
and cost of
installing a transponder, the encoder is the easy
part. Mode A sounds
almost useless, more confusing then not. A mode A
transponder could
signal an alert to any airline crusing at 30K above.
Which baffles me - Why aren't modern transponders
already including
internal encoder??
Ramy
Glen Kelley wrote:
Ramy,
The problem is that TCAS will display you as a target
with altitude
unknown
(unless you have mode c with an encoding altimeter).
Therefore, TCAS
will
only call you out as traffic and display your position
without generating
a
Resolution Advisory (RA). We see this pretty often
as VFR traffic. We
will
be looking hard for the traffic, but won't necessarily
maneuver the
aircraft, since we can't see altitude/heading.
If in fact, the sailplane does have mode C with an
encoding altimeter,
then
the RA will be generated and you should see the big
bird maneuver to
avoid
the conflict. Note that a TCAS RA will direct maneuvering
in the
vertical
only, since TCAS azimuth is considered too innacurate
to generate
turn-based
avoidance. Typical RAs would be 'Climb,Climb, Climb
- Descend, Descend,
Descend - Reduce Climb - Reduce Descent, etc'.
I guess I figured most of the gliders with transponders
weren't using
Mode
C, so good catch.
Glen
Thanks for the excellent overview, Glen. Regarding
number 3, why would
a TCAS equipped airliner pilot need to see me if
the TCAS gives the
resolution? I'm pretty sure most of the airliners
vectored around me
never actually see me (although I always
wave ;-)
Ramy
Glen Kelley wrote:
A few additions to Kirk's excellent points - from
the background of
former
fighter pilot, current airline pilot, and current
glider pilot:
1. We often surprise each other in sailplanes with
how hard it is to
see
each other. Don't expect an airline pilot to be
any better at it!
The
fighter pilot at least will have good visual acuity
and is used to
looking
for small targets.
2. Airline pilots don't carry sectionals - at the
speeds we operate,
there
would be little time to use them anyway. Fighter
pilots will carry a
low
level map and will have thought about visual traffic
conflicts, wires,
terrain, etc in the planning stages. At the speeds
they operate, they
aren't looking at those maps very often, once airborne.
3. The busier glider operations are notam'd and often
referred to by
atc
controllers. If you have an operable transponder,
you will *normally*
be
called out by atc and if TCAS equipped, airline pilots
will be aware
of
your
location. They would still have to see you to maneuver
away from you.
(See
note 1.) Big airliners are not very maneuverable
(mine - the Boeing
737 -
is limited to 2.5 g!).
4. Fighters are a different case. They don't have
TCAS and only some
of
them have the ability to interrogate/detect transponder
targets. Some
of
them have air intercept radar capability, but sailplanes
are small
radar
targets and will often (usually!) be filtered out
because of their low
speeds and altitudes - like highway traffic. If
they are at low
altitude,
fighters usually operate at high speed (420 - 540
indicated, except
A-10). As Kirk pointed out they will almost never
be alone, but will
be
in
formations of 2 - 4. When low level (100 to 1500
agl, most commonly
300 -
500agl), they will normally *not* be receiving traffic
information
from
ATC.
When operating in a MOA, there may be intercept controllers
who can
call
out
glider traffic, but again, without a transponder,
it is unlikely. The
formations will vary, but most pairs of flight lead
and wingman will
be
laterally spread by 5000 to 10000 feet, for visual
lookout. The
flight
lead
will be spending quite a bit of his time looking
forward for threat
detection and navigation, but the wingman will be
spending less time
looking
forward because he must maintain formation. If they
see you, they
have
an
excellent capability to avoid you. Head on and tail
on, the sailplane
has
the tiny visual profile that fighter designers dream
of.... In other
words,
you are nearly invisible unless you have a wing up
in a turn/thermal.
5. As Kirk said, the primary threat is at 6 o'clock,
because it is
hardest to see - essentially, only the overtaking
aircraft has a
reasonable
chance of avoiding a collision. Therefore, if you
know you are
operating
in
a high threat area: MOA, low level route, approach
corridor, VFR
flyway,
near an airport etc, I would 'belly check' periodically,
depending on
nature of the threat. The timing is based on the
amount of time it
takes
for
the threat aircraft to close from outside visual
range to hitting me
from
the 6 o'clock position. I use visual ranges of 8nm
for airliners, 5
nm
for
small commercial jets (corporate and regional jets)
and fighters, and
3
nm
for light aircraft - adjust as your visual acuity
and experience
dictate.
I
use worst-case speeds as follows: airliner and small
jets - 4 nm/min,
fighters - 8 nm/min, and light aircraft - 2.5 nm/min.
Combing
detection
ranges and times, I calculate: airliners - 2 min,
small jets - 1 min
and
15
sec, fighters - roughly 40 sec, and light planes
- approx 1 min and 15
sec.
So... if you are straight and level for more than
these times, there
is
sufficient time for an aircraft to move from outside
(my) visual range
to
the same airspace as my (your) little pink body.
As you would probably
guess, fighters are the worst case because of their
relatively small
size
and high closure rate. On the positive side, there
are typically more
eyeballs with better acuity and better maneuverability
involved.
Interestingly, small jets and light aircraft are
not that far behind,
as
far
as detection time is concerned. In my experience
they are far less
likely
to see you than the fighters. The same is true for
airliners, but
because
of their size you have more time to see them coming...
6. How to do a belly check: No, I don't hack a
stopwatch, but I keep
above times in mind with respect to the likely threat
for my area. My
primary threat is small jet/light aircraft that operate
on various
highway/flyways and approach corridors. Away from
these specific
areas,
traffic density is extremely low. First clear your
'new six' - if you
are
going to turn left, look to the area behind to the
right 4 - 5 oclock
position - this will be your new blind spot. Next
clear your new nose
position - this is where you are going to roll out.
Finally make a 45
deg
turn to the left and visually clear your 'old six',
which is now at
your
left 7 to 8 o'clock. Often/usually, a belly check
can be incorporated
into
turns you are going to make anyway, for other reasons.
When you
visually
clear, make sure you focus on something on the horizon,
otherwise you
are
only visually clearing out to an arms length. If
I really need to
hold a
straight line, I do the belly check as a gentle 45
deg turn to each
side.
7. In a thermal, periodically check to the outside
of your term to
clear
your 'new six'. If there are other sailplanes with
you in the
thermal,
of
course they are the primary threats for midair, but
you still need to
check
for other aircraft. Fortunately, you are easier to
see while turning -
as
long as the other pilots are looking...
8. Proximity to clouds. You need to think about
what you are doing
when
you are near cloudbase, in proximity to likely IFR
traffic. If you
are
500'
below cloudbase (perfectly legal), and an airliner
descends out of the
cloud
at 250kt on his descent profile on collision course
(perfectly legal),
there
may be as little as 20 seconds to impact. If you
are tail on when
this
happens - good luck. I'm sure no one would ever
be right at cloudbase
on
a
nice day, because that would violate the FARs -
more importantly, you
are
'rolling the bones' every time you do this on a known
approach
corridor.
9. Conclusion. If you fly in a high airliner/small
jet threat area
and
can afford a transponder it will help other people
see/avoid you. If
your
primary threat comes from military operations in
MOAs, I would not
spend
money on a transponder unless I knew those fighters
have intercept/atc
controllers passing them information. The various
TPAS - type devices
will
help your see/avoid efforts and should help in the
case of fighters,
although the flight lead is likely the only one squawking
in the
formation.
Only you/your club knows the primary threats for
your particular
operating
area and you need to understand what they are. Taylor
your altitude
awareness/cloud avoidance and belly check frequency
to the nature of
your
local area. Don't cede visual lookout/avoidance
responsibility to
someone
else - ever. Sailplane right-of-way is a myth in
most situations and
a
comfort only to your survivors/legal counsel.
Hope this helps.
Glen
Old September 1st 06, 04:22 PM posted to rec.aviation.soaring
snoop
Bob, I know what your saying with regard to the aging eyes. It stinks.
With regard to the glass cockpit, the automation is wonderful stuff,
and if more people would learn to set it up, use it and look out the
window more, we'd all be better off. This means all of us,
powered/glider, as I too am guilty of playing with my glider toys while
zipping along on task.
Unfortunately, a lot of our pro pilot friends don't take the time to
fly wonderful GenAv ships like our gliders, and taildraggers, so what
do they want to do when they get to work, shut off the automation and
hand fly the beast. Been in the business for almost thirty years,
watching someone, now head down, hand fly an aircraft with millions of
dollars worth of automation play the High and the Mighty is not
impressive anymore.
When I go to work after a weekend of glider/taildragger play, at 200'
off the deck it's "autopilot on", until 50' over the numbers where I
disengage to land. We brief the approach while still in cruise, yes,
nitpickers, there is always the chance of change of runway, then it's
automation all the way down, keeping eyes going outside. For a VNAV
descent it's only two key strokes, for a FLC descent it's one. If
properly managed it's a thing of beauty to see how little the crew has
to do other than manage, and look outside. Watching guys who want to
play pilot, and turn off the automation in the terminal area, well now
your having to watch him/her, and the airplane. Just easier, to use the
automation at work, then go yank/bank the toys on the weekends!
With regard to item #4, I think "give way" applies to everybody,
especially who ever sees the other guy first, if there's time. Let's
not be "dead right" in interpreting the rules. Avoidance requires
insight provided by all parties involved. If we in our glider take off
thinking, those doggone engine powered beasts better get out of the
way, because the "law" says I own the road, then were as good as dead.
Pick up the phone, mike, our heads, and fly defensively.
since at least the
more 'protection'.
Glen
roups.com...
glider not using
and cost of
part. Mode A sounds
transponder could
already including
internal encoder??
Ramy
Glen Kelley wrote:
Ramy,
with altitude
unknown
Therefore, TCAS
will
without generating
a
as VFR traffic. We
will
maneuver the
encoding altimeter,
then
bird maneuver to
avoid
in the
vertical
to generate
turn-based
- Descend, Descend,
weren't using
Mode
C, so good catch.
Glen
number 3, why would
the TCAS gives the
vectored around me
wave ;-)
Ramy
the background of
former
glider pilot:
how hard it is to
see
any better at it!
The
and is used to
looking
for small targets.
speeds we operate,
there
pilots will carry a
low
conflicts, wires,
they operate, they
referred to by
atc
you will *normally*
be
will be aware
of
your
away from you.
(See
(mine - the Boeing
737 -
TCAS and only some
of
targets. Some
of
are small
radar
they are at low
altitude,
indicated, except
be alone, but will
be
in
agl, most commonly
300 -
information
from
ATC.
who can
call
out
it is unlikely. The
and wingman will
be
lookout. The
flight
lead
forward for threat
spending less time
looking
see you, they
have
an
on, the sailplane
has
of.... In other
words,
in a turn/thermal.
because it is
aircraft has a
reasonable
know you are
operating
in
corridor, VFR
flyway,
depending on
amount of time it
takes
for
range to hitting me
from
for airliners, 5
nm
for
and fighters, and
3
nm
and experience
dictate.
I
jets - 4 nm/min,
Combing
detection
small jets - 1 min
and
15
sec.
these times, there
is
(my) visual range
to
relatively small
size
are typically more
involved.
as
far
they are far less
likely
airliners, but
because
for my area. My
on various
these specific
areas,
'new six' - if you
are
right 4 - 5 oclock
clear your new nose
Finally make a 45
deg
which is now at
your
can be incorporated
into
When you
visually
otherwise you
are
I really need to
hold a
deg turn to each
side.
of your term to
clear
you in the
thermal,
of
you still need to
check
see while turning -
as
what you are doing
when
traffic. If you
are
500'
descends out of the
cloud
(perfectly legal),
there
are tail on when
this
on
a
are
approach
corridor.
jet threat area
and
see/avoid you. If
your
MOAs, I would not
spend
have intercept/atc
TPAS - type devices
will
case of fighters,
in the
formation.
your particular
operating
your altitude
to the nature of
your
responsibility to
someone
most situations and
a
Hope this helps.
Glen
Old September 1st 06, 06:40 PM posted to rec.aviation.soaring
Derek Copeland
Default Mode S Transponders (was Glider Crash - Minden?)
They are still 2000 Euros or £1500 before fitting,
testing, licensing and Value Added Tax. You can buy
a decent airworthy wooden glider for far less than
that in the UK!
If any anti-collision device of about the size, cost
and power consumption of a small portable GPS unit
becomes available, then I might be prepared to buy
one, especially if it doesn't require an externally
mounted aerial that reduces glider performance.
Derek Copeland
At 11:30 01 September 2006, W.J. \bill\ Dean \u.K.\.
All the transponders currently listed by Filser
http://www.filser.de/onlineshop/english/ are modes
A/C and S, and have
extended squitter; they all have an integral alticoder.
These are probably
the cheapest on the UK market http://www.lxavionics.co.uk/
I would be surprised if this is not true of other makes,
I am sure it soon
will be.
W.J. (Bill) Dean (U.K.).
Remove 'ic' to reply.
glider not using
and cost of
part. Mode A sounds
transponder could
already including
internal encoder??
Ramy
Old September 1st 06, 07:37 PM posted to rec.aviation.soaring
Jack[_1_]
Default Mode S Transponders....
Derek, on how many of your best days of the year could you tell the
difference with a tiny external 1030-1090 MHz antenna? Yes, it's
expensive, but let's not get silly about performance degradation.
Not keeping the pieces of the glider flying in close formation will
degrade your personal performance considerably.
Jack
Old September 1st 06, 07:57 PM posted to rec.aviation.soaring
Derek Copeland
Jack,
I know that a UK pilot removed a transponder aerial
from his glider part way through a Nationals competition
because he was losing too much performance in relation
to his competitors in similar gliders. Also I fly a
Standard Cirrus, so I need all the performance I can
get!
Derek Copeland
you tell the
Yes, it's
degradation.
formation will
Jack
Old September 1st 06, 08:31 PM posted to rec.aviation.soaring
Jack[_1_]
What serious competitors will do to gain a perceived (or imagined)
edge would stun Ripley's most jaded researchers.
Though the difference may be quantifiable by theoretical
aerodynamicists, are the numbers measurable in actual performance? I
am always open to citations of flight tests which may demonstrate such
differences.
Here we should be addressing the cost/benefit relationship for
ourselves. I fear that it will require government mandate and
resulting high production levels to bring the unit price down. But we
could do that ourselves to some degree by establishing a demand to
serve our own safety interests.
I have ordered a PCAS (less than $500 from Tim Mara at Wings and
Wheels http://www.wingsandwheels.com/page4.htm) Now the problem is
where to place it in my 1-26E. I may have to buy a different glider
just to accommodate the new PCAS unit. ;
I'd buy a Standard Cirrus like yours, but I'm addicted to Aluminum.
Jack
you tell the
Yes, it's
degradation.
formation will
Jack
Old September 2nd 06, 03:08 AM posted to rec.aviation.soaring
Eric Greenwell[_1_]
Jack,
get!
You can't measure the performance loss that a transponder antenna on
your Std Cirrus, the drag is so little; nonetheless, the fiberglass
fuselage will let you mount one internally. The big advantage is it's
protected from ground and handling damage.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old September 2nd 06, 04:14 AM posted to rec.aviation.soaring
Jack[_4_]
Snoop,
Not going to make the lap races at TSA...DRAT!!! Work and family stuff
got in the way at the last minute. I understand what the rest of you
said about the airlines, flying public, and picking your battles.
Sorry, it was more af a rant than anything...
Jack Womack
Jack,
get!
Operation"
Old September 5th 06, 04:29 PM posted to rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
Eric,
The pilot who removed his transponder antenna is a friend of mine, and I
talked with him about it at the time.
The glider is an ASW27, he was flying in competition with other pilots in
ASW27s who were well known to him as people and as pilots. Some were
members of his club.
He has a transponder fitted (Becker Mode A/C, not Mode S) because he
frequently flies high in wave, particularly in Scotland, where it is
necessary to talk to an air traffic controller and either a great help or
essential to have a transponder. He is also a professional airline pilot.
During the competition the transponder would not have been turned on. He
started with the antenna fitted because he did not realise the difference in
performance it caused. After two or three days, with his ship not going as
well compared with the others as he expected, he removed it. The
difference was immediate and obvious, he described to me the difference with
it fitted as turning the ASW27 into an ASW20! Remember, he had been flying
with the antenna for some time, it was only in contest against other similar
gliders with good pilots that he saw the difference.
Please do not talk as if flying in UK contests involves the same collision
risk with CAT as flying in the high skies around Minden (I have never done
that, alas!). I understand that there has not been an actual collision in
the UK between a glider and CAT or the military since 1947.
To anyone buying a new modern machine from Schleicher, Schempp or the
others, the cost of fitting a transponder is only a small percentage of the
total cost, but would still involve finding panel space, and sufficient
power (particularly if the transponder is to be on whenever airborne). But
there are still a lot of low value gliders in use in the UK, and a lot of
gliding being done where the actual collision risk where a transponder would
make a difference is very small. In the USA, I wonder how many of the 1-26
fleet are fitted?
Remove "ic" to reply.
"Eric Greenwell" wrote in message
news:HQ4Kg.227$m36.105@trnddc02...
Jack,
get!
You can't measure the performance loss that a transponder antenna on your
Std Cirrus, the drag is so little; nonetheless, the fiberglass fuselage
will let you mount one internally. The big advantage is it's protected
Operation"
Old September 5th 06, 05:18 PM posted to rec.aviation.soaring
Eric Greenwell
I remain skeptical: I sure didn't see any difference at all when I
fitted a transponder antenna to my ASH 26 E, flying against gliders I'd
flown with for years, nor have I heard of anyone else noticing a
difference. Perhaps something unusual was occurring in his case.
that, alas!).
I won't, and I didn't. My remarks were directed at a Std Cirrus pilot
who felt he needed every crumb of performance, and that was why he
wouldn't consider a transponder. My belief the drag increase is
insgnificant, so it shouldn't be a factor in his decision. The need for
it and the cost are the most important factors, I think.
Also the situation in much of the USA. Though, I don't think the value
of the glider should be a factor in the decision to install a
transponder. I realize you are using the glider value as a proxy for the
spare cash the owner has, but I'd rather the focus was on the collision
risk, the value of reducing it, and the cost of installing a transponder.
In the USA, I wonder how many of the 1-26 fleet are fitted?
I don't know, but some do have them in the Minden area.
Are you allowed to fly in airways in the UK (as we do in the US), and
would having a transponder give you greater access to them?
Note: email address new as of 9/4/2006
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 7th 06 12:13 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 06:58 PM
Seniors Contest Bob Fidler Soaring 68 March 17th 05 04:50 AM
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 11:41 AM
Announce/USA: FAA Glider Flying Handbook / Bob Wander SoarBooks Soaring 0 August 11th 03 04:55 PM
