"Kingfish" wrote in message ups.com... Larry Dighera wrote: While pilot Annette Saunders handled her Hawker 800XP admirably after colliding with the glider, why she obviously failed to give way is a mystery. Don't you have to *see* the other aircraft before you can give way? As has been mentioned by other posters in this thread, if the glider didn't have a transponder the jet's TCAS wouldn't have seen it, and the glider's profile might make it hard to spot. Why do you automatically assume the Hawker pilot is at fault? Yes you have to look out the front and scan to see other aircraft. Because she is a woman JOKING. Hope that reporter does not read this. From now on in I think I will enjoy baiting reporters with bull**** to see if they report it. Lets see I am in a jet doing 300 knots descending I believe I am under IFR control and the ATC would advised of traffic! |
"Kingfish" wrote:
Larry Dighera wrote: While pilot Annette Saunders handled her Hawker 800XP admirably after colliding with the glider, why she obviously failed to give way is a mystery. Don't you have to *see* the other aircraft before you can give way? As has been mentioned by other posters in this thread, if the glider didn't have a transponder the jet's TCAS wouldn't have seen it, and the glider's profile might make it hard to spot. Why do you automatically assume the Hawker pilot is at fault? Is there a hard-to-see exception in the right of way rules? Everyone is focusing on how hard a glider is to see in straight-and-level flight head-on. It seems far more likely that this was not head on. From the glider's perspective the jet was an unmoving object somewhere in the sky, while from the jet's perspective, the glider was a moving object directly ahead. Will be interesting to hear the glider pilot's perspective of where and from what angle he was hit. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
alexy wrote: Is there a hard-to-see exception in the right of way rules? No, but there is a physical limitation to the Mk1 Mod1 Eyeball - which, in the absence of any usable TCAS type equipment is all you have. Everyone is focusing on how hard a glider is to see in straight-and-level flight head-on. It seems far more likely that this was not head on. From the glider's perspective the jet was an unmoving object somewhere in the sky, while from the jet's perspective, the glider was a moving object directly ahead. And you know this...how? It's all speculation until both pilots are interviewed and their accounts are made public. Will be interesting to hear the glider pilot's perspective of where and from what angle he was hit. Agreed. There might be a lesson in this for all pilots. |
"Kingfish" wrote:
alexy wrote: Is there a hard-to-see exception in the right of way rules? No, but there is a physical limitation to the Mk1 Mod1 Eyeball - which, in the absence of any usable TCAS type equipment is all you have. Everyone is focusing on how hard a glider is to see in straight-and-level flight head-on. It seems far more likely that this was not head on. From the glider's perspective the jet was an unmoving object somewhere in the sky, while from the jet's perspective, the glider was a moving object directly ahead. And you know this...how? Assuming by "this" you are referring to what I wrote (that it seems more likely), I know this just from the common knowledge that biz jets spend a very large portion of their time in straight or gently turning flight and gliders spend a large portion of their time turing, Also, that at their relative speeds, it is almost as easy for the jet to broadside the glider as to hit it headon. It's all speculation until both pilots are interviewed and their accounts are made public. Absolutely. That's why I limited my comment to what seemed more likely to me, with no broader claim. Will be interesting to hear the glider pilot's perspective of where and from what angle he was hit. Agreed. There might be a lesson in this for all pilots. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
"alexy" wrote in message ... "Kingfish" wrote: Larry Dighera wrote: -on. It seems far more likely that this was not head on. From the glider's perspective the jet was an unmoving object somewhere in the sky, while from the jet's perspective, the glider was a moving object directly ahead. Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. If I read your logic, the jet is unmoving because it is in steady flight (not circling), so it stays in one position relative to the glider. Whereas the glider is circling and so moves back and forth to some extent. Well, given the small diameter of a thermalling glider, I think for all intents, the glider would have been effectively a small dot in the sky except for the last seconds. The power pilot had some clues, but it is still darn difficult to see other gliders sometimes. Heck, I've been in thermals where the other glider never saw me. |
"Jim Vincent" wrote:
"alexy" wrote in message .. . "Kingfish" wrote: Larry Dighera wrote: -on. It seems far more likely that this was not head on. From the glider's perspective the jet was an unmoving object somewhere in the sky, while from the jet's perspective, the glider was a moving object directly ahead. Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. If I read your logic, the jet is unmoving because it is in steady flight (not circling), so it stays in one position relative to the glider. Whereas the glider is circling and so moves back and forth to some extent. Well, given the small diameter of a thermalling glider, I think for all intents, the glider would have been effectively a small dot in the sky except for the last seconds. The power pilot had some clues, but it is still darn difficult to see other gliders sometimes. Heck, I've been in thermals where the other glider never saw me. You're probably right. It just seemed to me that talk about how hard a glider is to see head-on might not have been a relevant comment. And given their relative speeds, without working the math, I'd guess that the glider was probably at all times between the jet's 11:00 and 1:00, while the jet might have been in front of, behind, or at any point to the side of the glider. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
"Jim Vincent" wrote in message
. .. I think for all intents, the glider would have been effectively a small dot in the sky except for the last seconds. No, it's the Hawker that was a small (2 meters) motionless white dot in the white sky. The thermalling glider was an 18-meter white cross moving against the desert background. The jet was descending, wasn't it? That means no soot trail. Which, I am convinced, is the only part of the jet visible head-on from far enough to have any practical chance at all to evade, at glider speed. -- Yuliy |
Will be interesting to hear the glider pilot's perspective of where and from what angle he was hit. The glider pilot was circling when he was hit. He reported that he saw the jet just a blink before the impact with no possibility of evasive action. (How many of us have searched the sky in vain for a glider that was in full view. In my experience most circling gliders can be invisible until a wing catches some light. Obviously, that didn't happen in this case.) Hirao was one of five glider pilots from Crazy Creek at Minden for a few days of flying. I was supposed to be the sixth, but I arrived late and didn't complete rigging until 4pm, at which point I judged it not worth launching. All the gliders were in frequent communication. About three Hirao reported he was over the Pine Nuts at 13,000 and climbing in good lift. That was his last transmission. As near as we can tell, the jet hit his right wing, slicing off at least half of it. The canopy popped partially open, he pushed it the rest of the way and rolled out. As he floated down he could see the glider below him in a flat spin. It spun all the way to the ground. Our reconstruction is that the impact must have spun the glider counterclockwise. Otherwise the intact left wing would have lifted, ending the spin. The only injuiry Hirao sustained was a scratch on his right forearm when he landed in some bush. He refused medical attention, and we all enjoyed a very celebratory dinner in Minden that night. The glider was the ASG-29 that Rick Indrebo flew at the Worlds in Sweden in July. Herao was part owner of the glider, and this was his first flight. He'd just passed his BFR that morning. He has more than 800 hours in gliders. |
ups.com... The only injuiry Hirao sustained was a scratch on his right forearm when he landed in some bush. He refused medical attention, and we all enjoyed a very celebratory dinner in Minden that night. I live in Douglas County, flew with John at Flying Start...but the real question is...where did you celebrate and was the food and service good? - Curtis |
| Thread Tools | |
| Display Modes | |
| Midair near Minden | Fred | Soaring | 52 | September 1st 06 12:41 PM |
| Cloud Flying | Shawn Knickerbocker | Soaring | 48 | August 30th 06 08:21 AM |
| Refinish a Glider in Europe | Jim Culp | Soaring | 0 | November 18th 05 05:00 PM |
| Bad publicity | David Starer | Soaring | 18 | March 8th 04 04:57 PM |
| Newbie seeking glider purchase advice | Ted Wagner | Soaring | 19 | January 2nd 04 08:00 PM |
