Make sure to check the aircraft parts for deer fur or fuz.. evidence for the
insurance company. I've "dodged" more than a couple of shadows over the years.. always been on the luckier side of the out come. Never any damage to the plane.. only hit one... and that one thump was not good for the deer. Touch and Go in the Bone.. just at lift off a deer in the headlights.. never felt the thump but we had the SOF check the runway before we came back.. sure enough.. deer with broken back.. now which part of the B-1 did he hit?.. precautionary landing after they dragged the deer clear.. could only find some fur on the main gear trucks. Another night we hit a snowy owl on final.. spooked the co-pilot as he flashed past the wind screen, a tough and go turned into a full stop.. post flight check.. no windshield damage.. grease streak down the right side.. arched up and over the wing.. so he cleared the engines.. did leave some DNA evidence behind on some of the aircraft seams.. missed the tail. At Loring AFB ME, they used to have to check the runway at night for Moose, before the after dark departures and arrivals. The "Moose is Loose" air shows were always a good time. BT "John T" wrote in message m... It happened to me August 29, 2006. I went out for night currency with a short hop to Winchester, VA (KOKV). I flew there VFR since the only clouds in the forecast would be up in the Class A realm. Besides, I don't fly VFR in the DC ADIZ very often and I could use the practice there, too. The only interesting thing at KOKV were the birds. It's not often I see birds (not bats) flying around well after dark, but there were a few sandpipers flitting around Winchester. The flight home to Leesburg, VA (KJYO) from my night currency landings at Winchester was uneventful. The landing, on the other hand, had a bit of a surprise in store. Rounding out on final, I had the numbers nailed and came in over the threshold right at 65 MPH indicated (yes, MPH, not knots). Just after the nose gear touched, I saw a shadow cross the center line from right to left and into the beam of the landing light: Deer! A split second later came a thump and a slight pull to the right which was easily corrected. The engine remained running fine with no unusual vibrations or noises so I pulled off the runway at the first turn-off, cleaned up the aircraft and scanned around for damage. As my scan came to the starboard horizontal stabilizer, I saw in the faint light bent metal and busted fiberglass. It was painfully obvious the thump I'd felt was not something being run over by my landing gear as I'd desperately hoped, but rather a second deer. I parked the plane in its usual spot and assessed the damage. Sure enough, the starboard stabilizer had its leading corner busted and bent back with the rear corner twisted back over the trim tab. It was also twisted back enough that the corner connecting to the empennage was pulled out almost 2 inches. There was wrinkling on the starboard side of the empennage and vertical stabilizer and the beacon was knocked loose from the fiberglass cap. Well, "knocked loose" may be a bit of a misnomer as there was a bit of fiberglass still attached to the beacon which was left hanging by the power cords. The damage to the port side was worse as the force of the impact evidently twisted the entire tail section to the port side. Also, the impact appears to have severed at least one of the control connections as the control lock was in the yoke, but I was able to move the elevator almost from stop to stop. I walked back to the scene of the impact to pull the carcass off the runway - after all, there's no sense leaving it there for the next poor soul to land - but there was nothing on the runway. Not even a blood trail. The only apparent evidence of the culprit was the appearance of two pairs of green eyes reflecting my flashlight beam at the edge of the woodline west of the field and they ran off when I approached. After the damage done to the plane, I was hoping to have something to at least kick. All things considered, I was lucky. This may end up being minor compared to the damage that could have been caused had the first deer struck the prop. Pics and vids posted on my site for interested parties. -- John T http://sage1solutions.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
The state of Kansas reports about 10,000 deer/vehicle
collision a year, most are cars and trucks. My son lives in a very rural area and has had several vehicles damaged by deer, only one carcass recovered. Be sure to inspect the entire tail cone for remote damage caused by the lever effect of the strike. Good idea for all night landings at quiet airports, a noisy low pass to move the deer away from the runway. Not a perfect solution, but it should help. -- James H. Macklin ATP,CFI,A&P "John T" wrote in message m... | It happened to me August 29, 2006. | | I went out for night currency with a short hop to Winchester, VA (KOKV). I | flew there VFR since the only clouds in the forecast would be up in the | Class A realm. Besides, I don't fly VFR in the DC ADIZ very often and I | could use the practice there, too. | | The only interesting thing at KOKV were the birds. It's not often I see | birds (not bats) flying around well after dark, but there were a few | sandpipers flitting around Winchester. | | The flight home to Leesburg, VA (KJYO) from my night currency landings at | Winchester was uneventful. The landing, on the other hand, had a bit of a | surprise in store. | | Rounding out on final, I had the numbers nailed and came in over the | threshold right at 65 MPH indicated (yes, MPH, not knots). Just after the | nose gear touched, I saw a shadow cross the center line from right to left | and into the beam of the landing light: Deer! A split second later came a | thump and a slight pull to the right which was easily corrected. | | The engine remained running fine with no unusual vibrations or noises so I | pulled off the runway at the first turn-off, cleaned up the aircraft and | scanned around for damage. As my scan came to the starboard horizontal | stabilizer, I saw in the faint light bent metal and busted fiberglass. It | was painfully obvious the thump I'd felt was not something being run over by | my landing gear as I'd desperately hoped, but rather a second deer. | | I parked the plane in its usual spot and assessed the damage. Sure enough, | the starboard stabilizer had its leading corner busted and bent back with | the rear corner twisted back over the trim tab. It was also twisted back | enough that the corner connecting to the empennage was pulled out almost 2 | inches. There was wrinkling on the starboard side of the empennage and | vertical stabilizer and the beacon was knocked loose from the fiberglass | cap. Well, "knocked loose" may be a bit of a misnomer as there was a bit of | fiberglass still attached to the beacon which was left hanging by the power | cords. The damage to the port side was worse as the force of the impact | evidently twisted the entire tail section to the port side. Also, the impact | appears to have severed at least one of the control connections as the | control lock was in the yoke, but I was able to move the elevator almost | from stop to stop. | | I walked back to the scene of the impact to pull the carcass off the | runway - after all, there's no sense leaving it there for the next poor soul | to land - but there was nothing on the runway. Not even a blood trail. The | only apparent evidence of the culprit was the appearance of two pairs of | green eyes reflecting my flashlight beam at the edge of the woodline west of | the field and they ran off when I approached. After the damage done to the | plane, I was hoping to have something to at least kick. | | All things considered, I was lucky. This may end up being minor compared to | the damage that could have been caused had the first deer struck the prop. | | Pics and vids posted on my site for interested parties. | | -- | John T | http://sage1solutions.com/TknoFlyer | Reduce spam. Use Sender Policy Framework: http://spf.pobox.com | ____________________ | | |
The deer have a greater right to be there than you do bozo. The deer are on
the ground walking and you're flying around in an unnatural contrivance in order to satisfy your need for ego gratification. No sympathy here. "John T" wrote in message m... It happened to me August 29, 2006. I went out for night currency with a short hop to Winchester, VA (KOKV). I flew there VFR since the only clouds in the forecast would be up in the Class A realm. Besides, I don't fly VFR in the DC ADIZ very often and I could use the practice there, too. The only interesting thing at KOKV were the birds. It's not often I see birds (not bats) flying around well after dark, but there were a few sandpipers flitting around Winchester. The flight home to Leesburg, VA (KJYO) from my night currency landings at Winchester was uneventful. The landing, on the other hand, had a bit of a surprise in store. Rounding out on final, I had the numbers nailed and came in over the threshold right at 65 MPH indicated (yes, MPH, not knots). Just after the nose gear touched, I saw a shadow cross the center line from right to left and into the beam of the landing light: Deer! A split second later came a thump and a slight pull to the right which was easily corrected. The engine remained running fine with no unusual vibrations or noises so I pulled off the runway at the first turn-off, cleaned up the aircraft and scanned around for damage. As my scan came to the starboard horizontal stabilizer, I saw in the faint light bent metal and busted fiberglass. It was painfully obvious the thump I'd felt was not something being run over by my landing gear as I'd desperately hoped, but rather a second deer. I parked the plane in its usual spot and assessed the damage. Sure enough, the starboard stabilizer had its leading corner busted and bent back with the rear corner twisted back over the trim tab. It was also twisted back enough that the corner connecting to the empennage was pulled out almost 2 inches. There was wrinkling on the starboard side of the empennage and vertical stabilizer and the beacon was knocked loose from the fiberglass cap. Well, "knocked loose" may be a bit of a misnomer as there was a bit of fiberglass still attached to the beacon which was left hanging by the power cords. The damage to the port side was worse as the force of the impact evidently twisted the entire tail section to the port side. Also, the impact appears to have severed at least one of the control connections as the control lock was in the yoke, but I was able to move the elevator almost from stop to stop. I walked back to the scene of the impact to pull the carcass off the runway - after all, there's no sense leaving it there for the next poor soul to land - but there was nothing on the runway. Not even a blood trail. The only apparent evidence of the culprit was the appearance of two pairs of green eyes reflecting my flashlight beam at the edge of the woodline west of the field and they ran off when I approached. After the damage done to the plane, I was hoping to have something to at least kick. All things considered, I was lucky. This may end up being minor compared to the damage that could have been caused had the first deer struck the prop. Pics and vids posted on my site for interested parties. -- John T http://sage1solutions.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
("r. mutt" wrote)
The deer have a greater right to be there than you do bozo. The deer are on the ground walking and you're flying around in an unnatural contrivance in order to satisfy your need for ego gratification. No sympathy here. Who conferred upon deer this right? Montblack |
Well I guess I will have to right off this post as well. We do people
have to get into ****ing contests over **** that doesn't matter or isn't even related to the post whatsoever! How about wishing the fellow well and thanking goodness that he was able to walk away from this incident. I have been on short final in that same area with students{warrenton} and had to go around because the deer does the usual thing and looks at ya! I am now in SC flying and flying for a gentleman in and out of a grass strip in edisto sc. I have had deer looking at me as I taxi by them in the baron for take off. All the while praying "please stay in the woods please stay in the woods" Deer are a real serious hazard! I know a company that flew both a king air 90 and a Citation II and the owner hit a deer with king air totalling the king air. Now that is serious damage folks. I feel to many people take for granted the fact that nothing is coming out at you once down on the runway. In the circumstances stated the poor guy with the cessna had now chance of avoiding the impact. So take that into account folks even when we do everything right something can go terribly wrong! Ok enough of the profit of doom. Did i mention what a great day of flying we had here in SC/GA. I really love picking my way around t-storms{said in a sarcastic tone} YUM. Happy flying to all! matt tiberii CFI CFII Com asel amel ases Montblack wrote: ("r. mutt" wrote) The deer have a greater right to be there than you do bozo. The deer are on the ground walking and you're flying around in an unnatural contrivance in order to satisfy your need for ego gratification. No sympathy here. Who conferred upon deer this right? Montblack |
"Huck" wrote Well I guess I will have to right off this post as well. We do people have to get into ****ing contests over **** that doesn't matter or isn't even related to the post whatsoever! How about wishing the fellow well and thanking goodness that he was able to walk away from this incident. I think that was in the posts, back a bit. (quite a bit) It is usual to have thread drift, and opposing viewpoints, especially when it comes to animal rights, ect. The animal rights people are very vocal, and have strong beliefs, and there will always be someone to call them on it. So really, don't be so down. It really was a pretty minor escalation, all things considered. In case nobody did wish the guy well, and give thanks for his safety, I will. I've had a tangle with a deer, and it was only a 6 month old, but it sure busted up my car. There isn't a damn thing you can do about it; just say oh well, and go on with it. Same with this thread. See ya! -- Jim in NC |
"Huck" wrote in message
oups.com... I have been on short final in that same area with students{warrenton} and had to go around because the deer does the usual thing and looks at ya! I am now in SC flying and flying for a gentleman in and out of a grass strip in edisto sc. I have had deer looking at me as I taxi by them in the baron for take off. All the while praying "please stay in the woods please stay in the woods" Deer are a real serious hazard! I think that it depends upon the area of the country that you are in... While up in Iowa, I heard a lot about people hitting deer... While driving through Mississippi on the way from New Orlean to Iowa, I often encountered large numbers of deer on the side of the highway at night, but none of them got spooked and bolted across the road... Hell, I saw more deer along the highway in one spot than I have in multiple deer hunting seasons... My first flight into the Slidell, LA airport allowed me to be greeted by a turkey walking across the runway... As I'm rolling out towards him, he doesn't pick up speed or anything... He just continues his slow walk across the runway... I moved to the left side of the runway a bit and let him pass... My right wing probably went over the top of him, but he appeared totally unfazed by it... As if aircraft landing by him is a totally normal occurance... |
"r. mutt" nofishin.net wrote:
The deer have a greater right to be there than you do bozo. The deer are on the ground walking and you're flying around in an unnatural contrivance in order to satisfy your need for ego gratification. No sympathy here. LOL. Do you suppose the deer would have to show ID to the TSA had they spotted him/her running around on the runway? -- Peter |
The deer have a greater right to be there than you do bozo. The deer are on the ground walking and you're flying around in an unnatural contrivance in order to satisfy your need for ego gratification. No sympathy here. Huck: Just kill file this Bozo, who is obviously a troll, and go on with it. He is not worth getting your blood pressure up over. Notice I had to respond second hand, cuz I already had him in the dumpster. -- Jim in NC |
"John T" wrote in message m... It happened to me August 29, 2006. Well John, You will be happy to know that you will be able to safely fly to my local airport ELD soon without worrying about deer. They have just gotten federal funding to spend over $1 million to build a seven foot high fence all the way around the place specifically to keep deer out. The funds are out there so maybe you need to get your airport manager to work on getting some. |
| CRS VIEWS THE JOINT STRIKE FIGHTER | Mike | Naval Aviation | 13 | June 10th 06 01:37 AM |
| Tankers and strike packages (Was: EA-18G vs ES-3) | [email protected] | Naval Aviation | 0 | December 9th 04 12:11 PM |
| Hamas Leader Rantisi Killed by Israeli Strike on Car | Dav1936531 | Military Aviation | 13 | April 21st 04 08:04 PM |
| Joint Strike Fighter focus sparks concern | Otis Willie | Military Aviation | 0 | March 19th 04 10:19 PM |
