Denny, I completely agree with everything you said. If however, there's a chance that the owner might occasionally start the engine around 40Fdays without pre-heating (not exactly a temp that normally requiring pre-heating), the Phillips X/C 20W50, at only $40 a case, would be a better choice than Phillips 100AW or 100AD. Denny wrote: Pete, I have no criticism of your determination to maximize engine longevity... I have a pair of engines I'm babying along... Yes, I have rebuilt aircraft engines sob, sob... Let me play devils advocate here based on the additional information you have given to other posters.. 1. you run the engine regularily.. 2. you preheat in cold temps... So, let me be the first to say you are wasting your money on semisynthetic, multiviscosity oils! Yes, wasting your money, kemo sabe... You should be using a good, single viscosity oil, changing the oil religously at 25 hours, and your filter at 50 or 75 hours... Having that bright, golden, fresh, slippery, oil in the engine will do more to prevent wear than anything else you can do... Every branded oil company has an excellent, single viscosity, petroleum based oil, with Lycoming additive that they can barely give away... An industry secret that FBO's know... Let me suggest Phillips 100AW at less than half the price of 15W50, or 20W50 as a good oil to use... Now, this advice does not apply to engines that routinely go weeks between starts, that are started stone cold, etc.. There a semisynthetic, multiviscosity oil is probably the best - actually a new owner that runs them often is the best, but it's an imperfect world... The other habit I would forego is ground running... More engines than you can wave a stick at are burnt' up getting the oil temp "into the green"... By the time you run up and taxi to the runway that engine is ready to go.. The last comment I will make on this is that changing oil brand/type is guaranteed to obscure the analysis for 2 to 4 changes... No, I don't do oil analysis... I change my own oil, I cut open my own filters, i clean my own plugs, and I listen to my engines... Not perfect, but it's an imperffff, uhh, geez the echo in here is deafening... denny |
I don't think there's enough datapoint to draw a conclusion. That being aside, the benefit of using different brand of oil *pales* compared to simply adding 30% to your flying frequency. Just fly 30% more often. You don't even need to fly 30% more hours. Just go out one *extra* day every week (or two weeks) and fly for half an hour on top of your existing flying schedule. You'll do better to the engine than any fancy oil can possibly achieve. I for one, use the cheap Phillips X/C 20W50, change every 25 hours, and fly at least twice a week. |
Each of us has a hot button, but I'd be willing to bet that one cold start with marginal preheat would drive the metal analysis way off the chart. I have no problem with looking for a trend, but consider it for feedback to your operating guidelines too. |
nrp wrote:
Each of us has a hot button, but I'd be willing to bet that one cold start with marginal preheat would drive the metal analysis way off the chart. I have no problem with looking for a trend, but consider it for feedback to your operating guidelines too. No cold starts here, at least assuming my Tanis heater is working correctly. I am religious about plugging in the Tanis heater both at my home T-hangar and at my destination hangar if temperatures drop below 50 degrees F or so (this also prevents having to run the engine for a longer than normal time on the ground to bring the oil temperature up to the minimum of 120 for takeoff). When temps fall below 30 degrees F, I throw on the prop and cowling cover that I purchased a couple of years ago from Kennon in addition to the Tanis heater. -- Peter |
M wrote:
That being aside, the benefit of using different brand of oil *pales* compared to simply adding 30% to your flying frequency. Just fly 30% more often. You don't even need to fly 30% more hours. Just go out one *extra* day every week (or two weeks) and fly for half an hour on top of your existing flying schedule. You'll do better to the engine than any fancy oil can possibly achieve. Thanks, M. In my case, I fly a minimum of twice per week, every week now for over two years, as I use my aircraft to commute to my customers' cities of business. Toss in one Angel Flight every three weeks or so and at least two personal flights a month, and that brings up the flying total to about 12 legs per month. -- Peter |
Congrats! If that's your flying schedule, I don't see any reason why your engine won't make to the TBO and beyond, regardless of what brand of oil you use (right viscosity for the temperature of course), as long as the engine is operated properly. I'm sure most the A&Ps will have the same opinion about an engine that's flown twice a week. Peter R. wrote: In my case, I fly a minimum of twice per week, every week now for over two years, as I use my aircraft to commute to my customers' cities of business. Toss in one Angel Flight every three weeks or so and at least two personal flights a month, and that brings up the flying total to about 12 legs per month. -- Peter |
M wrote:
Congrats! If that's your flying schedule, I don't see any reason why your engine won't make to the TBO and beyond, regardless of what brand of oil you use (right viscosity for the temperature of course), as long as the engine is operated properly. snip You know, I was too quick to post my schedule. In retrospect, there are normally two weeks off a year due to the aircraft's annual, and in the last two years I have canceled three times due to weather and once due to unscheduled maintenance. Sorry 'bout the overstatement. -- Peter |
We switched from Aeroshell Multigrade 15w50 to the Exxon Elite 20w50 in
a Cherokee Six with a Lycoming 0-540-E4B5. We had decrease in metals as well. Decided to just stay with the Exxon. This was by no means a scientific study. We had 4 analsis before the change and are now up to 4 after. These were 40-50 hour changes in southwest Virginia in various seasons. The plane if flown roughly every 2 weeks year round. Peter R. wrote: With my rebuilt Bonanza engine, I have been faithfully sending in every oil sample drawn from the 40-50 hour oil change to Aviation Laboratories for an oil sample. When I receive the report from the lab, I log it to an MS Excel spreadsheet in order to catch any trends. Currently I have seven oil analyses logged over the 300 hours that this engine has on it. Normally I use Aeroshell Multigrade 15w50, but last winter I used Exxon Elite 20w50 for one of the oil changes under the assumption that it would combat corrosion that might occur from condensation build-up in the oil after engine-shutdown. An interesting data point has emerged that has me curious. All of the metals discovered in the oil analysis after using Exxon Elite were of significantly lower quantities when compared to the analyses from the Aeroshell multigrade, either before or after the use of the Exxon Elite. Is this just coincidence or does this indicate that perhaps Exxon Elite does provide better engine lubrication? My aircraft is a few hours away from an oil change and, as we approach winter in the Northeast, I am considering using Exxon Elite again. |
Robet Coffey wrote:
We switched from Aeroshell Multigrade 15w50 to the Exxon Elite 20w50 in a Cherokee Six with a Lycoming 0-540-E4B5. We had decrease in metals as well. Decided to just stay with the Exxon. This was by no means a scientific study. We had 4 analsis before the change and are now up to 4 after. These were 40-50 hour changes in southwest Virginia in various seasons. The plane if flown roughly every 2 weeks year round. Interesting. Thanks for sharing your observation. -- Peter |
Which metals showed a decrease?
Al 1964 Skyhawk Spokane, WA Robet Coffey wrote: We switched from Aeroshell Multigrade 15w50 to the Exxon Elite 20w50 in a Cherokee Six with a Lycoming 0-540-E4B5. We had decrease in metals as well. Decided to just stay with the Exxon. This was by no means a scientific study. We had 4 analsis before the change and are now up to 4 after. These were 40-50 hour changes in southwest Virginia in various seasons. The plane if flown roughly every 2 weeks year round. Peter R. wrote: With my rebuilt Bonanza engine, I have been faithfully sending in every oil sample drawn from the 40-50 hour oil change to Aviation Laboratories for an oil sample. When I receive the report from the lab, I log it to an MS Excel spreadsheet in order to catch any trends. Currently I have seven oil analyses logged over the 300 hours that this engine has on it. Normally I use Aeroshell Multigrade 15w50, but last winter I used Exxon Elite 20w50 for one of the oil changes under the assumption that it would combat corrosion that might occur from condensation build-up in the oil after engine-shutdown. An interesting data point has emerged that has me curious. All of the metals discovered in the oil analysis after using Exxon Elite were of significantly lower quantities when compared to the analyses from the Aeroshell multigrade, either before or after the use of the Exxon Elite. Is this just coincidence or does this indicate that perhaps Exxon Elite does provide better engine lubrication? My aircraft is a few hours away from an oil change and, as we approach winter in the Northeast, I am considering using Exxon Elite again. |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
