GPS clearance puzzle
Old December 1st 04, 07:37 PM
Stan Prevost
Roy, just curious, does the CNX-80 use the facility magnetic variation when
setting up a VOR radial in OBS mode? I believe the Apollo GX-60 does not.
I think the 430/530 does use the facility variation, and I wonder if Garmin
changed what the Apollo units do, either in the CNX-80 or going to the
GNS-480.
There is a four degree difference between facility variation and actual
variation at our local VOR. It would make two miles of crosstrack error at
30 miles from the VOR, usually not a big deal, but worth knowing about.
Stan
"Roy Smith" wrote in message
Apparently, if you file IFR HPN - MMU, you get a clearance which starts
"CMK CMK275R SAX039R SAX" (i.e. fly outbound on the CMK 275 until you
intercept the SAX 039, then fly that inbound to SAX). In the good old
days of 2 VOR receivers, this is trivial to fly; the radios don't know
or care that the cross-radial fix you're going to doesn't have a name.
But, how would you fly that with a GPS?
I've been puzzling over that one for a week or so now, and the best I
can come up with is to use the GPS's OBS mode to track outbound on the
CMK 275, and set up a VOR receiver to indicate the crossing radial.
Can anybody figure out a way to set it up purely on the GPS? I'm using
a CNX-80, but it might be interesting to see how other units would do it
too.
Old December 1st 04, 08:24 PM
John R. Copeland
From page 37 of the GNS 480 Pilot's Guide;
"NOTE: When using the OBS mode with a VOR station, the GNS 480
will use the station declination of the VOR.
For other waypoints, the GNS 480 will use magnetic variation based on
your present position."
In my opinion, it should use VOR station declination *only* in OBS
mode, but in Salem they chose to use it in all modes involving VORs.
That wasn't their original choice, but the UPS pilots wanted it that =
way.
---JRC---
"Stan Prevost" wrote in message =
Roy, just curious, does the CNX-80 use the facility magnetic variation =
when=20
setting up a VOR radial in OBS mode? I believe the Apollo GX-60 does =
not.=20
I think the 430/530 does use the facility variation, and I wonder if =
Garmin=20
changed what the Apollo units do, either in the CNX-80 or going to the =
GNS-480.
=20
There is a four degree difference between facility variation and =
actual=20
variation at our local VOR. It would make two miles of crosstrack =
error at=20
30 miles from the VOR, usually not a big deal, but worth knowing =
about.
=20
Stan
=20
"Roy Smith" wrote in message=20
Apparently, if you file IFR HPN - MMU, you get a clearance which =
starts
intercept the SAX 039, then fly that inbound to SAX). In the good =
old
days of 2 VOR receivers, this is trivial to fly; the radios don't =
know
or care that the cross-radial fix you're going to doesn't have a =
name.
can come up with is to use the GPS's OBS mode to track outbound on =
Can anybody figure out a way to set it up purely on the GPS? I'm =
using
a CNX-80, but it might be interesting to see how other units would do =
it
too.=20
Old December 1st 04, 10:47 PM
Stan Prevost
Thanks, John.
"John R. Copeland" wrote in message
That wasn't their original choice, but the UPS pilots wanted it that way.
---JRC---
when
Garmin
GNS-480.
at
Stan
too.
Old December 2nd 04, 03:29 AM
Roy Smith
According to the CNX-80 manual, facility variation is used in OBS mode
when the waypoint is a VOR, but not in Course-To or Course-From mode
(and not in OBS mode when the waypoint is not a VOR).
All things considered, I think that makes a lot of sense.
I just looked at the GX-60 manual, in the section on OBS mode. It
doesn't say one way or the other, which I assume means it does not take
variation into account.
Old December 2nd 04, 03:45 AM
John R. Copeland
"Roy Smith" wrote in message =
Roy, just curious, does the CNX-80 use the facility magnetic =
variation when=20
=20
According to the CNX-80 manual, facility variation is used in OBS mode =
when the waypoint is a VOR, but not in Course-To or Course-From mode=20
=20
=20
=20
I just looked at the GX-60 manual, in the section on OBS mode. It=20
doesn't say one way or the other, which I assume means it does not =
take=20
Roy:
I've never yet used the CNX 80 "Course To" or "Course From" in flight,
but the GNS 480 Windows Simulator appears to me that it uses
VOR station declination for those modes, as well as all other modes
whenever VORs are involved as waypoints.
---JRC---
Old December 2nd 04, 05:09 AM
Stan Prevost
The manual shows what data is included in the database for a VOR, and it
does not include facility variation.
Old December 2nd 04, 02:12 PM
Roy Smith
That would be another good clue that it doesn't use it :-)
Old December 2nd 04, 05:11 AM
Greg Esres
Hmmmm...does it appear this way on a flight progress strip? Duats
won't accept that sort of thing.
Old December 2nd 04, 05:52 AM
Newps
A flight progress strip would have a radial and DME.
Old December 2nd 04, 01:26 PM
Steven P. McNicoll
"Greg Esres" wrote in message
For ATC Flight Data processing the input would be CMK.CMK275..SAX039.SAX, it
appears on the strip without the dots.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 11:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 07:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 10:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 01:40 AM
