"Doug" wrote in message oups.com... The cost will go down. It costs no more to make a glass panel than the gyros they replace, maybe less. True, but the point is that you can only get a glass panel in a new plane, and a new plane is (and will continue to be) far more expensive than an "equivalent" new one. Most places are getting crunched badly enough on fuel as it is. For an idea of what it can cost, you can get an experimental AI replacement that has an AI, TC, VSI and probably some other stuff I've forgotten for under $2000. All electronic, with no mechanical gyros. And they work! Well if you cut the single biggest line-item expense out of anything you can cut the cost substantially. Certification will never get cheaper, nor will the delta in price between new and used airplanes. It's also unlikely that installing glass panels in used planes will prove economical in anything but big-ticket high-performance planes like Bonanzas. So the rest of us will have to wait a decade or so until they start becoming common on the used market, which they inevitably will. IFR IMC flight is mostly about what to do if something becomes non-functional anyway. So have lots of backups and know how to cross check to determine just what is going on. I'd disagree- moving from my 172, with two NAV/COMs, ADF, and Loran, to a G-1000-equipped 172, represents a dramatic step up in complexity. If someone is already used to flying with a GNS-430 then the transition will probably be straightforward, but for many of us there's a lot of new functionality to learn about, especially if you want to truly use the full integrated capabilities of the system, which is the point. However, I agree that in the long run, it will represent an improvement in safety and utility. There's no longer any question about where the future is. -cwk. |
I expect the panels will become more standardized or the insurance companies will step in and make something like that mandatory. That certainly hasn't been the case with air carrier and biz jet aircraft. For instance, the Falcon 900 (the biz jet with three engines) requires a new, separate type rating for the new 900EX. |
Yes!!!!!!
Gene Whitt |
| Best Option for Private Pilot to Multi Commercial Instrument Ratings | Hudson Valley Amusement | Instrument Flight Rules | 34 | December 17th 04 10:25 PM |
| Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 03:16 PM |
| Tips on Getting Your Instrument Rating Sooner and at Lower Cost | Fred | Instrument Flight Rules | 21 | October 19th 04 08:31 AM |
| Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 06:54 PM |
| Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 12th 03 01:25 PM |
