GPT (Gulfport MS) ILS 14 question
Old January 30th 05, 12:50 PM
Bill J wrote:
I think a lot of folks may not know what "VICE" really means!
True. The FAA is supposed to promote good human factors. "Instead of" would be
much clearer, but it's 9 characters instead of 5, and their NOTAM system is old
and clunky.
Old January 26th 05, 05:20 AM
Peter R.
A Lieberman ) wrote:
Looking at the approach, the IAF is CAESA. Outside the 10 NM ring, it says
2000 no PT, so, I would take it that no procedure turn is authorized, yet,
I see the procedure turn barbs just inside the 10 NM ring. Am I reading
this correctly that no procedure turns for the ILS is authorized outside
this 10NM ring, and if I was to do a full procedure approach that it must
be inside the the 10 NM ring??? Or what am I missing?
I am looking at the chart and seeing that there is another IAF at the
LOM (BAYOU). If you were coming from the southwest/southeast,
presumably you would use this IAF and hence, fly the localizer outbound
and execute the PT.
http://www.myairplane.com/databases/.../00576IL14.PDF
If you were coming from the north, you would fly to the CAESA IAF,
intercept the localizer at 2000 and fly inbound, not PT needed.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old January 26th 05, 05:23 AM
Stan Prevost
"A Lieberman" wrote in message
About to take a trip down to Gulfport MS (GPT) tomorrow morning.
Ceilings are forecasted to be 300 broken, so I really doubt that I will be
mucking around with full procedure approaches in the clag, but while I was
studying the approaches into GPT, I am kinda figuring on expecting vectors
for the ILS 14 approach based on forecasted winds.
says
This question is coming up, as when I got my flight briefing, the briefer
said, no procedure turn at CAESA from Victor 552 which in my opinion
agrees
with the approach chart, yet I see the procedure turn barbs outbound 268
and inbound 088 to intercept the localizer.
Any assistance in clearing up my question really appreciated.
Allen
A0008/05 (FDC 5/0505) - ILS OR LOC RWY 14, AMDT 14... CHANGE PLANVIEW NOTE:
PROCEDURE NA FOR ARRIVALS AT CAESA VIA V552 WESTBOUND VICE V522 WESTBOUND.
WIE UNTIL UFN
The only reason a briefer would discuss the details of an instrument
approach procedure is if there was a NOTAM pertaining to it. Somewhere in
your discussion with the briefer, the "procedure" vs the "procedure turn"
got mixed up.
Old January 26th 05, 03:06 PM
Roy Smith
I'm looking at the NOS plate
(http://204.108.4.16/d-tpp/0501/00576IL14.PDF)
The "2000 NoPT" is marking the straight-in segment from CASEA, but the
way it's drawn, it's really hard to see that. I don't have an en-route
for that area, but I would assume there are multiple airways that go to
CASEA. It boils down to this:
1) If you're arriving CASEA on V522 westbound, the whole procedure is
NA. Not just the procedure turn, but the whole procedure.
2) If you're arriving at CASEA on any other airway, then the procedure
TURN is NA, i.e. you go straight-in.
3) If you're arriving at CASEA from BAYOU (perhaps via MUDDA, MINDO, or
GPT VOR).
The cartography here is horrible. I would have drawn the PT barb much
closer in; this would have made it clearer that the NoPT note pertained
to the segment inbound from CASEA.
Does anybody have a Jepp plate handy? Does Jepp draw it any better?
The other problem is the "Procedure NA" terminology is confusing.
Everybody is used to talking about "procedure turn", and the brain just
naturally reads "procedure NA" as "procedure turn NA". I've seen that
mistake made several times (and made it myself). A better note would be
"Approach not authorized for arrivals from V522 westbound". That would
be less likely to be mis-read. I'm sure getting that change into TERPS
would only require about 10 years of debate and paperwork.
Old January 26th 05, 10:39 PM
Dave
It would be simpler if it said IAP not available. That would be clearer
"Roy Smith" wrote in message
be
was
vectors
says
yet,
GPT VOR).
Old January 27th 05, 02:12 AM
Peter Clark
They designate it with a note in the plan view near CAESA (it's a
Jepp note, inverse-video 1 next to CAESA, the text could appear
anywhere but happens to be right under CAESA for this procedure)
reading "Procedure not authorized for arrivals at CAESA via V522
westbound". Same effect if one isn't paying close attention to the
meaning of the text.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Question Charles S Home Built 4 April 5th 04 10:10 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
