"Mxsmanic" wrote in message
news ![]() How does pressing "direct to" replace a detailed flight plan? What do you do if the GPS fails? It's a non-issue. If the GPS failed before flight, then plan the flight the same way we were trained using the charts. If it fails during flight, more than likely you're heading in the general direction and have some idea where you are and how far to your next waypoint/airport, just pull out the chart... I've had a GPS in my plane the last 4 years. When I sold the plane, the buyer didn't want my GPS so I took it out. He wanted me to fly the plane to an airport that I hadn't been to before about 45 miles NE of here. I took off without the GPS, headed NE and compared the chart to what I was seeing on the ground. Found the airport without any problems. It would have been nice to have access to a GPS but we can still fly without one. Perhaps a greater miracle would be a cockpit quiet enough not to require hearing protection. Soundproofing a plane is possible but the added weight isn't worth it. A lot easier/cheaper to install and use (ANR) headsets. It's more expensive and complicated than it has ever been, in many respects, even if certain aspects of actually flying in the cockpit have become easier. There's planes that fly with only an airspeed indicator, compass, slip/skid indicator, engine gauges, and an altimeter. They fly fine without all the radios, GPS, transponder, electrical system, ANR, etc. |
"Greg B" wrote in message
... Soundproofing a plane is possible but the added weight isn't worth it. A lot easier/cheaper to install and use (ANR) headsets. Too bad the commercial flights don't issue ANR headphones for the passengers on some flights... Grace has been flying back and forth to Toronto lately in a Embraer RJ145 and according to her, they're rather noisy... Noisy enough that 31 dB earplugs are required in the passenger compartment... Noisy enough that she had to cup her hands over her earphones so that she could hear the music from her MP3 player... |
Greg B writes:
I've had a GPS in my plane the last 4 years. When I sold the plane, the buyer didn't want my GPS so I took it out. He wanted me to fly the plane to an airport that I hadn't been to before about 45 miles NE of here. I took off without the GPS, headed NE and compared the chart to what I was seeing on the ground. Found the airport without any problems. It would have been nice to have access to a GPS but we can still fly without one. Maybe you can fly without one, but is that true for all pilots? Soundproofing a plane is possible but the added weight isn't worth it. A lot easier/cheaper to install and use (ANR) headsets. If you stop using props, most of the noise disappears. There's planes that fly with only an airspeed indicator, compass, slip/skid indicator, engine gauges, and an altimeter. They fly fine without all the radios, GPS, transponder, electrical system, ANR, etc. In certain places, at certain times. -- Transpose mxsmanic and gmail to reach me by e-mail. |
you do if the GPS fails? *chuckle* Then, my boy, we have to NAVIGATE! Every pilot is taught how to do this, even if we'd rather just push "Direct to" and GO. GPS has only failed me once, back when I had a Lowrance Airmap 300. I took off solo from Maquoketa, IA in marginal VFR (after having some upholstery work done on our old Warrior), and as I climbed to pattern altitude I noticed that the GPS wasn't updating. It was just staring at me stupidly, showing me stationary on the ground. It was/is very unusual for me to fly solo, so I had some "three-handed flying" to do while I messed around with the stupid thing, trying to remember how to clear-start it whilst aviating into not the greatest visibility and ceiling. After a few minutes, I just said "To hell with it" and took up an approximate heading for home. Somewhere en route I managed to get the thing to re-boot, and was quite pleased to discover that I was precisely where I expected to be. Straight-line navigation isn't all that hard, it's just inconvenient compared to GPS. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck writes:
Then, my boy, we have to NAVIGATE! Every pilot is taught how to do this, even if we'd rather just push "Direct to" and GO. How often do they practice, just in case? -- Transpose mxsmanic and gmail to reach me by e-mail. |
On 2006-10-31, Mxsmanic wrote:
How does pressing "direct to" replace a detailed flight plan? What do you do if the GPS fails? Turn on the backup handheld unit? If the GPS fails, you aren't lost - you're on course. Anyone with Jay's experience should just be able to pick up the chart and eyeball it from thereon in, and perhaps tune in a couple of VORs. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
Dylan Smith writes:
Turn on the backup handheld unit? Are there handhelds certified for aviation use? -- Transpose mxsmanic and gmail to reach me by e-mail. |
experience should just be able to pick up the chart and eyeball it from thereon in, and perhaps tune in a couple of VORs. What MX doesn't understand (and, in fairness, it's not something non- or new pilots often DO understand), is that an experienced pilot of a well-equipped GA airplane has a plethora of navigational aids at his/her disposal -- not just GPS. I know before I flew I often wondered how in the *hell* those fellers in the sky knew where they were! Now, with dual VORs, DME, two GPS units on board, charts, experience, and two Mark Five eyeballs, it's hard to imagine a scenario where I *could* get lost. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2006-10-30, Jay Honeck wrote:
When I first started flying, flight planning was laboriously done with a sectional chart and a pencil. I would carefully plot my course, figure out VOR frequencies, plan waypoints where I could triangulate my position with multiple navaids, and make note of visual checkpoints. It could take 20 minutes to plan a 1-hour flight. It could take DAYS to plan a multi-day, truly "cross-country" trip. Even with manual flight planning, the time spent planning is more a function of experience. I had about 1000 hours when I flew my Cessna 140 coast to coast in the United States. It was all done by hand, and by looking out the window - the fun of the trip was partly in the navigating. It didn't take days to plan - indeed, planning took about as long as reviewing the charts and drawing a line (which I like to do when using GPS anyway, so I'm well aware of special use airspace). Also, with experience, you can divert off track and not have to go back to where you diverted - being able to match up ground features and map features becomes vastly easier with practise, as does estimating intercept courses and estimating ETE. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
"Dylan Smith" wrote I had about 1000 hours when I flew my Cessna 140 coast to coast in the United States. It was all done by hand, and by looking out the window - the fun of the trip was partly in the navigating. It didn't take days to plan - indeed, planning took about as long as reviewing the charts and drawing a line (which I like to do when using GPS anyway, so I'm well aware of special use airspace). How did you decide on stops, and such? Fuel would be nice to have at the airports where you stop, no? g -- Jim in NC |
| Disruptive Technology | Steelgtr62 | Home Built | 13 | October 24th 04 08:32 PM |
| USA India Dual Use Technology Transfers | Ravi V Prasad | Military Aviation | 2 | April 13th 04 10:21 PM |
| Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 11:13 PM |
| Soviet State Committee on Science and Technology | Mike Yared | Military Aviation | 0 | November 8th 03 11:45 PM |
| Science, technology highlighted at hearing | Otis Willie | Military Aviation | 0 | July 23rd 03 11:30 PM |
