How to tell my instructor to increase glidespeed with headwind?
Old November 2nd 06, 10:25 PM posted to rec.aviation.piloting
Dave Doe
Default How to tell my instructor to increase glidespeed with headwind?
says...
Back to the drawing board Dunc!
bloody top poster!
Duncan
Old November 3rd 06, 12:19 PM posted to rec.aviation.piloting
mike regish
That's wrong, too. Flying at minimum sink will get you the longest time in
the air-like you'd want if you had a tailwind and needed the distance.
Minimum sink is slower than best glide.
mike
----- Original Message -----
Newsgroups: rec.aviation.piloting
Sent: Thursday, November 02, 2006 4:02 AM
Subject: How to tell my instructor to increase glidespeed with headwind?
Yes, the greatest *distance* - if you *need* it. Otherwise, I think
he's right - fly at 65kts, and you get the longest time in the air
(something you're short of usually, when the fan dies).
But yep, you're right, *if* you need to get the distance to make the
field.
Duncan
Old November 2nd 06, 06:27 PM posted to rec.aviation.piloting
pgbnh
To prove the point to your instructor.
Ask him/her to consider a headwind of 65kts. What are the chances of
reaching the field with a GS=0 ?? What are the chances if GS0 ??
"Nik" wrote in message
Ok, my instructor did a simulated engine failure in the pattern; winds
were around 20kts in the air and 13kts on the ground. Did everything
perfectly; however after we took off again, he told me to maintain 65
kts next time, and I totally disagreed.
The manual says 65 kts for best glide speed; however that is in calm
air. As a glider person, I know adding about 1/2 the headwind component
will give the greatest distance.
After the flight I pulled up the Glider Flying handbook online and it
says:
"...it is apparent that flying a faster airspeed as the headwind
increases will result in the greatest distance over the
ground. If this is done for the polar curves from many
gliders, a general rule of thumb is found, namely, add
half the headwind component to the best L/D for the
maximum distance."
But even after telling him that he said that doesn't apply to power
planes, also saying that manuals never give best glide, and there has
to be a reason for that.
Do you guys have any ideas on how I can really convince him? Any good
sources?
Thanks!
-Nik
Old November 2nd 06, 07:26 PM posted to rec.aviation.piloting
Brian[_1_]
Ask him if 65kts is the best glide speed to get to the airport into a
65kt head wind.
I myself would use at least 90 as I am sure you would as well.
Brian
CFIIG/ASEL
says:
maximum distance."
sources?
Thanks!
-Nik
Old November 2nd 06, 10:51 PM posted to rec.aviation.piloting
Al G[_1_]
says:
maximum distance."
sources?
Thanks!
-Nik
Give your instructor the benefit of your background. As an instructor
for thirty years, I can say that i have learned a lot from my students. Some
of them had Mach 2+ experience and I was to solo them in a C-150.
Bet him a beer that you can outglide him under those circumstances.
Get him an introductory ride at a glider port...
Al G
Old November 3rd 06, 07:43 PM posted to rec.aviation.piloting
d&tm
says:
maximum distance."
sources?
I found this link very helpful
http://www.auf.asn.au/emergencies/aircraft.html
terry
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Air Force seeks to increase military participation in 8th annual . Otis Willie Military Aviation 0 June 18th 04 11:53 PM
