500 km Triangle at 306 km/hr in Argentina
Old December 23rd 06, 03:57 AM posted to rec.aviation.soaring
Paul Remde
Default 500 km Triangle at 306 km/hr in Argentina
I just received an e-mail from Argentina that contained the text below.
"Today, Dec 22nd 2006 at 1:00 AM UTC, Klaus Ohlmann called me on the phone
just after landing to let me know he have made a 500 Km flight at 306 km/h
on average in a Nimbus 4DM... this could be the first above 300 km/h and for
far, the fastest glider flight made under FAI rules."
306 km/hr = 190 mph = 165 knots
That is an amazing feat!
Congratulations Mr. Ohlmann!!!
Merry Christmas,
Paul Remde
Old December 23rd 06, 05:54 AM posted to rec.aviation.soaring
that is simply amazing.
ive spent about 1000 hours going slower than that with an ENGINE.
Merry Christmas,
Paul Remde
Old December 23rd 06, 06:30 AM posted to rec.aviation.soaring
Not bad for a glider with a VNE of 275 km/hr.
Merry Christmas,
Paul Remde
Old December 23rd 06, 06:39 AM posted to rec.aviation.soaring
JS
Yes, it is.
Anyone trying to beat that record should be certain their parachute is
in good shape, as the number of wings will likely total zero.
Old December 23rd 06, 07:54 AM posted to rec.aviation.soaring
Soarin Again
Yes, it is.
their parachute is
zero.
Does anyone know if his Nimbus 4DM has had special
modifications to increase the vne at altitude, or does
he just not care about operating limitations?
Soarin
Old December 23rd 06, 08:14 AM posted to rec.aviation.soaring
Greg Arnold
Soarin
When you are cruising at 20,000' to 30,000', doesn't the effect of
altitude cause IAS to be substantially less than ground speed?
Old December 23rd 06, 08:24 AM posted to rec.aviation.soaring
Marc Ramsey
Yes, it is.
their parachute is
zero.
306 km/hr true airspeed is 200 to 220 km/hr IAS at the 20000+ foot
altitudes used for these wave flights. Some gliders do require a
reduction in Vne at higher altitudes, but it isn't necessarily the case
that the limitation was exceeded.
Marc
Old December 23rd 06, 09:50 AM posted to rec.aviation.soaring
Marc Ramsey
Yes, it is.
their parachute is
zero.
If the 4DM follows the protocol used by the Duo (for which I have a
manual), Vne is IAS up to approximately 2500M altitude, then the
equivalent TAS from there up. If Vne for the 4DM is 275 km/hr, the TAS
limitation would be around 310 km/hr.
Old December 23rd 06, 09:57 AM posted to rec.aviation.soaring
Charles Crosby
That is indeed true. However, there are aeroelastic concerns (such as
flutter) which may result in a lower indicated vne at high altitude.
Charles
Old December 23rd 06, 01:16 PM posted to rec.aviation.soaring
Stefan
Vne goes with TAS, not IAS. But then, as it most probably was a wave
flight, there most probably was a wind.
Question, Diamond distance as unsuccessful triangle. Roger Aviation Marketplace 1 November 22nd 04 08:34 PM
Question, Diamond distance as unsuccessful triangle. Roger Soaring 1 May 13th 04 02:31 AM
Argentina ! Frank Noort Military Aviation 0 January 27th 04 10:47 PM
Flying in Argentina Jay Soaring 1 November 25th 03 05:52 AM
new records (Out&Return) for Delore-Fossett in Argentina cernauta Soaring 0 November 17th 03 03:06 PM
