Lean the mixture until it peaks and then enrichen it
(turn it back in) until it drops 50°C. Not necessary the best advice. Remember FULL rich for takeoffs and landings unless your flying at Leadville, CO or some other really high altitude airport. That is actually VERY BAD and DANGEROUS advice! You will need to lean for take-off at density altitudes of 3000 feet or above for max power. Actual airport elevation is irrelevant in this discussion, density altitude is all that matters. -- Thomas Borchert (EDDH) |
That is too much anyway, 50 C is 90 F, really 25 C is more
than enough. "Thomas Borchert" wrote in message ... | Lean the mixture until it peaks and then enrichen it | (turn it back in) until it drops 50°C. | | Not necessary the best advice. | | Remember FULL rich for takeoffs and landings unless your flying at | Leadville, CO or some other really high altitude airport. | | That is actually VERY BAD and DANGEROUS advice! You will need to lean | for take-off at density altitudes of 3000 feet or above for max power. | Actual airport elevation is irrelevant in this discussion, density | altitude is all that matters. | | -- | Thomas Borchert (EDDH) | |
Jim,
That is too much anyway, 50 C is 90 F, really 25 C is more than enough. That will put you right at the point of maximum internal combustion pressure (and mostly maximum CHT). Is that good for the engine? I doubt it. -- Thomas Borchert (EDDH) |
What damages the engine is excess oxygen and any combustion
temperature. Any mixture with a temperature drop means that there is excess fuel. 25 C is easy to see on the gauge and with a single probe assures that all cylinders are rich of peak. A multi-probe system is best as is fuel injection. At cruise power settings, you can lean aggressively. But only the pressure wave of detonation will damage the combustion chamber. -- James H. Macklin ATP,CFI,A&P "Thomas Borchert" wrote in message ... | Jim, | | That is too much anyway, 50 C is 90 F, really 25 C is more | than enough. | | | That will put you right at the point of maximum internal combustion | pressure (and mostly maximum CHT). Is that good for the engine? I doubt | it. | | -- | Thomas Borchert (EDDH) | |
"Thomas Borchert" wrote in message ... Lean the mixture until it peaks and then enrichen it (turn it back in) until it drops 50°C. Not necessary the best advice. Remember FULL rich for takeoffs and landings unless your flying at Leadville, CO or some other really high altitude airport. That is actually VERY BAD and DANGEROUS advice! You will need to lean for take-off at density altitudes of 3000 feet or above for max power. Actual airport elevation is irrelevant in this discussion, density altitude is all that matters. -- Thomas Borchert (EDDH) Ok confession time: I've never been PIC with a controllable prop. 3000 feet density altitude fits with 75% power in the POHs that I recall reading for trainers with fixed pitch props. OTOH, high power levels are available to a higher density altitude with a controllable prop--consult the POH. If the POH is old, consult the engine manufacturer. (I really wish that I could say "consult an instructor or mechanic at the local FBO" ) Peter |
Peter,
OTOH, high power levels are available to a higher density altitude with a controllable prop. They are? How would that work? (flying a Tobago with CS prop) -- Thomas Borchert (EDDH) |
... Peter, OTOH, high power levels are available to a higher density altitude with a controllable prop. They are? How would that work? (flying a Tobago with CS prop) -- Thomas Borchert (EDDH) Full RPM on a CS prop is usually higher than the fixed pitch prop will allow under most conditions of flight--especially take off and climb. Peter |
Peter Dohm wrote: 3000 feet density altitude fits with 75% power in the POHs that I recall reading for trainers with fixed pitch props. 75% is available to about 8000 feet, depends on temp. OTOH, high power levels are available to a higher density altitude with a controllable prop--consult the POH. Yes, indeed, consult the POH. The prop is irrelavant to the discussion unless you've installed one hell of a cruise prop that just won't turn up. |
Mxsmanic wrote: Up to now when flying in simulation, I've had the simulator take care of engine mixture adjustments. However, since I'd have to do this myself in real life, I've decided to make some modest attempts at managing mixture myself. Making whole-hearted attempts may prove most effective. ----- - gpsman |
gpsman writes:
Making whole-hearted attempts may prove most effective. One step at a time. -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Emergency Procedures | RD | Piloting | 13 | April 11th 04 09:25 PM |
| My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 06:02 PM |
| Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 07:11 AM |
