Capt.Doug,
OK, so should I say something like "leaving FL290 for 12000 at CLARR," assuming I'm already cleared to descend at my discretion? Sounds professional. Actually, no, it doesn't. The word "for" is to be avoided because it sound the same as "four". It sounds like many airline pilots (just like "twelve hundred" or "with you"), but professional it is not. -- Thomas Borchert (EDDH) |
Thomas Borchert writes:
Actually, no, it doesn't. The word "for" is to be avoided because it sound the same as "four". It sounds like many airline pilots (just like "twelve hundred" or "with you"), but professional it is not. Which airline do you fly for, again? -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Thomas Borchert" wrote in message
Actually, no, it doesn't. The word "for" is to be avoided because it sound the same as "four". It sounds like many airline pilots (just like "twelve hundred" or "with you"), but professional it is not. Let's split hairs- I am aware of the Flying Tigers' accident. However, 'four' followed by 'twelve' is hard to confuse. 'four one two thousand' doesn't make sense either. Professionals are admonished to be concise and efficient in their transmissions. In that sense, and because Maniac did say that he was already issued the crossing restriction, "Leaving FL290" would be better. D. |
Capt.Doug writes:
MCP = max continuous power? Mode Control Panel--the gadgets on the glare shield that control the autopilot. So I set the ALT HOLD parameter on that to prevent the FMS from going below a certain altitude on its own. The important thing is to not set the altitude hold for descent until cleared by ATC. Up to now, I've been setting the altitude above my cruise for the climb, and then below the airfield for my descent, thus preventing it from ever limiting the FMS. But it now appears that I should be using it to make sure I don't overstep any ATC instructions. So if they say climb and maintain 5000, I set 5000 until I get new instructions, thus preventing the FMS from taking me all the way to cruise altitude before I've been cleared for it. I note, however, that I'm often cleared for a higher altitude before reaching the previously cleared altitude, so sometimes I just keep a hand near the altitude setting on the MCP, ready to adjust it if I have to, while letting the FMC do its thing. A good center controller will have all of the arrivals spaced like pearls before everyone hits the arrival's gate. The quality of controllers in simulation is quite variable, but the good ones are just as good as real controllers (sometimes they _are_ real controllers, who, for some reason, like to simulate their work when they aren't doing it for real--I guess some people really like their jobs). The most common is a clearance to cross a fix at an assigned altitude (crossing restriction). Say for example you are cruising at FL290 and the controller isues you a clearance to cross a fix at 12000'. It is your perogative as to when to start your descent so long as you cross the fix at the assigned altitude. OK, I've had those. I'll remember to treat them as an implicit clearance to descend or climb to the specified altitude at my discretion. During the climb, ATC sees the final altitude we requested on our flight plan. They try to get us up there, traffic permitting. After that we request from ATC any altitude changes we want and they work us to that altitude, traffic permitting. Do you often need a different altitude from the one you filed? Perhaps for fuel considerations, or headwinds, or something? "DESCEND via the Korry 3" Ah ... see, I would have interpreted that as more restrictive, i.e., meaning that I should change altitudes but that my heading should not change. I guess it's the other way around. And I suppose it doesn't make much sense that you'd be cleared to descend via the STAR and yet not be cleared to follow it laterally, now that I think more about it. No, because seperation wasn't lost. So what do they say in this telephone call? Sounds professional. Cool. Now if I can just say it with a Texas drawl. In the IFR world, altitude is all important. There are crossing restrictions and block altitudes, but most of the time we follow I would have thought that altitude and track would both be about equally important. In the real world we usually follow the arrival procedures with the altitudes as published. When flying the big jets, just remember that you will need 3 miles for every 1000' you want to descend plus another 5 miles to slow for the 250 knot speed restriction at 10000'. I have discovered that it's much harder to move large jets towards the ground than it is to move them towards the sky. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Mxsmanic" wrote in message Do you often need a different altitude from
the one you filed? Perhaps for fuel considerations, or headwinds, or something? Often times our actual weight will be slightly different from the flight planned weight requiring 2000' up or down for fuel optimization. Turbulence is another reason to change altitudes, sometimes 10000' or more. A 2000' change in altitude usually doesn't make enough difference in headwinds to justify the increased fuel burn of changing altitudes. Sometimes we are just plain stuck at an inefficient altitude because of same direction traffic. So what do they say in this telephone call? Along the lines of 'Now you know- don't do it again". I would have thought that altitude and track would both be about equally important. They are both important, however altitude leeway is +/-300' whereas airways have .5 to 4 miles of leeway. D. |
Capt.Doug wrote:
"Mxsmanic" wrote in message So it would probably be best to set the MCP to prevent any descent until I'm cleared, then? MCP = max continuous power? Sorry- not familiar with the term as used on an FMS. The important thing is to not set the altitude hold for descent until cleared by ATC. Mode Control Panel |
Just out of curiosity, what simulator are you using?
Gus EGYC "Mxsmanic" wrote in message news ![]() I fly from KLAX to KLAS, using the FMC to handle most of the flight. With the routing I put in, the FMC decides on some default altitudes and includes required altitudes for the arrival and departure procedures I select. Part of what it does is to create a descent schedule from the nominal cruise altitude to the arrival procedure. So I leave KLAX and my last explicit instruction from ATC is "climb and maintain FL290," which is my programmed and filed cruise altitude. Now, my question is this: If the FMC has a programmed descent in its route, do I let the FMC start the descent where it sees fit, or do I force the aircraft to maintain FL290 until ATC explicitly clears me for my own navigation or for a lower altitude? And if ATC's last instruction had simply been "resume own navigation" or "proceed as filed," would that mean that I'd be free to begin the descent whenever the FMC (or I) decides it's best? In situations where I can begin the descent at my discretion (assuming that own navigation implies this), should I tell ATC that I'm leaving my cruise altitude? If the FMC has a continuously changing estimate of lower altitudes in the descent profile, what should I give as my target altitude? The next fix that has a specific altitude? (Such as a fix in the arrival procedure) Climbing I think I understand. If I'm told to resume own navigation, or cleared as filed in the first place, I climb per my flight plan/FMC profile. If ATC says maintain X, I stay at X until ATC tells me to resume own navigation or instructs me to change altitudes. But the descent part still has me a bit confused. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Gus Cabre writes:
Just out of curiosity, what simulator are you using? Microsoft Flight Simulator 2004. However, I use the PMDG 737-800 add-on aircraft, which is equipped like the real thing (practically a different world as compared to the default 737 in the simulator). I also use the Dreamfleet Baron 58 add-on, which, again, is also in a category of its own. Both are renowned for their uncompromising realism with respect to the real aircraft. I also have a separate joystick and throttle, and rudder pedals. Anything fancier is hard to justify at this time. I fly a mixture of VFR and IFR on the Baron, and mostly IFR on the 737. I also use VATSIM, the leading virtual flight network, so that I can interact with other human pilots and controllers by radio, rather than just interact with the computer-generated stuff provided by MSFS when it is in offline mode. All in all, the realism is striking, and much better than some detractors like to believe. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: All in all, the realism is striking, and much better than some detractors like to believe. How do you know? |
Judah writes:
How do you know? The honest ones admit it to me. -- Transpose mxsmanic and gmail to reach me by e-mail. |
