Probably the temperature. At 25" MP and 2520 rpm, I'd guess you would
be running about 78% power under standard temperature conditions (15C?). But at -1C the denser air is giving you additional power output so you're probably closer to 80%. This is harder than most of us would be willing to run at 5000 ft. Peak EGT at this power setting is also asking for engine detonation. |
Paul kgyy writes:
Probably the temperature. At 25" MP and 2520 rpm, I'd guess you would be running about 78% power under standard temperature conditions (15C?). But at -1C the denser air is giving you additional power output so you're probably closer to 80%. OK. That sounds like enough to account for the difference in speed (?). This is harder than most of us would be willing to run at 5000 ft. My virtual funds are unlimited, but in real life, with a limited budget, I'd be far more conservative. Peak EGT at this power setting is also asking for engine detonation. I haven't noticed anything, but I don't know if this is simulated (and I'm not even sure that it occurs to a significant degree, as there seems to be a lot of disagreement on that). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Paul kgyy writes: Probably the temperature. At 25" MP and 2520 rpm, I'd guess you would be running about 78% power under standard temperature conditions (15C?). But at -1C the denser air is giving you additional power output so you're probably closer to 80%. OK. That sounds like enough to account for the difference in speed (?). The power chart in your POH should tell you how to adjust the manifold pressure for nonstandard temperature conditions. |
Paul kgyy writes:
The power chart in your POH should tell you how to adjust the manifold pressure for nonstandard temperature conditions. It says maximum cruise power at 20° rich of peak, 25" MP, 2500 RPM, for minus 20 degrees OAT, with the best listed performance at 6000 feet (approximately 200 KTAS), although I'm at 5000 feet because I'm IFR and that's not on the chart. That's about what I'm getting now (211 KTAS with the same settings, as close as I can get them). Economy cruise is about 40 kts slower, but I have virtual cash to burn. The cold air doesn't help performance, according to the POH chart. Maybe it's the adjustments I'm making; I've only recently started adjusting mixture and prop myself (I used to let the sim do it). -- Transpose mxsmanic and gmail to reach me by e-mail. |
be running about 78% power under standard temperature conditions (15C?). But at -1C the denser air is giving you additional power output so you're probably closer to 80%. This is harder than most of us would be willing to run at 5000 ft. Peak EGT at this power setting is also asking for engine detonation. I might have to read ordinary threads while his sim is getting new cylinders. Peter |
Peter Dohm wrote:
I might have to read ordinary threads while his sim is getting new cylinders. Hopefully the motherboard is still under warranty. |
Peter Dohm wrote: Probably the temperature. At 25" MP and 2520 rpm, I'd guess you would be running about 78% power under standard temperature conditions (15C?). But at -1C the denser air is giving you additional power output so you're probably closer to 80%. This is harder than most of us would be willing to run at 5000 ft. Peak EGT at this power setting is also asking for engine detonation. I might have to read ordinary threads while his sim is getting new cylinders. He must have gotten his monitor onto the step :-) |
george wrote: He must have gotten his monitor onto the step :-) George, you really made me smile with that comment :-) Extremely clever, inside pilot joke... and not mean. Thanks! Kev |
Paul,
under standard temperature conditions (15C?). 5 C, actually. 15 is standard on the ground. You lose 2 per 1000 feet in a standard atmosphere. -- Thomas Borchert (EDDH) |
| Crosswind Landings... But airspeed? | Jmarc99 | Soaring | 21 | October 4th 05 08:54 PM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| speed record set by scramjet - fair? | Don French | Piloting | 55 | November 28th 04 02:57 PM |
| Space Elevator | Big John | Home Built | 111 | July 21st 04 05:31 PM |
| Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 4th 03 12:53 AM |
