On 03/28/07 14:19, Gig 601XL Builder wrote:
Robert M. Gary wrote: On Mar 28, 12:30 pm, Blanche wrote: Robert M. Gary wrote: A fast Cherokee is also known as a Mooney C model. Hm...I always thought "fast cherokee" was an oxymoron... And yes, I own a cherokee 180. Would I like faster? Sure! Wouldn't everyone? I think part of my point is that the price of the 180 and the M20C are pretty close. I'm not sure why people choose the 180 when its a good 30 knots slower on the same fuel burn. -Robert I agree with you but I'd bet insurance and the cost of up keep added because of the retrac gear has a lot to do with it. Not to mention I could fit in a 180, but not a Mooney (although that is changing...) |
Blanche wrote in news:1175110215.538586
@irys.nyx.net: Robert M. Gary wrote: A fast Cherokee is also known as a Mooney C model. Hm...I always thought "fast cherokee" was an oxymoron... And yes, I own a cherokee 180. Would I like faster? Sure! Wouldn't everyone? Well there was an article about a guy in Sport Aviation a few years ago who had his 140 cruising at some insane airspeeds. He had a 160 engine in it IIRC, but more importantly he had done a lot of mods to the airframe, particularly wingtips, vortice generators and fairings for the gear, flap hinges and so on. Each mod multiplied the good of the other mods, of course, so he was happily whistling along at speeds that were simply amazing. As far as I know, he does sell the STCs he got for the airplane, but I couldn't find him wiht a quick search. I think he was in SA about three years ago but the wife will kill me if I pull the pile out and go through it in the living room again. I'll post it if i see it. ALC |
Nathan Young wrote:
So my question: How much drag does a wing on a Hersey Bar Cherokee generate, and and hypothetically speaking, how much faster could the plane go if it was retooled with a sleek, composite wing? You may take the other side of your question. You choose a composite plane (ie Lancair) with the same engine. You take the 75% cruising speed of the lancair (V-lancair) You take the Cherokee 75% cruising speed (V-cher) If you want the same speed for your plane, you need more HP The formula is HP=180 * (V-lancair/ V-cher)³ You may do the reverse: how many HP the lancair need for the Cherokee speed.... You know the cost of drag.... But don't think all drag is from wing, part of drag is from fuselage and a roomy fuselage will generate more drag. But the comfort is in roomy fuselage By -- Volem rien foutre al païs! Philippe Vessaire Ò¿Ó¬ |
On Wed, 28 Mar 2007 13:51:57 GMT, Nathan Young
wrote: I have a Cherokee 180, with the short hershey bar wing. While I love the plane, I always wish it could go a bit faster, or use a bit less fuel to get to my destination. With about 375 hours in a Cherokee 180 and about 1200 in a straight tail Beechcraft (Debonair) my take it this. I like the 180 better than the Archer even though the Archer lookes nicer with that taper wing and is a bit faster. That constant cord, thick wing makes the 180 one of the most docile airplanes you will find and it still has pretty good performance. Very good climb and tremendous at getting into short fields with the steep descent. I can't see as a gallon or two over the range of the Cherokee, or Archer is going to be worth worrying about....although we did have one guy land ours with 1/2 gallon of fuel on board (all in one tank). He'd flown the same trip (St Louis Mo to Midland, MI) so many times he never paid any attention to the time and this time coming home he had one bodatios head wind. (and a LOT OF LUCK! Having flown Both the 180 and the Deb in torrential rain I can say I'd much prefer a thicker windsheild to prettier wings. It was deafening! As to fuel, we flew the 180 down to Muncie IN to pick up the Deb. My friend took off well ahead of me, but I passed him before we reached Ft Wayne. I was back in Midland, had the Deb put away in the hangar and was having a cup of coffee in the terminal building when I head him call in. When they filled the Cherokee up, I found I had used less than one gallon more to cover the same route at close to 190 MPH. I had to ferry the Deb up to HTL to have some work done on the gear which meant leaving it down. Now that's using gas. The speed was about the same as the Cherokee but burning about 14 1/2 GPH. I have followed the composite homebuilding movement for many years, and am amazed at the sleekness of a composite wing. The wings on most composites tend to be the complete opposite of a Hersey bar wing: high aspect ratio, low thickness, no rivets, no screws for fuel I'm glad you said most. I'm building a Glasair III and a high aspect ratio it doesn't have. Wing span is a tad over 23' with a 4' wide fuselage in the middle so that makes each wing about 9 1/2 feet long. It also has almost 30# per square foot of wing loading on that tiny wing but it sure does go. Built like a tank too. If you think the 180 has a steep descent you should fly a G-III once. :-)) Normal is about 2000 fpm power off. tanks,smooth curves faired into airframe, and streamlined landing gear structure. So my question: How much drag does a wing on a Hersey Bar Cherokee generate, and and hypothetically speaking, how much faster could the plane go if it was retooled with a sleek, composite wing? That's a diffiuclt question to answer because there are so many variables. You could easily end up with a wing that could travel far faster than the rest of the structure could handle. On the Cherokee the landing gear presents a lot of drag. To maintain at least the handleing characteristics of the Archer you probably ould not get much faster than an Archer. To simply replace the wing with a composit one of the same design would most likely make little difference. All airplanes are a group of compromises. The 180 is the only plane I've ever flown where I could put it into a full stall, hold the elevator full up and still use the ailerons in turns. (with careful application) Almost any changes are going to result in a plane that is less forgiving. It's very difficult to hold the Deb in a stall without having it drop a wing. It's like balancing on a tight rope and if you touch an aileron to raise a wing, that wing will instead go down (abruptly) and you will most likely roll into a spin. Speed comes at a price. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
The composite construction makes a big difference in making possible the use of supercritical airfoils. These airfoils need a slick surface, so much so that flying in rain degrades their performance to the point that they can become dangerous. You'd never build a wing like that using sheet metal and rivets. Just the lap joints or any waviness in the aluminum would cause trouble. Composite looks nice, but I became allergic to some of that stuff way back in the '70s. And in the cold winters here I've seen it crack and delaminate. My preference is for something more resistant to everyday life. Kinda like my old truck. Dan |
| Hershey bar wing vs composite wing - how much drag? | Nathan Young | Owning | 33 | March 30th 07 08:47 AM |
| High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 12:10 PM |
| composite wing, wing spars | Dave Schneider | Home Built | 4 | May 21st 04 06:35 AM |
| Fuel Dip Tube for Hershey-bar Wing Cherokees? | Bob Chilcoat | Owning | 3 | May 3rd 04 11:29 PM |
| Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
