DA 42 accident
Old April 24th 07, 11:47 PM posted to rec.aviation.piloting
Friedrich Ostertag
Default DA 42 accident
Neil Gould wrote:
Recently, Friedrich Ostertag
posted:
Karl-Heinz Kuenzel wrote:
Hi.
Here in Germany we had an accident with a brand new DA 42 in Speyer
(EDRY) on 3-4-07 during take off.
It seems, that the battery was down and both engine were started
with remote power.
After take off when retracting the gear, the props feathered and
both engines stopped.
You can read about that accident in German (sorry) in
www.pilotundflugzeug.de
First hearing about that accident and the background, I could not
believe it.
I don't even know where to start. How can an aircraft, that depends
on electrical power for the operation of it's engines, be airworthy
without fully redundant electrical systems? While in this particular
case the pilot might have noticed the problem, had he meticuously
follow procedures and started the second engine at the plane's own
power, it is quite easy to find failure modes that would go unnoticed
inflight, yet cause double engine failure at the instant the gear is
lowered on final. Lead batteries are known to occasionally go flat
suddenly, once the buildup of oxide makes contact between the lead
elements. Happened to me in the car once. The engine (a diesel with
mechanical injection pump) ran happily without me even noticing the
failure until I shut it down. When I turned the power back on again,
not even the lights in the dashboard would light up, it was
completely and utterly dead.
I would never have thought that they cut corners like that at
Diamond. I Hope this will not create a lot of mistrust in
aerodiesels, as it is not a diesel issue. I guess you could call it a
FADEC issue if you wanted, however it really is an issue of
redundancy of essential systems, and easily solveable as such.
I have a somewhat different take on this event. It appears to me that
the pilot didn't sufficiently understand his aircraft or the
implications of the symptoms he observed. Knowing that there was
insufficient power to start the engines, that the engine & prop
controls were dependent on electric power and that the landing gear
used an electric motor would have stopped me from taking off until
the battery/electrical system problem was addressed.
Well said, and I wouldn't disagree. However, the very same potentially
deadly failure could occur anytime the battery fails inflight, with no way
for the pilot to know about it before he actually hits the button to lower
the gear. That alone appears to me to be a major design flaw that would make
me pretty uncomfortable, batteries are known to fail suddenly sometimes. I
really would expect redundancy in something as critical as the power supply
for the fadec to be a requirement for airworthyness. Why have two sets of
magnetos on the typical SI-engine? It's just an electrical system, too...
Why have a twin engined aircraft?
I don't find it
surprising that the props feathered in this situation, and would even
say that it would be the expected behavior, rather than a fluke of
some kind.
If you are saying that a shut-down is to be expected when the power supply
on a fadec controlled engine fails, you are right. No modern engine will
continue running without electrical power. Even on a diesel with common rail
fuel supply (as the thielert is) without electricity no fuel injection is
possible.
regards,
Friedrich
Old April 25th 07, 02:08 AM posted to rec.aviation.piloting
John Theune
Friedrich Ostertag wrote:
posted:
Hi.
with remote power.
believe it.
I don't find it
some kind.
possible.
regards,
Friedrich
This is a cut and paste from a AOPA story on the plane
There are three batteries. The main battery is a 24-volt 10-amp-hour
size. Electrical power is provided by two 24-volt 60-amp alternators —
one on each engine. There also is a 24-volt 1.3-amp-hour
alternator-excitation battery to provide alternator start-up
(excitation) voltage if the main battery is discharged below the
required excitation threshold. The third battery is a stand-alone
emergency battery that powers the electric artificial horizon and an
instrument floodlight for one and a half hours.
The question then become if there are 2 60AMP alternators and a single
10AMP-hour battery how could the battery being dead cause the issue. I
think there is much more here then meets the eye. Perhaps we should
wait for more data before we jump to conclusions.
Old April 25th 07, 03:25 AM posted to rec.aviation.piloting
C J Campbell[_1_]
On 2007-04-24 14:47:11 -0700, "Friedrich Ostertag"
said:
posted:
Hi.
with remote power.
believe it.
the gear.
No. This was not caused by a battery failure per se. It was a failure
of the electrical excitation system which starts the alternators. That
should prevent the engine from starting and it did. However, the pilot
bypassed that by starting both engines (a big no-no) with external
power. The battery is not actually used in-flight to keep the engines
running. The alternators are used for that, with a generator backup,
and finally a battery for backup, with warning lights all over the
place. Once the plane is flying, assuming the alternators start out
working, you would practically have to have a major electrical fire to
duplicate the problem. But take off without a working alternator and
you have a big problem.
Waddling Eagle
World Famous Flight Instructor
Old April 25th 07, 01:43 PM posted to rec.aviation.piloting
Neil Gould
Recently, Friedrich Ostertag posted:
posted:
Hi.
with remote power.
believe it.
unnoticed inflight, yet cause double engine failure at the instant
the gear is lowered on final. Lead batteries are known to
occasionally go flat suddenly, once the buildup of oxide makes
contact between the lead elements. Happened to me in the car once.
The engine (a diesel with mechanical injection pump) ran happily
without me even noticing the failure until I shut it down. When I
turned the power back on again, not even the lights in the
dashboard would light up, it was completely and utterly dead.
a FADEC issue if you wanted, however it really is an issue of
no way for the pilot to know about it before he actually hits the
button to lower the gear. That alone appears to me to be a major
design flaw that would make me pretty uncomfortable, batteries are
known to fail suddenly sometimes. I really would expect redundancy in
something as critical as the power supply for the fadec to be a
requirement for airworthyness. Why have two sets of magnetos on the
typical SI-engine? It's just an electrical system, too... Why have a
I agree that a failure mode allowing in-flight engine shutdown due to low
battery voltage implies that there may be an aspect of the design that
needs attention. On the other hand, the dead battery could have been a
symptom of a larger problem, and the existing design really is quite
reasonable.
I don't find it
some kind.
supply on a fadec controlled engine fails, you are right. No modern
engine will continue running without electrical power. Even on a
diesel with common rail fuel supply (as the thielert is) without
electricity no fuel injection is possible.
Right, however, the alternator should be able to supply the electricity
needed to keep the engines running. It wouldn't surprise me to find that
the a breaker had popped when the landing gear was retracted and the pilot
didn't think to reset it.
Neil
Old April 24th 07, 05:25 PM posted to rec.aviation.piloting
Thomas Borchert
Karl-Heinz,
believe it.
And that may well be wise. There is no official accident report yet.
Thomas Borchert (EDDH)
Old April 25th 07, 03:07 AM posted to rec.aviation.piloting
C J Campbell[_1_]
On 2007-04-22 04:23:22 -0700, Karl-Heinz Kuenzel
said:
Hi.
It seems, that the battery was down and both engine were started with
remote power.
After take off when retracting the gear, the props feathered and both
engines stopped.
You can read about that accident in German (sorry) in www.pilotundflugzeug.de
First hearing about that accident and the background, I could not believe it.
Karl
If you have to start both engines with remote power it seems to me that
is should be obvious that the electrical system is not working. If it
doesn't work with one engine running it is not going to work with them
both running.
According to the article, the battery was so dead that it could not
excite the alternator -- the alternator needs some current in order to
start. For example, if you hand-prop a single engine piston airplane
that has a dead battery, you might get the engine to run but you still
will not have an electrical system. The article complains about there
being a "single point of failure" for the plane, but in fact most small
aircraft have the same single point of failure. In the case of the
DA-42, however, electrical current is needed to keep the engines
running. This is a big difference from the piston engines most of us
are used to. This turns an electrical failure from a nuisance to
something deadly. The excitation battery system is needed to run the
ECU for each engine. Although each engine has its own bus, both are
dependent on the excitation battery system. If that fails, both engine
buses and the main bus go down. Since the excitation battery system
does not have anywhere near the power to handle loads like the gear,
the avionics, and the engine (and it was already broken), there was no
way this plane was going to fly.
The pilot should have known that if both engines needed to be started
remotely that this plane was not airworthy. Spending a little time
studying the electrical system of your plane can save your life. Look
at each component and ask yourself, what if it quits?
The props on most twin engine aircraft feather when they quit. It helps
prevent loss of control in an engine failure. Only piston single engine
props do the opposite in an attempt to keep the prop and engine turning
to make it easier to restart -- but at the cost of greatly reducing
your glide distance. Having a prop go to max rpm if it quits on a light
twin is likely to be deadly.
In general, it looks like a maintenance problem that was allowed to
turn into an emergency, which in turn was badly mishandled. One very
popular way of falling out of the sky is to take off in an airplane
that you knew had problems before you left.
All of that said, I think the article makes a strong argument that this
kind of thing should not happen. If you are going to have engines
dependent on electricity to keep running, then you need to have some
form of backup, but the DA-41 has a backup system -- it just didn't
cover what would happen if the alternator failed on takeoff and someone
raised the gear. I don't like the idea of the engines shutting down in
an electrical failure, either, but that is one price of FADEC. In the
DA-42, it appears that installing a generator was considered to be
enough redundancy in the event of an alternator failure. It apparently
never occurred to anyone that someone would take off with a failed
alternator and then try to raise the gear.
The question is why raising the landing gear should be allowed to cause
a complete system failure. The easiest fix would be to install a bigger
generator, but that is probably not a complete solution. I agree that
the electrical system should prioritize things, too. And if things
fail, I don't want just a red line on the voltmeter -- I want it to be
something that attracts attention to itself. In the DA-42, it appears
that there is an alternator failure light. This thing should have been
lit. Perhaps the pilot ignored it. Presumably the generator would keep
things running once the engine starts, but if all you have is the
generator I don't think you have any business departing the field. In
this case, the alternator appears to have never even started running
because of the failure of the excitation system, and the generator was
too weak to run the whole system, so it quit completely. Dang.
Yeah, I think there is a design problem, but it seems to me that the
pilot missed plenty of warning signs and opportunities to do something
about them.
Waddling Eagle
Old April 25th 07, 04:43 AM posted to rec.aviation.piloting
Peter Dohm
news:2007042418074350073-christophercampbell@hotmailcom...
said:
Hi.
remote power.
engines stopped.
believe it.
Karl
both running.
about them.
Waddling Eagle
As you correctly pointed out, we will all have to wait for the accident
report to know very much. In my case, I already knew that the DA-42 had two
common rail diesel engines and was very fuel efficient--but nearly all of
the rest came from this thread. The result of what I am learning here is
that I am becomming less critical of the the aircraft systems and more
suspicious of a catastrophic series of human errors--from what I have read
in this conversation, it appears that, if a DA-42 is parked with the master
switch(es) on, and with the alternator exciter battery switches also turned
on, and the pilot did not understand the aircraft systems; then something
like this could easily occur.
Obviously, at this time, none of use know what really happened; but I am no
longer ready to presume that the systems lacked a normal level of safety.
In fact, I am no longer ready to presume anything--other than the fact that
I plan to read the report when available.
Peter
Old April 25th 07, 09:46 AM posted to rec.aviation.piloting
Snowbird
"C J Campbell" wrote ...
According to the article, the battery was so dead that it could not excite
the alternator -- the alternator needs some current in order to start.
I'm sorry, but the quoted article seems to point more at the main battery as
the culprit.
Without the buffering effect of the main battery, the current spike of the
gear retract was supposedly enough to decrease the voltage on the ECU bus
and cause an ECU reset.
There is a discussion whether the main battery was connected to the battery
bus at all. Judging from the electrical diagram, if the battery is flat
there is no way to activate the battery relay to get the main battery
connected to the battery bus.
If the excitation battery had been the culprit, I guess an alternator
warning light would have been very visible.
F6F accident Larry Cauble Naval Aviation 4 October 14th 05 07:19 PM
Accident db? [email protected] Owning 3 July 25th 05 07:22 PM
C-130 accident Jay Honeck Piloting 28 January 11th 05 07:52 PM
MU2 accident Big John Piloting 16 April 13th 04 04:58 AM
KC-135 accident Big John Piloting 3 November 19th 03 05:36 PM
