Can F-15s making 9G turns with payload?
Old September 18th 03, 11:34 PM
Gene Storey
"Ed Rasimus" wrote
"The aircraft G-limits are only there in case there is another flight
by that particular airplane. If subsequent flights do not appear
likely, there are no G-limits."
They even include a chair where you can give it back to the taxpayers
anytime you like...
Old September 19th 03, 07:29 PM
Walt BJ
The F4 wingtips cracked from vibration, not G. However, G set up the
vibration. Flying close when when lead was doing acro one could see
the wing tip vibrating as the tip vortices did their 'Karmann trail"
thing. The 110v 'thin filament' tip lights used to fail in a jiffy
until they rewired then for 28vDC 'heavy filament' bulbs.
We had an F4 at low altitude peg the G meter both ways when the tip of
the 600gal centerline came off as the pilot (Stormy FAC) dodged a SAM
coming right in from 12:00. Later a second F4 had the tip shot off his
centerline tank and the Gs piled on the same way. Turns out the blunt
nosed tank sets up severely disturbed airflow over the horizontal
stabilizers.
Both aircraft checked out okay except lots of 'bubble gum' was needed
to reseal the bottom of the internal wing tanks.
Walt BJ
Old September 19th 03, 07:39 PM
Tarver Engineering
"Walt BJ" wrote in message
m...
thing.
More apropriatly called gain in s-plane analysis, but true.
Making your own canopy c hinds Home Built 6 November 22nd 04 10:10 AM
Why is a standard hold right turns? Roy Smith Instrument Flight Rules 51 August 28th 04 07:09 PM
need advice with composite for making glare shield bubba Home Built 1 July 7th 04 06:44 AM
Making my landing gear Lou Parker Home Built 8 March 31st 04 11:34 PM
Air Force launches rocket with secret military payload from Cape Canaveral Otis Willie Military Aviation 0 September 9th 03 10:07 PM
