Temporarily removing fuel and replacing it into the same aircraft
Old July 24th 07, 06:28 PM posted to rec.aviation.piloting,rec.aviation.owning
Ross
Default Temporarily removing fuel and replacing it into the same aircraft
El Maximo wrote:
FWIW, I found the best way to de-fuel my plane is through the carb.
Unfortunately, it renders the fuel unusable, but it's alot of fun.
"B A R R Y" wrote in message
news
Thanks for all the GREAT info!
That took me a second reading to understand. That's great and I agree.
Regards, Ross
C-172F 180HP
KSWI
Old July 24th 07, 05:55 PM posted to rec.aviation.piloting,rec.aviation.owning
In rec.aviation.owning Stealth Pilot wrote:
: when you do it make sure you have an earth connection between the
: aircraft and the container. this can be as simple as a piece of fence
: wire in the container touching the aircraft so as to bleed static
: differences between the two. more elaborate would be a piece of
: automotive wire with a crocodile clip on each end clipped between the
: with static taken care of you worst problem is spillage.
: when you have the time go and get a copy of the regs and read them
: yourself. it isnt difficult to understand them and you will have in
: your memory an authoritative picture of them. the world gets easier
: after that.
: when you put the fuel back into the aircraft just pour it through a
: funnel with a micromesh filter in it, they are as cheap as chips in
: discount automotive shops and they exclude crud and water.
: Stealth Pilot
My setup for doing this is the same as what I use to haul cargas to the airport for my plane. I
use a few plastic, 6-gallon cans. To minimize the risk of contamination (from bad service station fuel
with sludge, water, stuff in the cans, etc), I rigged a water-absorbing spin-on fuel filter with a
pour-spout that will screw into the can. Then I just move the filtering pour spout from one can to the
other as I dump it in.
I minimize the electrical arcing risk by *ALWAYS* touching the filtering pour spout (which is
metal BTW) with one hand while I touch the wing with my other some distance away from the fuel tank
filler neck. Then while tipping the can into the neck, I maintain grounding with my fingers until the
metal spout makes contact with the plane. Sounds complicated, but it's not... prevents the possibility
of arcing where it counts (at the filler neck) even with plastic fuel containers.
I've never found any crude in sumping the tanks since I started using the filter 4 years ago.
Before then there was always a bit of water and the occasional bits of particles from the cargas.
Defueling and refueling just means one more trip through the filtering pour spout.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old July 25th 07, 03:22 PM posted to rec.aviation.piloting,rec.aviation.owning
JB
: after that.
: Stealth Pilot
-Cory
I've never had to off-load fuel but just in case....
For plastic containers (with plastic spouts) and a plastic siphon hose
from the wing tank to the container which is sitting on the tarmac,
what's the best way to ground and avoid static build up?
--Jeff
Old July 25th 07, 04:02 PM posted to rec.aviation.piloting,rec.aviation.owning
Newps
It's plastic, there's nothing you can do but hope.
Old July 25th 07, 05:43 PM posted to rec.aviation.piloting,rec.aviation.owning
Don Tuite
It might help to run some sash chain through the hose with enough left
over to pile up in the wing tank and storage tank. Knot the chain to
prevent it from pulling thorugh the hose.
Sash chain: That flattish chain people with old fashioned windows use
between the window sash and the sash wieghts.
Don
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 05:54 PM
Removing 100LL Fuel Stain Jeff Home Built 7 September 20th 05 09:45 PM
FOLO: Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 10 February 23rd 05 05:35 AM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 05:12 AM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 11:20 PM
