clare @ snyder.on .ca wrote ...
No, David was right. ... He sure was. I misread what he meant. Engine RPM vs prop RPM. The error was mine. Daniel |
David
Many years ago, someone told me that motorcycle engines had a lot of vibration and for that reason were not really reliable for use in a very light aircraft that their horsepower would pull. Vibrations caused failures in the structure???? One data point FYI. Big John On Fri, 19 Sep 2003 10:06:41 GMT, David Hill wrote: I'm working on a replica of a 1924 airplane originally powered by an Indian Chief motorcycle engine. I've spent a year or two trying to find a modern engine that somewhat resembles the Indian, and the best I have come up with is a Harley-Davidson. Looks like with an 80 cid Evolution engine I can get ~40 hp at ~3400 rpm (direct drive) or ~60 hp at ~4500 rpm (PSRU setup). Has anyone here tried this? Or know of anyone who has done this? I'm looking for caveats, tips, and techniques. Based on experience, not opinion. Oh, sorry, I forgot where I was. grin |
Indian just went belly up re article in todays paper. Stated in 1902
it said. Big John On Fri, 19 Sep 2003 10:06:41 GMT, David Hill wrote: I'm working on a replica of a 1924 airplane originally powered by an Indian Chief motorcycle engine. I've spent a year or two trying to find a modern engine that somewhat resembles the Indian, and the best I have come up with is a Harley-Davidson. Looks like with an 80 cid Evolution engine I can get ~40 hp at ~3400 rpm (direct drive) or ~60 hp at ~4500 rpm (PSRU setup). Has anyone here tried this? Or know of anyone who has done this? I'm looking for caveats, tips, and techniques. Based on experience, not opinion. Oh, sorry, I forgot where I was. grin |
This month's Kit Planes talks about a Nieuport replica with a Yamaha
engine as the powerplant. The guy has the engine locked in second gear to supply his reduction. I saw a site with it a long time ago but can't find it now. Apparently it has hours on it in the air and pulls ok. Personally I have no opinion on the feasability but we are experimenters. |
Canuck Bob wrote:
This month's Kit Planes talks about a Nieuport replica with a Yamaha engine as the powerplant. The guy has the engine locked in second gear to supply his reduction. I saw a site with it a long time ago but can't find it now. Apparently it has hours on it in the air and pulls ok. Personally I have no opinion on the feasability but we are experimenters. When I first started looking at using a V-Twin motorcycle engine, my inclination was to use a Jap V-Twin rather than a Harley, mainly because in motorcycles the Jap engines are 1) smoother, 2) more reliable, and 3) more powerful. However, the big drawback is that the transmission is integral with the engine. The plus side of that is you already have a well engineered gear reduction system in place. The minus side is you have a lot of extra weight that you really don't need. I've talked to folks that used other Jap engines; they removed as much of the transmission innards as they could, leaving only what was necessary. This involved some tricky welding, and still left a lot of metal in place that wasn't really needed. My inclination changed recently after I dropped by a local Harley shop and started asking questions. Turns out the Harley motor is separate from the transmission. Turns out you can get a new-in-the-crate Evo engine for about $2900. Comes with dual sprockets standard on the crank (just waiting for a chain drive PSRU). Turns out it's a dry sump engine; requires a separate oil tank. Can you say "lots and lots of oil, and an oil cooler to boot"? That'll help a lot in regard to engine cooling. Turns out you can get it either carburated or with electronic fuel injection. EFI means I can keep the simple single lever control (throttle only) of the original plane, but be able to operate efficiently at varying altitudes. So, the only hard part is designing and building the PSRU. I've seen the one at http://www.hog-air.com/. From the pictures it looks like it ties in to the cylinder heads, while the engine mounts are at the base of the cylinders. It seems this would put a bending stress on the cylinder bases that they were not designed for. I hope to get a first hand look at it next month and ask the designer about it. -- David Hill david at hillREMOVETHISfamily.org Sautee-Nacoochee, GA, USA |
So, the only hard part is designing and building the PSRU. I've seen the one at http://www.hog-air.com/. From the pictures it looks like it ties in to the cylinder heads, while the engine mounts are at the base of the cylinders. It seems this would put a bending stress on the cylinder bases that they were not designed for. I hope to get a first hand look at it next month and ask the designer about it. Couldn't find any specs on the engine other than the torque at 3000 RPM, and the Harley web site, like the hog-air web site, was kind of a pain to navigate. Any idea if they have the power curve on line? thanks Ed Wischmeyer |
Ed Wischmeyer wrote:
Couldn't find any specs on the engine other than the torque at 3000 RPM, and the Harley web site, like the hog-air web site, was kind of a pain to navigate. Any idea if they have the power curve on line? thanks Ed Wischmeyer There's a "list of verified horsepower figures for a variety of the Twin Cam 88 and 95 CID Engines" at http://www.nightrider.com/biketech/hplist_twin_cam.htm If you drop down to the first 68 hp motor 88 CID engine listed, you can click on it and get a dyno chart at http://www.nightrider.com/biketech/dyno_sheets/max_green_tcdyno.jpg Just looked up what the Harley website says about torque at 3000 RPM; they claim peak torque of 85 ft-lbs. The dyno chart referenced shows a peak torque of about 76, maybe 77 ft-lbs at 4000 RPM. Harley's probably measuring at the crank; the dyno chart is of measurements taken at the rear wheel. hope this helps, -- David Hill david at hillREMOVETHISfamily.org Sautee-Nacoochee, GA, USA |
| personal property tax on homebuilt aircraft | Stu Fields | Home Built | 18 | September 6th 03 04:29 PM |
| High performance homebuilt in the UK | NigelPocock | Home Built | 0 | August 18th 03 09:35 PM |
| Sport Pilot Airplanes - Homebuilt? | Rich S. | Home Built | 8 | August 11th 03 12:41 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
