At 06:00 29 July 2007, Bob Kuykendall wrote:
On Jul 28, 9:20 pm, Marc Ramsey wrote: Looks like they deepened the canopy cut out at the back to allow a bit better view down. That's the sort of thing prototypes are used for. Is that the best evidence you have of changes? It kinda looks that way. However, it is a far from trivial thing to change the canopy rail curve that drastically. There are somewhere between three and six molds you'd have to change, and I can't imagine going to the trouble unless it was really important. I don't think the minor visibility improvement in that direction would justify it. Moving the wing forward that little bit requires almost as much tooling change as changing the canopy rail curve. However, the resulting CG shift might really come in handy. If the empty CG was coming out further forward than they originally expected (say, if they were originally too pessimistic about the shell weights of the aft fuselage and tail parts), moving the wing forward can mean less trim ballast, lower trim drag, greater cockpit payload, or some combination of all three. So, Marc, you could well be right, but I'm betting the other way on this one. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 See: http://picasaweb.google.co.uk/chrisi...to#50924269483 65588402 This picture has a comparison grid that seems to be accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. From comparison of the relative port and starboard rear cockpit frame positions it looks as if SN 3 is photographed from a slightly more forward viewpoint but not enough to make one grid box difference to the position of the wing leading edge which is what would be required to bring the prototype leading edge as close to the canopy as S/N 3. If the there is any doubt remaining then nose to leading edge measurements of Bill's glider and the Australian one would be definitive would they not? |
John Galloway wrote:
See: http://picasaweb.google.co.uk/chrisi...to#50924269483 65588402 This picture has a comparison grid that seems to be accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. From comparison of the relative port and starboard rear cockpit frame positions it looks as if SN 3 is photographed from a slightly more forward viewpoint but not enough to make one grid box difference to the position of the wing leading edge which is what would be required to bring the prototype leading edge as close to the canopy as S/N 3. In any case, these photos can't provide a definitive comparison, as the the upper one is taken with a relatively wide angle lens, the lower with a telephoto. Note the geometric inconsistencies between openings at the rear of the canopy and the nose vents. If the there is any doubt remaining then nose to leading edge measurements of Bill's glider and the Australian one would be definitive would they not? That wouldn't be anywhere near as much fun as arguing about the integrity of the design based on obsessively examining photos... |
On Jul 29, 1:07 pm, John Galloway wrote:
At 06:00 29 July 2007, Bob Kuykendall wrote: On Jul 28, 9:20 pm, Marc Ramsey wrote: Looks like they deepened the canopy cut out at the back to allow a bit better view down. That's the sort of thing prototypes are used for. Is that the best evidence you have of changes? It kinda looks that way. However, it is a far from trivial thing to change the canopy rail curve that drastically. There are somewhere between three and six molds you'd have to change, and I can't imagine going to the trouble unless it was really important. I don't think the minor visibility improvement in that direction would justify it. Moving the wing forward that little bit requires almost as much tooling change as changing the canopy rail curve. However, the resulting CG shift might really come in handy. If the empty CG was coming out further forward than they originally expected (say, if they were originally too pessimistic about the shell weights of the aft fuselage and tail parts), moving the wing forward can mean less trim ballast, lower trim drag, greater cockpit payload, or some combination of all three. So, Marc, you could well be right, but I'm betting the other way on this one. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 See: http://picasaweb.google.co.uk/chrisi...to#50924269483 65588402 This picture has a comparison grid that seems to be accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. From comparison of the relative port and starboard rear cockpit frame positions it looks as if SN 3 is photographed from a slightly more forward viewpoint but not enough to make one grid box difference to the position of the wing leading edge which is what would be required to bring the prototype leading edge as close to the canopy as S/N 3. If the there is any doubt remaining then nose to leading edge measurements of Bill's glider and the Australian one would be definitive would they not?- Hide quoted text - - Show quoted text - It appears to me that the images are not scaled identicly, easely seen on the lettering and the canopy frame. Udo |
accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. That's not serial #002, THIS is #002. Here are some shots of serial #002.... http://i206.photobucket.com/albums/b...r/DSCF0013.jpg http://i206.photobucket.com/albums/b...r/DSCF0010.jpg http://i206.photobucket.com/albums/b...r/DSCF0007.jpg Bill |
Does anyone really give a flying you-know-what?
Whoever the hell builds the Diana clearly has no clue about customer service, but we knew that already. The glider itself is a triumph of technology in a dying backwater of gliding nobody cares about (everybody is buying 18m gliders now). Blue's posts are doing a fantastic job of promoting the Diana because really I'd have long forgotten it existed without them... how many have they built now? Four? So, does anyone give a... Dan |
As I know Chris, he is one of the nicest very professional persons in
gliding scene. I truly believe him, if he is making a point. They who say, he is against polish manufacturer, are redicilous. He would of done the same, if the plane was what ever. He is just after some answers. And no, I AM NOT CHRIS. (I am sure some of you already thought that) So let's cut the crab... PS On 30 heinä, 02:20, Airjunkie wrote: This picture has a comparison grid that seems to be accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. That's not serial #002, THIS is #002. Here are some shots of serial #002.... http://i206.photobucket.com/albums/b...r/DSCF0007.jpg Bill |
At 23:24 29 July 2007, Airjunkie wrote:
This picture has a comparison grid that seems to be accurately placed on the basis that the nose to rear of canopy and nose to front of canopy dimensions are the very closely matched. If that analysis is correct then the grid shows that the wing of S/N 3 is not moved forward compared to what we are told is the prototype (labelled S/N 2) and the canopy lower rear contour looks to be cut more angularly. That's not serial #002, THIS is #002. Here are some shots of serial #002.... http://i206.photobucket.com/albums/b...r/DSCF0013.jpg http://i206.photobucket.com/albums/b...r/DSCF0010.jpg http://i206.photobucket.com/albums/b...r/DSCF0007.jpg Bill Bill, That is what I was trying to make clear - that the grid picture is mis-identified as S/N 2 whereas it is actually the prototype. No need for measurements now - your glider is clearly the same as the Australian one John |
The people that might be in the market for a Diana 2 are probably the
only ones that really give a rats patoot, but there may be a few of those monitoring this board. The manufacturer may have an 18-meter LS-10 killer version planned. If so, knowing they're not being exactly stand-up guys might be of some GREAT interest. That's why people are reading this... I'd personally hate to invest that kind of money and have the manufacturer snub me. Jack Womack |
http://www.beres.com.pl/index.php?op...26&Itemi d=13
one distributor has vanished from the "Foreign Representatives" list.. Chris |
On Jul 31, 4:38 pm, "BlueCumulus" wrote:
http://www.beres.com.pl/index.php?op...sk=view&id=26&... one distributor has vanished from the "Foreign Representatives" list.. Chris Hey you, Blue Cumulus....you are a freak of nature, I can't believe I share the sky with a piece of !%#$$ like you...just drop it...we are getting tired of you...what the hell??? do I hear the fifth column marching????!!!!! ASM |
| Thread Tools | |
| Display Modes | |
| Diana-2 VH-VHZ, the test flight (pic links only) | BlueCumulus[_2_] | Soaring | 1 | July 27th 07 06:24 AM |
| TV helicopter pilot saves stranded deer | Shiver | Rotorcraft | 0 | January 18th 07 11:44 PM |
| SZD-56-2 Diana | Yurek | Soaring | 1 | January 29th 05 02:02 PM |
| Stranded WWII vet gets presidential assistance | G Farris | Piloting | 0 | June 10th 04 07:15 PM |
| Jon Johanson stranded in Antartica.... | John Ammeter | Home Built | 149 | December 24th 03 05:42 PM |
