F-4 chaff/flare loads
Old September 23rd 03, 11:04 PM
Juvat
After an exhausting session with Victoria's Secret Police, Token
blurted out:
I can not comment on the story of photo-flash carts being used to
defeat any seeker.
OK
I imagine it would work, I see no reason it should
not, but as I am not familiar with the burn times or dispense patterns
of the cartridges I can only guess.
Not surprisingly, you're impression was common back then.
While I can see that photo-flash stuff would be tailored to emit the
most energy in the optical band of interest, it is very hard, some
would say impossible, to design such a device that did not also emit
in unwanted bands.
I just flipped thru my notes from a 1984 course at TAWC, and can't
find the reference. I only got to keep some of them. The course had
guys from every tactical jet in USAFE, TAC, and PACAF. The question
was raised about the effectiveness of photo-flash carts versus IR
missiles during an IRCM lecture.
The short answer was they're ineffective due to the lack of sufficient
coverage of the IR spectrum (not enough heat), plus they're ejected
above and to the side before "blooming" which probably puts them
outside the seeker's centroid (depending on the missile's range from
the RF-4). But not a problem with A-10s' flare dispensers out near the
wingtip.
We watched a couple AVTR clips showing various IRCM techiques against
AIM-9P and L seekers and some foreign made seekers. The tests by the
guys at TAWC concludeded the photo-flash didn't decoy any seekers. And
there were remarks like, "We'd really like to show you some more neat
stuff, but you guys don't have need to know."
Additionally RF-4s had specific IR flares manufactured for their cart
breeches, not simply photo-flash carts modified to bloom early and
burn longer. I know they worked against the AIM-9 from DACT with the
MS or AL ANG.
Still, the point is that flares tailored to work in the IR spectrum
still, very often, possibly even always, emit in the visible spectrum
as well.
No problem.
I had an interesting LOWAT sortie were I tapped an MC-130. I had
gotten a satisfactory weapons check after takeoff (my Lima's seeker
tracked my wingman's exhaust). I managed to trap the MC-130 at my 12
o'clock thru superior airmanship and cunning (okay a single side
offset intercept). When I uncaged the seeker head it literally started
nutating in ever increasing circles and sailed way off the Herc. No
"visible" flares were noted (none on my AVTR), but that Lima just
couldn't lock-on to the Herc's engines. My wingman had the same
experience, and we could track and uncage the seeker against each
other after the Herc engagement. Magic...
Juvat
Old September 24th 03, 03:09 AM
Les Matheson
"Juvat" wrote in message
Yes the MC had/has some neat toys.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
Juvat
Old September 24th 03, 03:15 AM
Token
Juvat wrote in message . ..
wingtip.
I can totally buy that the eject profile is wrong, and that they get
out of the track beam of the seeker before they bloom. That is one of
the major design issues with IR counter measures flares, getting them
to heat up quick, without being explosive. However, IRCM flares are
JUST short of "explosive", they have a very rapid velocity factor. If
you have ever listened to them from outside the AC, say on the ground
under the AC, they make a very distinctive "pop" on ignition, a pop
that can be heard over a pair of engines in reheat.
I mean, if you go to this page:
http://www.fas.org/man/dod-101/sys/missile/row/sa-7.htm
You will see that the track "beam" of a period weapon, in this case
the SA-7b, is only 1.9 degrees wide. This is the instantaneous field
of view. That means that the flare would only have to move half this
value, or .95 degrees, to be out of the beam of the weapon (assuming
the weapon is tracking the aircraft). Lets figure a beam shot (yes, I
know, not with a 7b), at mid envelope range, say 2000 yards, 6000
feet. At that range 1 degree (17.5 mils) is about 105 feet. Lets
assume an aircraft speed of about 450 knots. That means the aircraft
is moving about 750 feet / sec. Or, the flare must come up to a high
enough energy state to mask the aircraft in less than 0.15 seconds, or
150 millisecond.
As far as the photo-flash flares having "not enough heat", I can see
someone saying that, in fact I have heard similar quotes from supposed
knowing individuals, but the physics just don't work that way. Less
heat means more shift to the red end. That is why something is
described as being "white hot". So, what it amounts to is, if it is a
pyrotechnic device (and these are) it will emit at least as much in
the IR as in the visible. Infra Red emissions happen at a lower energy
state then visible light emissions. So that even when it has burned
out, and is not issuing very much visible light, it will still be
emitting in the IR. This is a generalization, but a good one for
flares.
A high school physics example here. Take a DC light bulb, say a 12
volt car lamp. Turn down the voltage getting to the lamp, the lower
the voltage, the redder the lamp will glow. Eventually the lamp will
no longer put out visible light, but will still stay hot to the touch.
It is still putting out IR, but the energy state is lower, too low to
produce "white" light.
MS or AL ANG.
Yes, IR flares are specifically designed, not an adaptation of other
types of flares. The point of what I am saying is that photo-flash
flares will have some signature in the proper IR bands, but without a
doubt, it could be made better.
Juvat
lol...magic...magic with some kind of ALQ designator ;-) And that is
old tech, you should see some kind of DIRCM at work.
Token
Old September 24th 03, 04:21 AM
Juvat
blurted out:
Hehe...standing on the ramp I've heard the carts fire whilst
jettisoning a CL tank off a Phantom from over a mile away.
Sincere thanks for the link.
Oops, my poor choice of words. The video we watched clearly showed
foreign (as in those from the SA-7 and an early version of the Atoll)
seekers NOT tracking a photo-flash cart either singles or pairs. I
took them at their word. Another test showed AIM-9 Lima versus Papa
flare rejection abilities in relatively clear air mass, at high
aspect. Way out at 10 miles a Papa would bite off on an IR flare.
Fair enough, I am unable to dispute your logic. I love physics, but
don't have the memory (or notes) to get very deep in the topic. But
please feel free to expound...I always like learning.
Indeed, I'm long removed from a fighter cockpit to venture a WAG.
Juvat
Old September 24th 03, 03:18 PM
Tom Cooper
blurted out:
defeat any seeker.
OK
in unwanted bands.
wingtip.
Juvat,
I understand your points and the reasoning behind it. My question is only:
why would the crew of the RF-4E in question then explain such a story?
After all, they said they used these cartriges to decoy the missiles, and
evaded four R-3/R-13s fired by the MiG in question, and also the Soviet
pilot rammed them in desperation. OK, the Atolls were not that problematic
to evade, but an RF-4E at supersonic speed is also not that maneuvreable
either.
Do you have any idea what kind of cartriges were used at earlier times?
Tom Cooper
Co-Author:
Iran-Iraq War in the Air, 1980-1988:
http://www.acig.org/pg1/content.php
and,
Iranian F-4 Phantom II Units in Combat:
http://www.osprey-publishing.co.uk/t...hp/title=S6585
Old September 24th 03, 05:11 PM
Juvat
Tom Cooper asked:
Short answer...it would appear that since all Atolls missed, the
efficacy of photo-flash carts as IRCM was proven, at least
anecdotally. But wait...
What is missing from the story, are significant details like, time of
day (chased into the sun?), altitude of the fight, cloud cover (bright
white puffy ones)...even in the 80's the AIM-9 Papa was decoyed by
bright clouds.
Okay, here's a skeptical guess, merely throwing it out. What if the
MiG pilot was hosing off missiles from Max range in an clever attempt
to make the Phantom pilot turn, allowing the MiG to get closer (maybe
for a gun kill, not trusting the Atolls). BS? As the guy in the front
seat of the Phantom you would rely upon the WSO to tell you the MiG
fired a missile and which direction to break (assumes I can't see him,
i.e. he's in my vulnerable cone)
OK, the Atolls were not that problematic to evade, but an
RF-4E at supersonic speed is also not that maneuvreable either.
Indeed a big ass turn circle, which would give credence to the Max
range Atoll shot. Call me a skeptical asshole for thinking there is no
way in hell a Phantom is going to cruise Supersonic in Mil Power.
So from my perspective the supersonic RF-4 must be in Burner/Reheat/AB
and just think how much heat (IR energy) is thrown off by the exhaust
and the nozzles versus a few photo-flash carts. Based upon the TAWC
lectures and videos, I think it is unlikely photo-flash carts worked
as IR decoys under these circumstances.
As an aside, the mantra for using flares as IRCM included "ya gotta be
out of burner, and ya gotta maneuver the jet." So, here' what I'd toss
out. You've got an RF-4 going supersonic in Max AB, the WSO calls the
Atoll shots and tells the pilot to Break L/R, forcing the pilot to
Idle, Speedbrakes, and put 7.33 Gs on (and oh yeah watch out for Mach
Tuck as you slow down). Now the jet is subsonic and the fight stays
that way until they get speared by the MiG guy...AND perhaps the
mid-air was accidental.
Or you got this RF-4 going supersonic in Max AB and the pilot is smart
enough to try and keep the MiG(s) at the edge of the vulnerable cone
(out near the wingtip in terms of relative position seen from the FCP)
and out of Atoll parameters. These check-turns and extensions alter
direction, Left/Right in an attempt to keep going in the right
direction...Iran.
Tom this truly is an interesting story with so many missing variables
to ponder.
The reason that jumps out at me was the common belief that photo-flash
carts worked. There was no test data to support that belief, but what
the heck...photo-flash produce lots of light (energy) so they probably
will work as a decoy. I find absolutley nothing wrong with the logic
of that thinking (considering the infancy of IRCM).
Juvat
Old September 24th 03, 08:51 PM
Juvat
Tom Cooper posted:
either.
Just to recap from the earlier reply of mine:
"What is missing from the story, are significant details like, time of
bright clouds."
Taking that last phrase a bit further, this was for a Mil Power
target.
So perhaps the MiG was shooting first generation Atolls. Recalling
that they were noted for poor target/IR source discrimination, perhaps
the photo-flash did decoy the missiles. But I'd still speculate that
the RF-4 would not have been in AB for it to work.
Just to connect the dots of my train of thought...
Early generation Atoll with zero IRCCM and poor IR discrimination,
could get decoyed by lots of things (sun, bright clouds, warm surface
background)...possibly/probably photo-flash.
Ten years later leaps and bounds in seeker technology and IRCCM on
both sides of the Cold War. At that point in time photo-flash carts
were determined to be ineffective versus current IR missiles.
Works for me, just because they (photo-flash carts) didn't work in the
early 80's doesn't prove they NEVER worked as IRCM.
Les?...Ed?...Guy? Make sense to y'all?
Tom, does the USAF WSO which to remain anonymous? If so why?
Juvat
Old September 24th 03, 09:49 PM
Ed Rasimus
On Wed, 24 Sep 2003 19:51:58 GMT, Juvat
Tom Cooper posted:
either.
Anyone who is doing recce work who allows themselves to get rammed has
clearly slowed down too much and did way too much turning.
I doubt that RF was super. Even so, he should have had great
maneuvering potential. Kinetic translates to potential energy very
quickly.
bright clouds."
target.
My impression is that if the recce were in AB and then choose to honor
the shot by turning into it (and without the sophistication of knowing
to come out of burner and get quiet) then remember that the heat plume
is on the lag side of the turn.
Back in the days before the invention of fire when I was doing this
sort of thing, the best IR shot was taken by maneuvering to lag--not
cutting off inside the turn circle but lag rolling to outside the
target's flight path giving you a clear look up the pipes rather than
at the top of the wing.
Then, assuming that the RF-4E still had the cart doors at about the
same place, look for the turning recce to be firing photo-carts left
and right of flight path, but inside the turn circle.
If the MiG is trying to lead pursue and cut off (a natural thing to do
in a low-wing-loaded, high-G capable aircraft) then he's not getting a
good lag shot at the AB plume and he is closer to solution with the
photo carts. Sounds to me like a good transfer of the missile seeker
situation.
It's sure more fun to figure these things out at the PC with a cup of
coffee than twisted around in the seat at seven G and wishing you
could get two more.
