Garmin G1000 gets airways
Old August 3rd 07, 05:41 PM posted to rec.aviation.ifr,rec.aviation.piloting
Dan Luke[_2_]
Default Garmin G1000 gets airways
"Peter Clark" wrote:
When in FPL (on the MFD, this does not work from PFD),
That must be it: I was doing it from the PFD FPL.
Got it to work, though!
Thanks,
Dan
T-182T at BFM
Old August 3rd 07, 07:16 PM posted to rec.aviation.ifr,rec.aviation.piloting
B
Dan Luke wrote:
"Dan Luke" wrote:
Mine was installed today; I'll report on how it works this weekend.
OK, I couldn't wait, so on the way to work this morning I went and fired up
the G1000 on the ramp.
The airways flightplan feature worked fine once I figured out that there was
an error in the new Garmin Cockpit Reference Guide. It mentions a "Load
Airways" softkey that never appears, and fails to mention that you have to
press the MENU hardkey at some point to get the "Load Airways" option. Don't
they user-test these manuals?
Short story: you put in the entry fix, airway id and exit point (from a menu)
and you're done. The airway id.exit fix is then in your flight plan. The
airway is in white, with its number, on the course line on the moving map.
Does it populate every fix along the airway from ABC to XYZ?
Old August 3rd 07, 07:43 PM posted to rec.aviation.ifr,rec.aviation.piloting
Dan Luke[_2_]
Not on the map. When you're doing the airway exit part of the flight plan,
it nominates all the waypoints on the portion you will be flying.
Dan
T-182T at BFM
Old August 4th 07, 01:13 AM posted to rec.aviation.ifr,rec.aviation.piloting
Peter Clark
Yep, it puts every fix from entry to exit in the flight plan.
Old August 4th 07, 01:45 AM posted to rec.aviation.ifr,rec.aviation.piloting
Dan Luke[_2_]
On the flightplan I entered this morning. It listed
KBFM LOXLY V198.QUINCY KTLH
The fixes between LOXLY and QUINCY were not shown.
Dan
T-182T at BFM
Old August 4th 07, 02:43 AM posted to rec.aviation.ifr,rec.aviation.piloting
Roy Smith
On the 480, there's an expand (XPND) function which toggles between just
showing the airway endpoints and showing all the intermediate fixes.
Perhaps there is the same on the 1000?
Old August 4th 07, 03:15 PM posted to rec.aviation.ifr,rec.aviation.piloting
B
I don't know about Garmin but the ARINC format for that route would be:
KBFM..LOXY..V198.QUINCY..KTLH
(two dots for direct)
Old August 4th 07, 08:13 PM posted to rec.aviation.ifr,rec.aviation.piloting
Ron Rosenfeld
On Fri, 3 Aug 2007 18:45:44 -0500, "Dan Luke"
What is QUINCY? I can't locate it, and I thought all intersections were
five characters.
Old August 4th 07, 01:40 AM posted to rec.aviation.ifr,rec.aviation.piloting
Cary
On Aug 1, 5:49 pm, "Dan Luke" wrote:
The recently issued revision to the G1000 software includes an upgrade to
permit loading airways into flightpans.
The upgrade is free to 2004, 2005 and 2006 Cessna G1000 owners, including a
labor allowance for installation. Mine was installed today; I'll report on
Dan
T-182T at BFM
This upgrade must be specific for just the Cessna G1000, because I
have not received any notification for my G1000 equipped DA42. I will
probably have to wait forever for Diamond to upgrade us with airways
and WAAS.
Cary
Garmin G1000 ASA/King? Mitty Instrument Flight Rules 2 November 3rd 06 04:47 PM
Victor Airways in Cessna G1000 T182T [email protected] Instrument Flight Rules 17 May 2nd 06 03:56 AM
Mooney goes with Garmin G1000 Mike Rapoport Owning 4 February 15th 04 02:03 AM
Garmin G1000 Corky Scott Home Built 4 January 9th 04 07:57 AM
Garmin G1000 Foster Owning 2 July 20th 03 07:45 PM
