Recently, Dudley Henriques posted:
DR wrote: Fred the Red Shirt wrote: Here deep stall is defined as a condition in which the main wing is stalled and the stabilizer is enveloped in the turbulent wake of the stalled wing so that the pilot has lost pitch control and thus cannot lower the nose to recover. For certain airframe geometries, (such as the illustration above) that condition can occur even if the aircraft is within the proper CG limits. Err, that's not how I see it, The aircraft can/will still pitch down after stall for 2 reasons: First, the center of wing lift moves aft once the wing is stalled which will drop the nose. Second, the tail is pushing the nose up to increase angle of attack so that once blanketed the nose drops. As far as I understand it, all certificated aircraft must be able to recover from a basic stall. My 2c Cheers Not so for the F16. Deep stall is an issue for the Viper at specific angles of attack and cg configurations, especially if the airplane is out of fuel balance. The result of deep stall in the Viper is a flat extremely fast ROD either with occiliation or without. The ONLY way to break deep stall in the Viper is to INCREASE the aoa, then quickly input forward stick to induce a high nose rate down through the deep stall region into a recovery. Make no mistake, if the aoa is not increased before this fast nose down pitch rate, the Viper will stay in deep stall and can be completely unrecoverable. There is no "automatic" nose down pitch rate in deep stall in the F16. Thank you for this explanation! One of my favorite past-times is playing Falcon 4.0 (F-16 sim), and there have been times when I've gotten into deep stall and have not found a way to recover. Perhaps the game is not sophisticated enough to execute the manouver as you've described, but at least I understand better what's happening. More on-topic, my basic training was in a Tomahawk, and can say that the liklihood of deep stalls in that plane are rather slim unless there is some significant weight in the baggage area. Neil |
On Thu, 6 Sep 2007 06:18:24 -0500, "Neil Gould"
wrote: Recently, Dudley Henriques posted: DR wrote: Fred the Red Shirt wrote: Here deep stall is defined as a condition in which the main wing is stalled and the stabilizer is enveloped in the turbulent wake of the stalled wing so that the pilot has lost pitch control and thus cannot lower the nose to recover. For certain airframe geometries, (such as the illustration above) that condition can occur even if the aircraft is within the proper CG limits. Err, that's not how I see it, The aircraft can/will still pitch down after stall for 2 reasons: First, the center of wing lift moves aft once the wing is stalled which will drop the nose. Second, the tail is pushing the nose up to increase angle of attack so that once blanketed the nose drops. As far as I understand it, all certificated aircraft must be able to recover from a basic stall. My 2c Cheers Not so for the F16. Deep stall is an issue for the Viper at specific angles of attack and cg configurations, especially if the airplane is out of fuel balance. The result of deep stall in the Viper is a flat extremely fast ROD either with occiliation or without. The ONLY way to break deep stall in the Viper is to INCREASE the aoa, then quickly input forward stick to induce a high nose rate down through the deep stall region into a recovery. Make no mistake, if the aoa is not increased before this fast nose down pitch rate, the Viper will stay in deep stall and can be completely unrecoverable. There is no "automatic" nose down pitch rate in deep stall in the F16. Thank you for this explanation! One of my favorite past-times is playing Falcon 4.0 (F-16 sim), and there have been times when I've gotten into deep stall and have not found a way to recover. Perhaps the game is not The explanation as to what is happening and how to recover is in the Falcon 4 manual. Roger (K8RI) sophisticated enough to execute the manouver as you've described, but at least I understand better what's happening. More on-topic, my basic training was in a Tomahawk, and can say that the liklihood of deep stalls in that plane are rather slim unless there is some significant weight in the baggage area. Neil |
Recently, Roger (K8RI) posted:
On Thu, 6 Sep 2007 06:18:24 -0500, "Neil Gould" wrote: [...] One of my favorite past-times is playing Falcon 4.0 (F-16 sim), and there have been times when I've gotten into deep stall and have not found a way to recover. Perhaps the game is not The explanation as to what is happening and how to recover is in the Falcon 4 manual. Roger (K8RI) Thanks, Roger. After looking it over, I think I was doing everything right except hitting the MPO switch. Neil |
On Sep 6, 3:27 pm, Dudley Henriques wrote:
DR wrote: Fred the Red Shirt wrote: Here deep stall is defined as a condition in which the main wing is stalled and the stabilizer is enveloped in the turbulent wake of the stalled wing so that the pilot has lost pitch control and thus cannot lower the nose to recover. For certain airframe geometries, (such as the illustration above) that condition can occur even if the aircraft is within the proper CG limits. Err, that's not how I see it, The aircraft can/will still pitch down after stall for 2 reasons: First, the center of wing lift moves aft once the wing is stalled which will drop the nose. Second, the tail is pushing the nose up to increase angle of attack so that once blanketed the nose drops. As far as I understand it, all certificated aircraft must be able to recover from a basic stall. My 2c Cheers Not so for the F16. Deep stall is an issue for the Viper at specific angles of attack and cg configurations, especially if the airplane is out of fuel balance. The result of deep stall in the Viper is a flat extremely fast ROD either with occiliation or without. The ONLY way to break deep stall in the Viper is to INCREASE the aoa, then quickly input forward stick to induce a high nose rate down through the deep stall region into a recovery. Make no mistake, if the aoa is not increased before this fast nose down pitch rate, the Viper will stay in deep stall and can be completely unrecoverable. There is no "automatic" nose down pitch rate in deep stall in the F16. The F16 elevator is in not a high configuration is it? So, how does it get blanketed in the way the thread is discussing? |
On Thu, 06 Sep 2007 12:31:39 -0400, Dudley Henriques
wrote: snip This discussion on deep stall brings up a point that I have been making for years in the flight instruction community. When you learn to fly, there is a natural tendency for flight instructors to teach people to fly based on the aerodynamics involved with the specific airplane in use for the training. There is a whole world of aerodynamics that isn't covered when training is accomplished in general aviation. Some students go through entire careers as pilots not knowing how aerodynamics are affected as design changes and airplanes fly at greater gross weights and airspeeds. One poster correctly suggested that a pitch down moment was to be expected in stall recovery behavior. This is correct for a Cessna or a Piper light GA airplane manufactured in the normal or utility categories. Just keep in mind that the design considerations for these airplanes that handle the aerodynamics found at stall won't necessarily hold true for the next airplane you fly. As for the Viper; it will enter deep stall when aoa stabilizes at a high positive or negative value outside the pitch limiter. In this stall configuration, the Viper doesn't have full pitch authority on the horizontal tails and won't reduce aoa enough to break the stall. In the case of the Viper, fuel imbalance, external stores location, and other factors that cause a rearward cg condition can cause deep stall. The main point to make in this discussion is that the stall conditions you learn for your Cessna 172 in training for your PPL apply to that general category of airplane. Pilots are well advised to extend their knowledge WELL beyond that accepted for the certificate and to delve deeply into the new environment in which they have chosen to operate. Learning about deep stall is a good start along that path. Which reminds me... I've let many pilots fly the Deb. A few years back one of the locals was interested in getting a Deb or F-33 and wanted to see how they flew. He and his wife had been flying a Cherokee 140 or 160. I think he really liked the control harmony and response as well as the take off and landing performance, but he was used to a very docile airplane that would let him used the ailerons in a stall. Do that in the Deb and it'll roll over and bite you and I do mean roll. Which ever wing you try to raise will drop *abruptly*. You can learn to feel the stall coming in through the yoke and the stall warning horn and light give ample warning, but there is very little buffet with a rather abrupt break and a *strong* tendency to roll left if you don't stop it "with the rudder". You can put it into a stall and bring the yoke all the way back while keeping the nose pointed up with the rudder "with practice", but it's much like balancing on a tight rope. I demonstrated departure, approach, and accelerated stalls and the ease of recovery keeping everything in the proper attitude, but after just two tries he decided he was going to stick with something like the Cherokee and maybe upgrade to a 180 or Archer. Stall recovery is not difficult to learn, but it is different. He didn't like the idea of carrying power down final either. One other thing is you can't fly it using the VSI which is poor form in any plane, but the Deb and F-33s are so quick, using the VSI for anything other than a trend instrument "which is its intended purpose" will put the pilot into a PIO of 2Gs out of the bottom and zero over the top. That's typical of both Piper and Cessna pilots the first time they fly it. There are exceptions though. As you say, each plane has its characteristics and they aren't necessarily those of what we fly as trainers. These characteristics are not unique to the Deb although it does have some of its own. With only a few exceptions it's characteristics are common to most high performance retracts. If flown properly it is an outstanding short field airplane. Surprisingly although it shouldn't be, not many pilots land the Deb and F-33s according to the POH. "Flying by the numbers" puts them in a flight realm they learned to avoid as students and could avoid in most of the planes they have flown. Unfortunately that means landing these planes much faster than necessary. The Deb and F-33 have about twice the glide ratio of a 172, but it's in the neighborhood of 120 MPH. I've mentioned it before, but at the Bo specific training, you should have heard the complaining and exclamations when they told the group the instructors would be blocking the yoke so they wouldn't be able to use the ailerons when doing stalls. roger (K8RI) |
On Sep 6, 9:31 am, Dudley Henriques wrote:
The main point to make in this discussion is that the stall conditions you learn for your Cessna 172 in training for your PPL apply to that general category of airplane. Pilots are well advised to extend their knowledge WELL beyond that accepted for the certificate and to delve deeply into the new environment in which they have chosen to operate. Learning about deep stall is a good start along that path. I don't think I agree with your statement but I will say that any pilot transitioning from the C-172 to the F-16 should ensure they get a complete checkout. -Robert, CFII |
In article , DR
wrote: Fred the Red Shirt wrote: Here deep stall is defined as a condition in which the main wing is stalled and the stabilizer is enveloped in the turbulent wake of the stalled wing so that the pilot has lost pitch control and thus cannot lower the nose to recover. For certain airframe geometries, (such as the illustration above) that condition can occur even if the aircraft is within the proper CG limits. An additional definition of "deep stall" occurs in some twins (Twin Comanche and Baron come to mind) is when the nacelles develop their own positive pitching moment (up) at very high angles of attack. The result is that the elevator has insufficient control authority to effect recovery. These planes have conventional mounting of the stabilizer. The phenomenon in the F-16 described by another poster appears to be a similar phenomenon, where the forward fuselage develops a high pitching moment that the elevator cannot handle. |
On Sep 6, 3:16 am, DR wrote:
Fred the Red Shirt wrote: Here deep stall is defined as a condition in which the main wing is stalled and the stabilizer is enveloped in the turbulent wake of the stalled wing so that the pilot has lost pitch control and thus cannot lower the nose to recover. For certain airframe geometries, (such as the illustration above) that condition can occur even if the aircraft is within the proper CG limits. Err, that's not how I see it, The aircraft can/will still pitch down after stall for 2 reasons: First, the center of wing lift moves aft once the wing is stalled which will drop the nose. Second, the tail is pushing the nose up to increase angle of attack so that once blanketed the nose drops. The conditions that DEFINE Deep Stall cause a loss of lift at tail as well, though the tail is not necessarily stalled in the same sense as the main wing. As far as I understand it, all certificated aircraft must be able to recover from a basic stall. My 2c Deep Stall is not a basic stall. See the description above, or the previously referenced webpage. -- FF |
| Car and Deep Cycle Battery FAQ | Bill Darden | Home Built | 0 | May 28th 07 12:57 PM |
| ILS approaching help | Syucomm | Simulators | 8 | December 13th 06 10:58 PM |
| deep hole | Randall Robertson | Simulators | 9 | April 22nd 04 08:51 PM |
| German AUV "Deep C" | robert arndt | Military Aviation | 0 | November 25th 03 05:07 PM |
| Approaching BFM... | Craig Prouse | Piloting | 5 | September 26th 03 05:50 AM |
