On Sep 9, 6:03 am, Ol Shy & Bashful wrote:
There is little doubt in my mind that the ability to do slow flight at the very edge of stall speed will do more to prevent accidents than 1000 hours of cruise speed flight. Is there anyone here who is proficient that lands their aircraft more than 10kts above stall speed? I teach all my students to slow fly with the entire range of configurations for the particular aircraft they are flying. Gear up/ down, flaps up/down/in-between. I want them to be comfortable flying at the very edge of the stall speeds and spend a lot of time maneuvering right on the edge of a stall "nibble". It does more for pilot confidence and ability than anything else I can think of. They learn proper control useage and how their particular aircraft responds while in the low speed areas. Playing with different angles of bank while at low speeds and flying with a modicum of accuracy does a lot for proper control use. If you think about it, how many accidents occur in the low speed spectrum? Either from a stall, or from a high sink rate on approach, or poor control use during an emergency or off airport landing, or something similar? In my opinion, the pilot who is comfortable throughout the entire speed range of their aircraft is a properly trained pilot and one who will not get into an inadvertant stall, or spin. What are your thoughts? I think exposure to stalls is appropriate and you can get enough practice keeping the wings level (with rudder) on the approach to the stall during stall training. BUT why would you ever want to _fly_ so close to stall? It's really dangerous to be just 10k above stall speed in any part of the circuit and that speed is not good for anything in real flight (terrible lift:drag and poor control response)... So what's the point? Do you not worry about wind gusts/lulls at that speed? I'd put this general idea in the fuel cut pull at takeoff bin Perhaps a pilot who likes to fly at 10k above stall is an accident waiting to happen? I don't see how extensive training at such low speed can help you fly safely -quite the reverse. My natural mental ASI is set to 65k! An analogy would be the utility in driving a car on flat tyres... Yes it can be controlled but watch out (you _will_ eventually spin out)! My 2c Cheers MC |
wrote in message...
.... BUT why would you ever want to _fly_ so close to stall? It's really dangerous to be just 10k above stall speed in any part of the circuit and that speed is not good for anything in real flight (terrible lift:drag and poor control response)... So what's the point? Quite a few years back I flew with CAP where we did endless training of ground ref manouvers at slow flight. One of the greatest concerns of the IPs was to lose a search plane because the pilot got distracted when investigating an item of interest while he was low and slow. |
If you think about it, how many accidents occur in the low speed spectrum? Either from a stall, or from a high sink rate on approach, or poor control use during an emergency or off airport landing, or something similar? In my opinion, the pilot who is comfortable throughout the entire speed range of their aircraft is a properly trained pilot and one who will not get into an inadvertant stall, or spin. What are your thoughts? I have a slightly different take on this. I am not an instructor but I feel that slow flight is very easy to practice or teach compared to some of the other areas of flight because it requires nothing more than an airplane and an instructor. However some of the other aspects of flying related to weather are the most difficult to learn or teach (in my opinion). Learning to avoid rotors or learning to judge the airplane's limits on a hot day at a higher elevation could very well be more challenging because some of those aspects of flying involve learning to avoid something which is harder to teach. Truth be told, I have often wondered what the fuss is all about when it comes to slow flight. After enough practice, its a piece of cake. In the last few hrs leading to my PPL, I had no trouble flying very high nose up with the stall horn blaring and the power up very high and not losing an inch of altitude. The C-150 actually showed something like 35 knots IAS if I remember right (although the TAS is much higher). My instructor actually thought I was doing well enough that he didn't want to spend time on slow flight on the day before the checkride because he thought I was better off doing turns around a point which I had trouble with. On the checkride, slow flight was something I was eagerly waiting for to impress the DE. |
On Sep 9, 12:19 pm, wrote:
In the last few hrs leading to my PPL, I had no trouble flying very high nose up with the stall horn blaring and the power up very high and not losing an inch of altitude. Did you pull the nose up a little more to get the stall in that situation? That's where it can get interesting. Departure stall. A 150 does it real well. Better be prepared for spin recovery. Dan |
Did you pull the nose up a little more to get the stall in that situation? That's where it can get interesting. Departure stall. A 150 does it real well. Better be prepared for spin recovery. Yes, as part of stall practice I did a few different types including the departure stall and the approach to landing stall which I found to be more instructive because the nose is pointed down or level with the horizon when it happens.But on many occasions the exercise was just to fly at minimum controllable airspeed and turn using very shallow banks which I find to be just as instructive as doing stalls. I don't think of stalls as being difficult or dangerous as I once used to when I first started training. |
On Sep 8, 2:03 pm, Ol Shy & Bashful wrote:
There is little doubt in my mind that the ability to do slow flight at the very edge of stall speed will do more to prevent accidents than 1000 hours of cruise speed flight. Is there anyone here who is proficient that lands their aircraft more than 10kts above stall speed? ... In my opinion, the pilot who is comfortable throughout the entire speed range of their aircraft is a properly trained pilot and one who will not get into an inadvertant stall, or spin. What are your thoughts? Other then the obvious objections (expressed here by many others) regarding navigation skills ,and calm, ordered responses to emergencies, as well as interpreting and dealing with weather both before and during flight, I think you have identified a skill that needs to be driven home and repeated again and again with ab initio students until they are comfortable handling the aircraft in any configuration in the slow-flight regime, and, indeed, transitioning between different configurations while in slow flight, as well as handling turns, climbs descents, and simulated "approaches" while in slow flight. (They should get to enjoy it so much that they get in the habit of practicing it themselves as often as possible after certification!) It is such an important concept (the backside of the power curve and what it really means ... try explaining this only once or twice to a typical driver of a car ... I usually only get confused looks even after sketching it out on paper) that no student (no doubt most used to driving a car where one power equals one speed on a flat driving surface) should be considered proficient at slow flight until they can not only DO it but also sketch their aircrafts power curve and explain it to their instructor, identifying all the important point, as well as explaining how it is that a range of power settings correspond to more than one airspeed on the curve. Anyway ... one small thing that relates to slow flight that I found improved my approaches in early training immediately and considerably was the realization that for a given power setting and rate of descent (in feet per minute ), the airspeed would be the same every single time. This allowed me to have a stable approach set up very quickly after turning base and resulted in instantly noticeably better approaches and landings on the next lesson after I learned this (my instructor at the time noticed the improvement immediately, unfortunately it wasn't him that taught me this fact ... I found it on a website produced by another flight instructor ... it was a great site, can't remember its URL now). The airspeed that I aimed for was usually a few knots above slow flight (I aimed for approach speed for short field landing, plus a few knots if it was a little windy or gusty) and of course there was descent involved (about 500 fpm in the 172SP was typical). Long story short ... slow flight training made me comfortable with reducing the power considerably, accurately, and consistently and confidently (to about 1000 - 1300 RPM initially depending on the headwind, again 172SP) when turning base (not just slowly stepping the power and speed down, which consumed too much time on base), quickly and confidently aiming for an approach speed close to a "performance" landing approach speed every time, and with the speed (172 SP - about 61 - 65 KIAS) and descent rate (initially aiming for 500 fpm) stable and trimmed out, all that was required to attend to was the drift, any shear on descent, and staying on a good approach slope visually, while occasionally glancing at the airspeed to ensure it wasn't bleeding off. This usually only required small power adjustments to keep on a proper the approach slope, and of course with more headwind, more power on final. While many other skills (especially navigation, emergency procedures, and weather assessment) are required to become (and remain) a safe, confident but circumspect pilot, with respect to consistent and confident aircraft control, there's nothing like slow flight to hone one's skills and feel like you are flying the aircraft, and not the other way around. JAI PPL-A(SEL) Canada |
On Sep 10, 10:24 am, "PPL-A (Canada)" wrote:
On Sep 8, 2:03 pm, Ol Shy & Bashful wrote: There is little doubt in my mind that the ability to do slow flight at the very edge of stall speed will do more to prevent accidents than 1000 hours of cruise speed flight. Is there anyone here who is proficient that lands their aircraft more than 10kts above stall speed? ... In my opinion, the pilot who is comfortable throughout the entire speed range of their aircraft is a properly trained pilot and one who will not get into an inadvertant stall, or spin. What are your thoughts? Other then the obvious objections (expressed here by many others) regarding navigation skills ,and calm, ordered responses to emergencies, as well as interpreting and dealing with weather both before and during flight, I think you have identified a skill that needs to be driven home and repeated again and again with ab initio students until they are comfortable handling the aircraft in any configuration in the slow-flight regime, and, indeed, transitioning between different configurations while in slow flight, as well as handling turns, climbs descents, and simulated "approaches" while in slow flight. (They should get to enjoy it so much that they get in the habit of practicing it themselves as often as possible after certification!) It is such an important concept (the backside of the power curve and what it really means ... try explaining this only once or twice to a typical driver of a car ... I usually only get confused looks even after sketching it out on paper) that no student (no doubt most used to driving a car where one power equals one speed on a flat driving surface) should be considered proficient at slow flight until they can not only DO it but also sketch their aircrafts power curve and explain it to their instructor, identifying all the important point, as well as explaining how it is that a range of power settings correspond to more than one airspeed on the curve. Anyway ... one small thing that relates to slow flight that I found improved my approaches in early training immediately and considerably was the realization that for a given power setting and rate of descent (in feet per minute ), the airspeed would be the same every single time. This allowed me to have a stable approach set up very quickly after turning base and resulted in instantly noticeably better approaches and landings on the next lesson after I learned this (my instructor at the time noticed the improvement immediately, unfortunately it wasn't him that taught me this fact ... I found it on a website produced by another flight instructor ... it was a great site, can't remember its URL now). The airspeed that I aimed for was usually a few knots above slow flight (I aimed for approach speed for short field landing, plus a few knots if it was a little windy or gusty) and of course there was descent involved (about 500 fpm in the 172SP was typical). Long story short ... slow flight training made me comfortable with reducing the power considerably, accurately, and consistently and confidently (to about 1000 - 1300 RPM initially depending on the headwind, again 172SP) when turning base (not just slowly stepping the power and speed down, which consumed too much time on base), quickly and confidently aiming for an approach speed close to a "performance" landing approach speed every time, and with the speed (172 SP - about 61 - 65 KIAS) and descent rate (initially aiming for 500 fpm) stable and trimmed out, all that was required to attend to was the drift, any shear on descent, and staying on a good approach slope visually, while occasionally glancing at the airspeed to ensure it wasn't bleeding off. This usually only required small power adjustments to keep on a proper the approach slope, and of course with more headwind, more power on final. While many other skills (especially navigation, emergency procedures, and weather assessment) are required to become (and remain) a safe, confident but circumspect pilot, with respect to consistent and confident aircraft control, there's nothing like slow flight to hone one's skills and feel like you are flying the aircraft, and not the other way around. JAI PPL-A(SEL) Canada JAI Well written reply. Thanks Ol S&B Canada Commercial #408XXX USA #1550XXX |
On Sep 8, 11:03 am, Ol Shy & Bashful wrote:
There is little doubt in my mind that the ability to do slow flight at the very edge of stall speed will do more to prevent accidents than 1000 hours of cruise speed flight. Is there anyone here who is proficient that lands their aircraft more than 10kts above stall speed? I teach all my students to slow fly with the entire range of configurations for the particular aircraft they are flying. Gear up/ down, flaps up/down/in-between. I want them to be comfortable flying at the very edge of the stall speeds and spend a lot of time maneuvering right on the edge of a stall "nibble". It does more for pilot confidence and ability than anything else I can think of. They learn proper control useage and how their particular aircraft responds while in the low speed areas. Playing with different angles of bank while at low speeds and flying with a modicum of accuracy does a lot for proper control use. If you think about it, how many accidents occur in the low speed spectrum? Either from a stall, or from a high sink rate on approach, or poor control use during an emergency or off airport landing, or something similar? In my opinion, the pilot who is comfortable throughout the entire speed range of their aircraft is a properly trained pilot and one who will not get into an inadvertant stall, or spin. What are your thoughts? I agree with you on the importance of slow flight but for a slightly different reason. I think slow flight and stalls end up being seen by student's as more of a rite-of-passage more than anything else. My approach is to place an intense concentration on the indicators of stall in their aircraft (stall horn, sloppy ailerons, buffeting, nose drop, more buffet, then break). Therefore, I see slow flight more as a way to ensure that students have enough experience with these sensations to recognize them when they need to. In addition, I think most CFI's teach slow flight at WAY to high of a speed. If the student doesn't accidently stall on occasion its almost guaranteed that their slow flight is too fast. In your standard Cessna/Piper type products the plane should be bucking like a wild horse during slow flight. |
| Overweight? Out of CG? Stalled? Too slow? | Flyingmonk | Piloting | 41 | June 25th 06 08:08 PM |
| Running slow | Jamie Nicholl | Simulators | 2 | February 16th 06 10:57 PM |
| why so slow??!! | Heino & Deanne Weisberg | Home Built | 6 | November 6th 05 07:22 PM |
| Flightgear really this slow on XP? | [email protected] | Simulators | 6 | May 9th 05 03:55 PM |
| Flying Slow | [email protected] | Piloting | 61 | January 17th 05 06:23 PM |
