We had FJ-4Bs (1950s Navy fighters) on the flight deck dump fuel from the
rudder mounted dump pipe just above the jet engine exhaust at 100% RPM (no afterburner), but the fuel flow was so torrential it never even ignited. Such fuels have to be partially vaporized to reach the correct ignition temperature to begin burning. WDA end "Keith Willshaw" wrote in message ... "Ed Majden" wrote in message news:kg0gb.28475$pl3.8704@pd7tw3no... Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? If not, why would this be done? On another newsgroup, this is being used to explain a photograph taken by a young fellow in the UK. The photograph was first explained to be the entry of a meteorite in the upper atmosphere but now this is not supported. Some are using this fuel dump ignition theory to explain what was photographed. Your comments on this practice, if it exists, would be appreciated. Ed The RAAF F-111's do this pretty regularly , I seem to recall one did it over Sydney during the recent Olympics, that footage was seen around the world. As for why, well its pretty dammed spectacular is the main reason ![]() Keith |
"Ed Majden" wrote in message news:kg0gb.28475$pl3.8704@pd7tw3no... Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? If not, why would this be done? A pretty standard airshow move in the RA-5. The F-14 could also perform the deed, but it was discouraged by NATOPS. IIRC, JP's flame rate is 260 knots. Theoretically, at speeds faster, your torch cannot catch up with you. I know of no aircraft lost to the trick. R / John |
"John Carrier" wrote in message ...
"Ed Majden" wrote in message news:kg0gb.28475$pl3.8704@pd7tw3no... Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? If not, why would this be done? SNIP: I know of only one loss due to fuel dumping - a Boeing 314 Clipper off Oahu, I believe, in 1939 or so. It had to abort after takeoff and was dumping 100-octane gas and unfortunately flew in a wide level circle and upon entering the cloud of gas-air mix caught fire and crashed. I believe the crew was a Boeing factory crew and it was not on a pssenger flight. FWIW all jet airliners that takeoff at a gross weight higher than max landing weight have fuel dumping capabilitites. ISTR the L1011 could dump 5000#/min. The F4 had to dump fuel to get to carrier landing weight if it had to abort right after launch. Walt BJ |
carrier landing weight if it had to abort right after launch. They all still do. Larry AECS (AW/SW/MTS) Disabled Combat Veteran USN Retired 20 years of Navy in my rear view mirror and getting further away every day ;-) "WaltBJ" wrote in message om... "John Carrier" wrote in message ... "Ed Majden" wrote in message news:kg0gb.28475$pl3.8704@pd7tw3no... Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? If not, why would this be done? SNIP: I know of only one loss due to fuel dumping - a Boeing 314 Clipper off Oahu, I believe, in 1939 or so. It had to abort after takeoff and was dumping 100-octane gas and unfortunately flew in a wide level circle and upon entering the cloud of gas-air mix caught fire and crashed. I believe the crew was a Boeing factory crew and it was not on a pssenger flight. FWIW all jet airliners that takeoff at a gross weight higher than max landing weight have fuel dumping capabilitites. ISTR the L1011 could dump 5000#/min. The F4 had to dump fuel to get to carrier landing weight if it had to abort right after launch. Walt BJ |
"John Carrier" A pretty standard airshow move in the RA-5. The F-14 could also perform the deed, but it was discouraged by NATOPS. IIRC, JP's flame rate is 260 knots. Theoretically, at speeds faster, your torch cannot catch up with you. I know of no aircraft lost to the trick. R / John I worked on CF-104's and CF-101B Voodoos and never heard of this being done. Is this a recent trick or did pilots not attempt this near their home bases where they could be easily identified? ;-) Ed |
On Sun, 05 Oct 2003 21:43:44 GMT, "Ed Majden"
wrote: Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? If not, why would this be done? On another newsgroup, this is being used to explain a photograph taken by a young fellow in the UK. The photograph was first explained to be the entry of a meteorite in the upper atmosphere but now this is not supported. Some are using this fuel dump ignition theory to explain what was photographed. Your comments on this practice, if it exists, would be appreciated. Ed The fuel dump on a Backfire is just above and between the nozzles too. I wonder if they've ever lit fuel off. |
Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? In theory, not if you are going faster than the burn rate of the fuel. The USAF banned it for their F-111s (now retired), the RAAF still does it. It's covered in aus.aviation fairly often groups.google.com/groups?q=dump&btnG=Google+Search&meta=group%3Daus. aviation.* If not, why would this be done? On another newsgroup, this is being used to explain a photograph taken by a young fellow in the UK. The photograph was first explained to be the entry of a meteorite in the upper atmosphere but now this is not supported. Some are using this fuel dump ignition theory to explain what was photographed. Your comments on this practice, if it exists, would be appreciated. Ed Having it happen at altitude in the UK is rather different from at an Australian airshow however. Cheers Errol Cavit |
F-111s at Edwards AFB open houses did it for years (1970s).
Jim Thomas Errol Cavit wrote: "Ed Majden" wrote in message news:kg0gb.28475$pl3.8704@pd7tw3no... Some of you are jet jocks or ex-jet jocks. What can you tell me about the practice of dumping fuel from a jet and the igniting this dumped fuel by cutting in your afterburners? Wouldn't this be a very risky practice? In theory, not if you are going faster than the burn rate of the fuel. The USAF banned it for their F-111s (now retired), the RAAF still does it. It's covered in aus.aviation fairly often groups.google.com/groups?q=dump&btnG=Google+Search&meta=group%3Daus. aviation.* If not, why would this be done? On another newsgroup, this is being used to explain a photograph taken by a young fellow in the UK. The photograph was first explained to be the entry of a meteorite in the upper atmosphere but now this is not supported. Some are using this fuel dump ignition theory to explain what was photographed. Your comments on this practice, if it exists, would be appreciated. Ed Having it happen at altitude in the UK is rather different from at an Australian airshow however. Cheers Errol Cavit |
| spaceship one | Pianome | Home Built | 169 | June 30th 04 06:47 AM |
| Declared "minimum fuel" | O. Sami Saydjari | Instrument Flight Rules | 14 | April 4th 04 03:43 AM |
| Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 08:48 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
