On Feb 7, 5:00 pm, Mike the Strike wrote:
Frank: One thing that classic MacCready theory doesn't take into account is the depth of the working height band. It would be a foolish pilot who set his computer/ring to MacCready 5 on a day with 5 knot thermals that topped out at 1,500 feet AGL, but with cloudbases at 15,000 feet you could probably set it at 6 or higher. Several pilots I know set their ring almost as a function of height rather than thermal strength. The chance of you hooking up with a good thermal increases with the top of the lift and you can increase your speed accordingly. When you get low, you need to slow down. There have been some good articles on this if you search the databases. Mike Mike, Working the bands is very common and I think of it as setting the MC to the strength of the next thermal "I am willing to take". The day average may be 6 knots, but if I am low and willing to accept a 3 knot thermal I will set the MC to that. As I get lower the odds of finding a good thermal are reduced and I am willing to take a weaker thermal to get back up in the band or at least get the range to hopefully reach a better thermal. In the Western US there are many summer days where dropping below the mountain height can cost you dearly in time to get back up. In the 14-18 K range I tend to fly MC+5, 12-14K MC for the average thermal strength I am expecting still to find, 10-12 K I dial back to extend range, 8 to 10K back further and below 8 back to zero. This is with base elevation about 5,000 in the valleys. |
It would be a foolish pilot who set his computer/ring to MacCready 5 on a day with 5 knot thermals that topped out at 1,500 feet AGL, but with cloudbases at 15,000 feet you could probably set it at 6 or higher. Several pilots I know set their ring almost as a function of height rather than thermal strength. My understanding of the theory is that you will ALWAYS be worse off if you set a MC higher than the thermal strength and therefore fly faster than optimum. Flying slower however does have several advantages, as others have described. Stephen |
Stephen:
That is true if all thermals have the same strength. In reality, thermals have a strength (and size) distribution. On a day with a 5- knot average thermal strength you will find thermals as strong as 8 knots or as weak as 3 knots. More working altitude enables you to pick the strongest thermals and maintain an effective MacCready higher than the average thermal strength. The fastest pilots (which doesn't include me) seem to be rather good at this. Knowing when you can step up the speed and when to slow down is the key to winning. Mike My understanding of the theory is that you will ALWAYS be worse off if you set a MC higher than the thermal strength and therefore fly faster than optimum. Flying slower however does have several advantages, as others have described. Stephen |
I really liked John Cochrane's paper "A little Faster Please".
The message I took from that was that the MacCready setting can be used as a general "optimism setting". I tend to set MacCready with a "gut check" about how I feel conditions will be ahead. If you are bumping along above 17,000 feet, there's no thermal that's worth stopping for since you don't want to go any higher so M could be infinity. On the other hand, if you are low in tiger country, you'll take any thermal (M=0). There's a sliding scale in between. I use GPS_LOG which can average the last three thermals and automatically set M. That almost always gives me a M setting higher than my gut says I should use. Maybe that's why I fly slow. Bill D "Mike the Strike" wrote in message ... Stephen: That is true if all thermals have the same strength. In reality, thermals have a strength (and size) distribution. On a day with a 5- knot average thermal strength you will find thermals as strong as 8 knots or as weak as 3 knots. More working altitude enables you to pick the strongest thermals and maintain an effective MacCready higher than the average thermal strength. The fastest pilots (which doesn't include me) seem to be rather good at this. Knowing when you can step up the speed and when to slow down is the key to winning. Mike My understanding of the theory is that you will ALWAYS be worse off if you set a MC higher than the thermal strength and therefore fly faster than optimum. Flying slower however does have several advantages, as others have described. Stephen |
Bill Daniels wrote:
I really liked John Cochrane's paper "A little Faster Please". The message I took from that was that the MacCready setting can be used as a general "optimism setting". I tend to set MacCready with a "gut check" about how I feel conditions will be ahead. If you are bumping along above 17,000 feet, there's no thermal that's worth stopping for since you don't want to go any higher so M could be infinity. On the other hand, if you are low in tiger country, you'll take any thermal (M=0). There's a sliding scale in between. I use GPS_LOG which can average the last three thermals and automatically set M. That almost always gives me a M setting higher than my gut says I should use. Maybe that's why I fly slow. Maybe, but probably not - I think a lot of good pilots do the same. My experience is, if I use a MC setting the same as the average climbs I'm making, two things usually happen: 1) My speed director tells me to fly scary fast in medium or stronger sink (like 110-120 knots), and 2) I get low frequently! So, I usually set it as high as I can without getting stuck low somewhere, and that's generally around one-third of the climb average. I flew contests for many years, and the really good pilots weren't flying much faster, if any, than I was, but they sure chose better places to go, and they knew when to shift gears sooner than I did. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Stephen wrote: My understanding of the theory is that you will ALWAYS be worse off if you set a MC higher than the thermal strength and therefore fly faster than optimum. Flying slower however does have several advantages, as others have described. That is true if all thermals have the same strength. In reality, thermals have a strength (and size) distribution. On a day with a 5- knot average thermal strength you will find thermals as strong as 8 knots or as weak as 3 knots. McCready theory is based on what *you* get for thermal strength, not what a random sampling of the thermals in the area would produce, so I have to agree with Stephen. Set your MC higher than the thermals you are encounter will slow you down. Of course, we're assuming you are flying a classic thermal flight, and not convergence, wave, ridges, etc. Probably no one reading this thread anymore - I was traveling and got here late! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Frank: One thing that classic MacCready theory doesn't take into account is the depth of the working height band. It would be a foolish pilot who set his computer/ring to MacCready 5 on a day with 5 knot thermals that topped out at 1,500 feet AGL, but with cloudbases at 15,000 feet you could probably set it at 6 or higher. Several pilots I know set their ring almost as a function of height rather than thermal strength. The chance of you hooking up with a good thermal increases with the top of the lift and you can increase your speed accordingly. When you get low, you need to slow down. There have been some good articles on this if you search the databases. Mike On Feb 7, 11:50 am, Frank wrote: I'm curious what others are using for inter-thermal cruise speeds for modern 15m (and 18m I guess) gliders like the Ventus 2bx, Ventus 2cx, ASW-27, ASG-29, Diana 2, etc (add models as necessary). Here in the U.S. we have been moving toward cruise speeds much lower than would normally be dictated by using straight McReady settings, but how low is too low? I've also been flying a V2bx & V2cxt in Condor a lot, and cruise speeds there are all over the map, from 90kt to 125kt (fully ballasted) in the same race/weather conditions, with varying results. Any thoughts? TIA, Frank (TA) I have also found John Cochrane's (BB) work in this area to be most enlightening. Here is the link to the paper. http://faculty.chicagogsb.edu/john.c...s/newmcred.pdf It gets pretty technical but the gist is that he blends MC theory with probability (of reaching the next thermal of a certain strength) theory and proves it mathematically. A little calculus for those cold winter months..... Bob |
On Feb 7, 11:50*am, Frank wrote:
Any thoughts? I'm late to the thread but I have read the other posts. So far no one has mentioned: TAS effect (the advantage of better ground speed at high altitude) Polar knees (the sharp fall off in performance at high speed seen in some modern gliders). Streeting Wind shift with altitude. Simple MC theory does not deal with any of this very well, or if it does I missed understanding it. Years ago I thought the only way to fly fast was to push forward on the stick. I used to landout a lot. Over the years I got to fly with many excellent pilots and was impressed by how slow many of them flew and how seldom they stopped to thermal. Andy |
On Feb 7, 1:50*pm, Frank wrote:
I'm curious what others are using for inter-thermal cruise speeds for modern 15m (and 18m I guess) gliders like the Ventus 2bx, Ventus 2cx, ASW-27, ASG-29, Diana 2, etc (add models as necessary). Here in the U.S. we have been moving toward cruise speeds much lower than would normally be dictated by using straight McReady settings, but how low is too low? I've also been flying a V2bx & V2cxt in Condor a lot, and cruise speeds there are all over the map, from 90kt to 125kt (fully ballasted) in the same race/weather conditions, with varying results. Any thoughts? TIA, Frank (TA) The speed that gets you to the next acceptable thermal without hitting the ground. Seems obvious but each day we have to find a rythym that accomplishes this very basic element. I don't see the best pilots making drastic changes in how fast they fly. This takes too much attention better applied to where to fly. UH |
Anyone else here see Carl Herolds talk at the convention a couple
years ago titled, If you fly Mcdready you will lose"? Actually, he said that was a title just to get attention but that the real title was Fly Slower to Fly Faster, or something like that. It was fascinating to see all this graphs and flight traces. It was very convincing to see his data that indicated staying high and not circling was ultimately faster. I think there may be a threshold L/D value particular to specific conditions in which his technique worked. Regardless, I now circle as little as possible. MM |
| real cruise speeds | [email protected] | Home Built | 1 | January 20th 08 03:11 AM |
| ENvironmentally Friendly Inter City Aircraft powered by Fuel Cells | Larry Dighera | Piloting | 83 | June 12th 07 12:07 AM |
| Thermal Data Files Thermal Mapping Project Australia | Mal | Soaring | 0 | December 3rd 05 12:14 AM |
| Inter Club Competition (US NE Node) | Ken Kochanski (KK) | Soaring | 1 | January 22nd 05 06:46 PM |
| Inter Club Competition (US NE Node) | Ken Kochanski (KK) | Soaring | 0 | January 22nd 05 05:09 PM |
